» Wheel & Tire Center
» Sponsors
» Sponsors
Go Back   DSM Forums: Mitsubishi Eclipse, Plymouth Laser, and Eagle Talon Forum: DSMtalk.com > Supporting Vendors > Supporting Vendors > JNZ Tuning
DSMTalk.com is the premier Eclipse, Laser, and Eagle Talon forum on the internet. Registered Users do not see the above ads.Please Register - It's Free!
Old 10-29-2008, 12:33 PM   #1
greenstreak
Honorary Administrator
I don't have a life DSMtalker
greenstreak's Avatar
1996 Talon Tsi AWD
greenstreak's Gallery
Feedback Score: 18 reviews
EvoX radiator install
EVO X Mishimoto Radiator Install
STEP 1
-Let car cool off!! Coolant/Radiator/Hoses are HOT!
-Drain engine coolant once everything is cool.
-Remove Plastic Intake Air Duct
: 2 plastic Screws
-Remove Plastic Cowl above radiator
: 3 plastic Screws
-Remove Upper (hot side) Intercooler Pipe
: 2 clamps, 2 12mm bolts
(In the above photo you can see the X with the upper plastic trim pieces and upper intercooler pipe removed for access)
STEP 2
-Remove 4 10mm Bolts into bumper tabs
-Remove 3 10mm Hood Latch Bolts and pop Cable out (Unplug harness directly behind core support (2 wires))
-Remove 10mm Bolts holding Radiator support
: 2 on each side up top, 3 under hood latch
-Unplug Horn Wire
-Remove 1 10mm Bolt holding headlight to Rad support on each side.
-Pop the 3 clips out for the Latch harness (behind support on drivers side).
-Pop the 3 clips out for the crash sensor harness (harness runs underneath rad support)
-Remove the 2 12mm Nuts for the crash sensors
: one next to the intercooler inlet, other far D/S of rad support
: then remove sensors
-Remove the Radiator support. Shouldn't need much more than a little wiggle and pull.
(In the above photos you can see the X with the upper radiator support removed.)
STEP 3
-Unplug and un-clip the radiator fan wiring harness.
-Remove the 12mm bolt holding the Coolant filler neck to the Fan Shroud.
-Next remove the A/C Condenser from the Radiator
: There are 2 tabs that need to be un-clipped halfway down the radiator on each side.
: Then there are 2 more tabs at the top of the radiator, on each side.
-Remove Clamp for Upper hose to Radiator then remove hose from radiator.
-Remove Clamp for Lower U-shaped hose to Coolant Pipe or Radiator.
: It was easier to leave the U-shaped hose attached to the rad, and disconnect it at the pipe end.
-Remove Radiator, lift up on passenger side of radiator first, then pull up to slide radiator w/fans out.
(Stock radiator removed with fans still attached)
(Engine bay with the stock radiator removed)
STEP 4
-Stock Fan assembly has 4 clips and 2 10mm hold downs
: Remove the 10mm bolts and brackets
: Pop the 2 clips halfway down each side of the radiator, and the 1 on each top corner.
-If you left the U-shaped hose attached to the radiator, then swap it to the new one now.
-Swap fan assembly to the new radiator, and put the 10mm bolts back in with their brackets.
(The pictures above illustrate the installation of the stock fans to the Mishimoto aluminum radiator)
STEP 5
-Slide the radiator back down in, drivers side first to get the U-shaped hose to clear the side
-When the lower locating posts line up and drop into the rubber grommets, you are good to continue.
-Then lift up the A/C condenser and slide it down into the clips. Make sure it's all the way seated.
The Mishimoto radiator seated back in the stock location. Great fitment!
STEP 6
-Re-install the core support, watching the middle brace and bumper tabs.
: It is easier to run and clip in the harnesses now, while the rad support is loose
-Re-install the Hood latch and Crash sensors.
: The hood latch cable runs through the big hole on the right (d/s) of the latch
-Re-install the upper and lower coolant hoses, and the filler neck to the fan shroud.
-Re-install the Upper Intercooler pipe.
-Re-fill with coolant and start the Car
-Check for any leaks. If none, then finish the install of your performance Mishimoto Radiator.
(JNZ Tuning upper intercooler pipe is re-installed. Upper and lower radiator hoses are also re-installed at this stage)
STEP 7
-Re-install the Plastic Cowl above the radiator.
: Also install the intake air duct to airbox if you still have the stock setup.
(Back how we started but with the additional cooling and great looks of the new Mishimotor radiator!)
-In the pictures below you can see a side by side comparison of the Mishimoto aluminum radiator next to an OEM EvoX radiator. Notice the attention to detail in the fan shroud mounting points and radiator hose hookups.
Stats on the Mishimoto radiator are as follows:
Originally Posted by Mishimoto
Core Size: 700mm x 408mm
Rows: 2
Inlet: 35mm
Outlet: 35mm
Core Thickness: 40mm
Tank Wall Thickness: 2mm
Purchase Includes: Mishimoto Radiator and 1 Year Warranty
(courtesy of JNZ Tuning, Inc. www.jnztuning.net)
Interloper.
greenstreak is offline
Old 10-29-2008, 03:01 PM   #2
Got Insulin?
Ultra DSMtalker
Got Insulin?'s Avatar
93 AWD, 06 R53
Got Insulin?'s Gallery
Feedback Score: 20 reviews
Re: EvoX radiator install
That's cool that it has a removeable rad support. Cool write-up, guys.
Currently boost-less.
-Taylor
Originally Posted by winterwarz View Post
Then again me and the search button never got along after I cussed it out for not supplying the right results. .
Got Insulin? is offline
Powered by vBulletin® Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
