Re: Grinding noise when cranking?
Pull off the inspection plate at the bottom of the trans and check out the condition of the ring gear, If it looks good, pull out the starter and check out the engagement gear. If that also looks good, you have an alignment issue. Unless your car starts and still has a grinding noise - then it could be something entirely different.
George
AWD conversion | Dogbox Racing trans | ACT flywheel | Southbend SS TZFE clutch | 94mm Eagle crank | Manley pistons + H-beam rods | L19's | HKS HG | Kelford 272's | Kiggly beehive springs | Ferrea SS valves | AMS race shaft | Fidanza cam gears | Gates timing belt | FP race manifold | FP 18g | Injen intake | Greddy FMIC kit | Greddy RS BOV | Greddy profec S EBC | JMF street SMIM | 1g TB | Walbro 255hp | FIC 1050's | Aeromotive AFPR | DSMLink v3 | Inovate wideband
