Hey, I have a 1GB awd eagle talon, has a 6 bolt 4g63 and a 2g 95-96 trans with a matching transfer case and a 4bolt lsd in the rear. The car has seen better days, the body is starting to rust, I found 2 holes in the floor, there is rust showing underneath and quite frankly, I'm tired of having a 1g dsm. I'd like to buy a 2g awd shell to swap the engine/trans and everything I can.
My question is, what is swap-able from the 1g to the 2g. I know my trans will work as it's from a 95-96, engine will work as well.
What about the diff? I know the axles & drive shaft aren't the same, but will the diff ( center section) bolt up to the 2g shell?
Is the rad the same? (I have a mishimoto rad, 1.5-2 inch thick)
Anything else I should need for the shell swap? special harness for 7 to 6 bolt swap?
I know i'll need a computer, harness, etc.
