» Wheel & Tire Center
» Sponsors
» Sponsors
Old 09-08-2001, 11:38 AM   #1
tanner261
Super DSMtalker
1992 AWD Eagle Talon
Trader Rating: (0)
tanner261's Gallery
I would like to run water injection on my car and I have little money to work with. I have seen tutorials for a few different homemade systems, but I'm concerned that the water won't be "atomized" enough through some cheap water sprayer nozzle and the pump won't be able to keep up without costing a whole lot of money. Would it be worth doing a simple homemade system, or should I save my money and go with the aquamist 1 or 2?
If you have any good websites for a homemade system, please post them.
tanner261 is offline   Reply With Quote
Old 09-08-2001, 11:44 AM   #2
beerglass
Hardcore DSMtalker
Trader Rating: (0)
beerglass's Gallery
Wink
I built a alcohol injection system about 3 weeks ago, cost was $45 Canadian. If you want i can email you a list and the basic setup.
Clinton
1990 Talon Tsi Awd @17 psi
beerglass is offline   Reply With Quote
Old 09-08-2001, 05:32 PM   #3
davejcb
Super DSMtalker
1991 TSi AWD
Trader Rating: (0)
davejcb's Gallery
Hey if can email the list I'd like that! Where did you buy the stuff? Crappy Tire?
91 NT A/T Eagle Talon -> Busted tranny
1985 Honda Prelude -> Winter beater
91 TSI AWD: Neverending rebuild
"Food goes in here" - Homer
davejcb is offline   Reply With Quote
Old 09-09-2001, 12:35 AM   #4
Taylor SPL
Super DSMtalker
1995 Talon TSi
Trader Rating: (0)
Taylor SPL's Gallery
If you could email that to TaylorL@azstarnet.com as well it would be nice Taylor
1995 Talon TSi
15.266@90.65 @ 3075 ft.
14.766@95.16 @ 1250 ft. (Same Mods + 107 Octane)
Autometer 30-0-30 Boost Gauge
Greddy TT
Greddy Hard IC Pipe Kit
Greddy Type-S
Magnacore 8.5mm Wires
Injen Intake
Some BG Syncroshift
Symborski Shifter Kit
Taylor SPL is offline   Reply With Quote
Old 09-09-2001, 01:13 AM   #5
roadpie4u
Hardcore DSMtalker
roadpie4u's Avatar
Camaro z28 M6 Ragtop
Trader Rating: (0)
roadpie4u's Gallery
Talking
yeah, and to roadpie4u@aol.com
~Geoff
95' z28 Camaro M6 Convertible. ~800hp on pump gas.
Ex owner of 4 DSMs now!
roadpie4u is offline   Reply With Quote
Old 09-09-2001, 02:23 AM   #6
3312DC
Super DSMtalker
90 LaserRST
Trader Rating: (0)
3312DC's Gallery
user fastgsxauto has a nice system he made for 35 bucks... if your nice he will let you know how he made it. He gets 0 knock at 21 psi on a 16G
3312DC is offline   Reply With Quote
Old 09-09-2001, 02:42 AM   #7
SldSnk
DSMtalker
1990 TsiAwd
Trader Rating: (0)
SldSnk's Gallery
Just post it so we all have the general idea.
SldSnk is offline   Reply With Quote
Old 09-09-2001, 09:03 AM   #8
GST97ORL
Ultra DSMtalker
Blue 91 TSi FWD
Trader Rating: (0)
GST97ORL's Gallery
Lightbulb Injection systems
I'm interested as well, but if we're a community of DSMers here, let's not just email it to selected receivers, post your ideas here, I'd love to see some different configurations. Besides, if it were me, I wouldn't want to have to email the same thing to 10 different people. Share the wealth!!
GST97ORL is offline   Reply With Quote
Old 09-09-2001, 09:19 AM   #9
beerglass
Hardcore DSMtalker
Trader Rating: (0)
beerglass's Gallery
Wink
Here you go guys, not trying to keep it form anybody just didn't know if there was aynone interested or not. O.K here's what i got for you guys. The injector i used was off a 1984 240sx
startup injector, takes a phillips screwdriver and a pare of side cuts. You
can use one off a Sabb (82-86) but they spray straight down and is about 1"
as opposed to the 240 which sprays to one side and is 2". Take as much of
the wire as you can it helps. The pump is off a 87 Acura it's located
infront of the drivers side rear wheel. It has a pressure reg on the top
take it off and trash it then you have a high flow pump with straight
fitting's in and out. Used a rad overflow tank off a 85 Prelude it holds
approx 2 lt's, and a dual prong oil pressure switch from Napa rated for 10
psi. And depending on where you put everything you'll need 3-4 feet of 5/16
gas line and some wire and 30amp relay. What i did was weld a flang for the
injector and a nut for the pressure switch to the upper I/C pipe about 6"
before the throttle body, you'll have to make something up but it was really
easy. Now to wire it i ran constant power to the pump and injector and ran
the relay off the pressure switch to trigger the ground, which should put
less load on everything. Now for mounting everything is mounted where the
pollution canister and cruise contorol used to be. If you still have this
stuff maybe the driverside wheelwell or if you have a FMIC where the stock
IC went. If any of this sounds like mumbo/jumo just mail me again, i don't
mind don't worry. Oh and all the ground leads off the pressure switch, pump
and injector are hooked to led's which are going to be mounted on my a
piller when i get another chance to work on it it again. Hope this helps.
( My EGT's are 1550, 50 deg lower than without, and O2's are at .94 WOT third gear, .04 higher
than without)
Clitnon
vB code is On
Powered by vBulletin®
