» Wheel & Tire Center
» Sponsors
» Sponsors
Old 09-30-2009, 04:25 PM   #1
MacGSX
Ridiculous DSMtalker
MacGSX's Avatar
1999 GSX
Trader Rating: (21)
MacGSX's Gallery
Low Idle/ High Idle
Ok, this is not a idle surge thread. I've spend all day swapping in/out q45's and tps' and finally got everything running good. My problem is I set my idle when the car was rather cold, so once it was warmed up it was idling higher(1200-1400 but no surge). So I got the car to operating temperature and set the idle (850-900) but now on cold start up it idles so low it wont stay running. I just don't know what to do. The TPS is fully functional as well. No boost leaks, not running lean/rich. The car is healthy as can be other than this.
Jordan
11.91 @117 Spinning through first
---Build History of My GSX---
MacGSX is online now   Reply With Quote
Old 09-30-2009, 04:51 PM   #2
aferraro21
DSMtalker
aferraro21's Avatar
93 Elantra, 03 350z GT
Trader Rating: (0)
aferraro21's Gallery
Re: Low Idle/ High Idle
Do you notice any difference when you adjust your base idle screw on a cold start?
aferraro21 is offline   Reply With Quote
Old 09-30-2009, 04:55 PM   #3
n0rthendtr00per
Hardcore DSMtalker
n0rthendtr00per's Avatar
Mitsubishi GSX 1995
Trader Rating: (5)
n0rthendtr00per's Gallery
I have the same issue. But after warmed up it surges. So I'm pretty sure I'm in the same boat with Mac
12.3 at 114.67mph
Goal is 11s!
n0rthendtr00per is offline   Reply With Quote
Old 09-30-2009, 04:56 PM   #4
MacGSX
MacGSX's Avatar
1999 GSX
Trader Rating: (21)
MacGSX's Gallery
Adjusting the idle screw whether hot/cold affects the idle in respect to which direction you change it.
And I just want to make it clear it doesn't surge one bit. It has a very smooth idle.
Old 09-30-2009, 05:04 PM   #5
aferraro21
DSMtalker
aferraro21's Avatar
Trader Rating: (0)
Right, and I know you don't have surge or boost leaks (which I ruled out the IACV if you're running one), I'm thinking that maybe when you set your idle, you had the BIS too far in or out. Since the car was warm it might have seemed like it was idling ok but maybe you didn't leave yourself enough room for adjustment when the car is cold? I'm not saying that IS your problem, just trying to give a little insight on what helped me when I had idling issues.
Surging is usually caused when the IACV is stuck slighly open. You will either need a new one, or I have an old one you can pay for shipping and rebuild it yourself (I've heard there are kits out there).
Old 11-03-2009, 10:46 AM   #6
95boostdgst
1995 mitsu eclipse gst
Trader Rating: (0)
95boostdgst's Gallery
I'm having the same exact problem with my 95 gst with a 98 motor.. has anybody figured this out yet?
95boostdgst is offline   Reply With Quote
Old 11-03-2009, 10:49 AM   #7
Gamble
Gamble's Avatar
97 AWD & 97 Camry
Trader Rating: (30)
Gamble's Gallery
Do you have an isc?
If not on a cold startup, hold the gas down to catch the idle for like 20-30seconds then let go and it should be fine.
Another reason I stayed with the stock tb.
Gamble is offline   Reply With Quote
Old 11-03-2009, 10:59 AM   #8
aferraro21
DSMtalker
aferraro21's Avatar
Trader Rating: (0)
His car runs fine when it is warm, but has problems running on cold start-ups. This is a common problem for people who block off their idle air control units, or are using Throttle Bodies from different vehicles.
Are those the symptoms you are having? If not you are looking at a boost leak idle surge related issue.
Old 11-03-2009, 11:01 AM   #9
Mitsucolt
91 GST
Trader Rating: (0)
Mitsucolt's Gallery
What are you using to tune your car? With EFI the computer computer "ignores" the o2 sensor and adds more fuel until the car is warm. The reason why cars usually idle higher when its cold out, then idle down once warm. Somewhat of an "EFI choke" i guess in comparison to carb. engines. Your car however is doing the opposite. My guess is that the computer is not adding that extra fuel. And that is why it is stumbling when its cold, just like a carburated engine would when started without the choke.
Mitsucolt is offline   Reply With Quote
Old 11-03-2009, 11:15 AM   #10
93_GSX
Ultra DSMtalker
93_GSX's Avatar
1993 Mitsu GSX
Trader Rating: (0)
93_GSX's Gallery
Could you be having an issue with the coolant temp sensor?
93_GSX is offline   Reply With Quote
Old 11-03-2009, 11:18 AM   #11
Gamble
Gamble's Avatar
97 AWD & 97 Camry
Trader Rating: (30)
Gamble's Gallery
Typically when they go bad they read -40* and your car won't start.
Old 11-03-2009, 11:22 AM   #12
93_GSX
Ultra DSMtalker
93_GSX's Avatar
1993 Mitsu GSX
Trader Rating: (0)
93_GSX's Gallery
Gotcha, just trying to learn new things...
Old 11-03-2009, 11:23 AM   #13
Mitsucolt
91 GST
Trader Rating: (0)
Mitsucolt's Gallery
Makes sense.
Old 11-03-2009, 01:03 PM   #14
MacGSX
MacGSX's Avatar
1999 GSX
Trader Rating: (21)
MacGSX's Gallery
I have heard of the coolant temp sensor going bad and casuing this problem without it reading -40*. Then sensor is cheap from autozone and is worth a shot.
Jordan
Old 11-03-2009, 01:10 PM   #15
93_GSX
Ultra DSMtalker
93_GSX's Avatar
1993 Mitsu GSX
Trader Rating: (0)
93_GSX's Gallery
Cool.
vB code is On
Powered by vBulletin®
