I've never been able to get mine PERFECT, but the arrow parts should be lined up with the notch openings at least. I don't know if it's even possible to get it 100% perfect considering there are slight length differences from belt to belt. From what I can see in the pics, it looks like if you rotated your cams a little more to line up those marks and the other two are still within the indentations, then you should be good.
EVO III 16G, RC 550s, rewired Walbro 190, SAFC-2, dejon tools 2.25" intake, Joe P XZ MBC, Dave Brode UIC pipe, 1G BOV, 2.5" Stainless downpipe and test pipe, HKS Hi-power exhaust, Dejon Big SMIC, Symborski shift kit, brass shifter bushings, front and rear ES motor mount inserts, Auto-Meter 30-30 boost gauge, progress sport springs, 6 Bolt w/ balance shafts removed, balanced rotating assembly, ACT 2600 Clutch, ACT XACT Streetlite Flywheel.
