Car grinds on cold start. - DSM Forums: Mitsubishi Eclipse, Plymouth Laser, and Eagle Talon Forum: DSMtalk.com
Wheel & Tire Center
Notices
Old 11-06-2003, 10:39 PM   #1
rivet0r
90 Laser RST
rivet0r's Gallery
When I start my car in the morning, my car will give a screaching grind for a second and then stop. I don't understand what it could be, and I have no idea. Any help would be great.
Also forgot to add that it's more grind than screach. I don't think it's an accessory belt, it sure doesn't sound like it, and like I said, it only lasts for a second and then stops.
for reference : 90 Turbo Laser
-rivet0r
rivet0r is offline   Reply With Quote
Old 11-06-2003, 10:46 PM   #2
rivet0r
90 Laser RST
rivet0r's Gallery
Someone told me that it could be the crank bearings, which would require a rebuild.. just not sure how credible that opinion is.
Old 11-07-2003, 12:09 AM   #3
Turboholic
Hardcore DSMtalker
91-Talon TSI-AWD
Turboholic's Gallery
-My oil pump did that when it was on it's way out.
-Kevin.
Turboholic is offline   Reply With Quote
Old 11-07-2003, 04:10 AM   #4
tsunari
DSMtalker
Mitsubishi GS-T '97
tsunari's Gallery
Do you know where it may be coming from? My grind turned out to be the starter gear not retracting quick enough and so was grinding with the flywheel. So I replaced it with a Bosch, but in reality, I guess I could've just cleaned it up, lubed the shaft and put it back in. . .
tsunari is offline   Reply With Quote
Old 11-07-2003, 07:31 AM   #5
rivet0r
90 Laser RST
rivet0r's Gallery
Did it only grind on a cold start? Mine only does it on a cold start, if it's warm, or just not freezing cold and has been sitting over night, it won't grind.
Old 11-07-2003, 08:04 AM   #6
tsunari
DSMtalker
Mitsubishi GS-T '97
tsunari's Gallery
Hmmmm. . . thinking back . . . I guess it didn't matter whether it was cold or not. Something you can do . . .pop your hood when your stuff is cold and have someone start her up while you listen for the grind under the hood. If it sounds like it's coming from somewhere around your intake manifold or maybe even just to the left (passenger) side of the intake manifold, then it's probably the starter.
If that's not it - I will not even begin to speculate. Hope this helps narrow it down!
