Throttle Body Uprgade Worth It? - DSM Forums: Mitsubishi Eclipse, Plymouth Laser, and Eagle Talon Forum: DSMtalk.com
» Wheel & Tire Center
Go Back   DSM Forums: Mitsubishi Eclipse, Plymouth Laser, and Eagle Talon Forum: DSMtalk.com > DSM Tech Central > General DSM Tech and Tuning
Old 01-23-2013, 10:44 AM   #1
streaknby
Super DSMtalker
streaknby's Avatar
97 TSi AWD
streaknby's Gallery
Feedback Score: 4 reviews
Currently I have a 63mm tapered and polished NT TB bolted up to a JMFab Race SMIM. Up to the TB I have a 3" upper IC piping and narrows to 2.48" (63/25.4) at the TB. I have been told a number of times now tht I could see a noticeable airflow/power increase upgrading to a 3" throttle body. I'm looking to squeeze some more power out of my current setup without making any boost/timing advance increases or other significant part swaps as I am right on the edge of knock on pump as it is. For this reason I have had the thought and am starting to consider this TB upgrade as an option to get where I want to go. Would the swap from a ~2.5" to a 3" TB make a worth while difference?
streaknby is offline   Reply With Quote
Old 01-24-2013, 10:45 AM   #2
Ripper_XX
Ultra DSMtalker
Ripper_XX's Avatar
Eagle Talon TSi 1990
Ripper_XX's Gallery
Feedback Score: 7 reviews
Re: Throttle Body Uprgade Worth It?
Is it true that an oversized TB tends to make the car more sensitive to throttle input?
1990 Eagle Talon TSi AWD 318hp @ 5950 w/stock SMIC & catback
If you can blame guns for killing people, I can blame misspelled words on my pencil!
Ripper_XX is offline   Reply With Quote
Old 01-24-2013, 11:35 AM   #3
Sean485
Senior Moderator
Sean485's Avatar
99 Spyder "GSX"
Sean485's Gallery
That depends on what the rest of your setup looks like, a stock 60mm tb has gone 10's so they can flow the air required and money may be better spent elsewhere. I have never seen a test done where they measure pressure in the IC pipe pre-tb and then another measurement at the plenum and see the difference but if you did that would be a good indication of if your tb was actually limiting you much or not.
As for the more sensitive throttle, they can to a degree simply because your gas pedal only has 'X' amount of travel and you are changing the restriction in the intake system more per amount of movment of the pedal vs a stock tb. I have an accufab 75mm on my car and its definitely there but you get used to it quickly.
99 Spyder "GSX"
Sean Clancy
Sean485 is offline   Reply With Quote
Old 01-24-2013, 02:01 PM   #4
MindBlowin03
Honorary Moderator
MindBlowin03's Avatar
'97 TSi AWD
MindBlowin03's Gallery
Feedback Score: 20 reviews
If you have 3" IC piping then you probably should upgrade but it also depends on the rest of your setup. Will you see a noticeable difference? Not sure on that. IMO, your money can be spent better elsewhere but it would make your intake slightly more efficient.
-Nick
'97 Talon AWD - 6 bolt / 8.5:1 Mahle/Eagle combo / T3 HX-40(.70 A/R) / ported/polished head / HKS 272s / Cyclone intake / Dual 255's(intank/inline) / FIC 1150s / Spoolin' Up AFPR(43psi) / -6an fuel lines / Meth/water(75/25) / GM MAF / ECULink V3
565 awhp 524 lb/ft
My build thread
MindBlowin03 is offline   Reply With Quote
Old 01-24-2013, 05:21 PM   #5
scotthidley
Elite DSMtalker
scotthidley's Avatar
92 TSI AWD / 05 Quattro
scotthidley's Gallery
Feedback Score: 1 reviews
I think I'm missing something. Let me rephrase what I understand.
Your fuel system is maxed out, and you want to find out if putting a larger throttle body will increase your horsepower without you adding fuel for the additional air?
My hunch is you might get a slightly lower air temp at your intake manifold, but I don't think you'd be able to make any gains as you don't want to add more fuel.
Finally out of storage in it's new garage slowly getting ready to be started for the engines first time.
scotthidley is offline   Reply With Quote
Old 01-24-2013, 05:53 PM   #6
streaknby
Super DSMtalker
streaknby's Avatar
97 TSi AWD
streaknby's Gallery
Yes I think you may have misunderstood a bit. My fuel system is not maxed out, I have lots of room in that area still. At 22psi on my HX40 and 10* of timing up top I'm at the limits if what 91 octane will allow. Another 1psi of boost or any more advance and I'm starting to get some knock. So my question is will the increase in airflow from a half inch diameter increase at the throttle body to match my 3" upper IC piping be a worthwhile upgrade.
Sean and Mindblowin, you both said it depends on the rest of my setup. What else are you referring to? The rest of the intake system is 4" FP straight to the 0.70a/r HX40 running speed density. 2.5" hot piping to a 3" in and out 24x12x3 IC with 3" short route UICP to a 63mm tapered and polished NT TB, JMFab Race SMIM, Buschur Stage 4 Head with Kelford 272's.
Old 01-24-2013, 06:45 PM   #7
Sean485
Senior Moderator
Sean485's Avatar
99 Spyder "GSX"
Sean485's Gallery
With the fact you have significant flow upgrades with the head and cams as well as the 3" uicp (which I hadn't caught when I first read your post) and a sufficient turbo to supply the flow I would vote that a larger TB would give you a noticeable gain and you would likely do it at less boost.
99 Spyder "GSX"
Sean Clancy
Old 01-24-2013, 07:55 PM   #8
scotthidley
Elite DSMtalker
Thanks for clarifying. I need to read things a few times as I still haven't caught up to my jet lag.
That swap could yield a gain. The area increase is ~40% neglecting the flappers. More than the area increase, you currently have a flow restriction right at the manifold. If you keep to your IC piping size and maintain steady flow into the manifold, you could eliminate a bit of turbulence and possibly save a bit on your intake temps.
Not the best turbo comparison, but years ago by opening up my 14b compressor housing, I was able to run another 2-3 PSI at the same intake temps as before the change.
