Hey I just installed the Apexi Auto timer and it's working great. I was wondering if anyone else has this turbo timer and they could help me setting up the A/F value and the O2 Sensor Voltage. I did a search and I wasn't able to find any help on setting these 2 features up. Should I just leave it defaulted to what it has? Will that be a acturate reading?? Thanks for anyone that can help out.
I left the default settings as it is when I got it. You shouldn't have to adjust it or anything as long as it displays the correct value. It works fine and accurate as least for me.
I have that new timer and it actually does a good job of giving a value close to what the proper a/f mix is. I usually dont use the ratio though, I use the O2 sensor voltage values for tuning. I have seen cars on dynos that graph the a/f mix and the apex TT seems pretty damn close. Basically I have mine set to 11. Most cars want a little higher than that but I am having massive fuel delivery issues due to the cold weather here in pa. At a ratio of 11:1 it is still a little rich but whatever. I have it tapped into the kick panel O2 voltage output harness rather than the ecu as the pin connections on the wiring diagram for the apex unit was incorrect. I wouldnt really rely on the ratio that much, I just have it set to that to see a green light light up at WOT (it's a psychological thing I guess) . Basically the unit uses the same technology the LED a/f guages use but it is a little easier to interpret due to numeric values versus little lights. Hope this helps. Lata
what is the the default settings for the A/F ratio and the o2v? when i put in in, i was movin the things around and need to set it to the default, im gettin wack readings. TIA
Anybody have a vfaq for this install yet? I have the timer laying around but I haven't had a chance to install it yet. If nothing exists, maybe I'll make one
thanks i found it. its hidden behind the floor hvac vent. i took them out and theres like 4 harnesses behind it. now i gotta figure out why my ebrake shut off wont work.
Does anyone have a vfaq for this?? I really need a lil help. I do not have the greddy harness. I only have the wires coming from the back of the TT. I bought it from ebay and hope this is what it comes with. I am in the process of soldering up mySAFC 2 LE and would like to do this at the same time, but I do not know which wire go where. I know i sound like an idiot. I have wired to the ecu before many times but never the ignition. Please help
Chris
there is a pretty good faq on www.plymouthlaser.com this guy does a pretty decent job on faqs so it shouldnt be to difficult to follow...
Related Threads
2.3M posts
102.7K members
Since 2000
