I believe that's why I've seen some local guys saying "Less Talk, more Tuning" with "- DSMtuners" tagged on it. It's fun to poke, but in the end, we're all here for the same common goal. Carry on.
__________________ - Dustin DSMtalk Rules and FAQ!! 1997 Mitsubishi Eclipse GSX - 12.281 @ 115.85 MPH (KCIR) 1991 Eagle Talon TSI AWD 5 Speed B16g - The Daily
I'm back!! Did some searching on Google and the Holset site, but couldn't figure out how to determine which hotsides I have. I believe one is a 12cm^2 and the other a 9cm^2 (so I was told). Where exactly do I measure to know which is which?
Thanks
- Matt 5 speed, 4 cylinder, 3 diamonds, 2 liters, 1 turbo, 0 chance of losing.
Missed edit time. I looked here but didn't see the numbers I have. I looked up the hotside numbers and the assy numbers off the compressor covers. Ideas?
Spec number is always stamped on the outside of the housing somewhere as well as the inside of the inlet (manifold flange). On this particular 18cm HX40 housing it's stamped on the housing itself, not on the downpipe flange, just under the part number. It's easiest to just look inside the inlet.
There are no 9cm HX35 turbine housings to my knowledge- the smallest I've seen is 12cm. The HY35 uses a single-scroll 9cm housing. The smallest factory HX40 housing known is a 16cm divided T3....anything smaller has been machined to fit.
The AutoGuide.com network consists of the largest network of enthusiast-owned enthusiast-operated automotive communities.
AutoGuide.com provides the latest car reviews, auto show coverage, new car prices, and automotive news. The AutoGuide network operates more than 100 automotive forums where our users consult peers for shopping information and advice, and share opinions as a community.
