Just replaced the timing belt and all the seals under it, but something's not right. I also replaced the starter. It ran fine before.
Idle is smooth, but it revs slowly and won't go above 3000. Acts like its leaning out- if I didn't know better I'd say the MAF was disconnected.
I've checked all the timing marks a couple of times, they seem fine. Pretty sure I didn't reverse the plate- the motor can be rotated by hand with a wrench and there's good compression across the board. Maybe I knocked a vacuum line loose?
