6 bolt head - need help
I'm about to order my new valves, valve springs, retainers, locks, and valve seats along with the hks cams and cam gears.. my question is, when i was taking the stock valves out, i accidentally dented one of the little metal peices that stick out - its hard to explain without a picture so i'll do my best..
when you take the cam shafts out, they are held in by these U-brackets w/ two bolts, when you take the two bolts off, the u-bracket, and the cam, your left with the rest of the U that support the cam shaft - the U has two metal circles that are hollow for the screws to go through... well i dented about 3 of them and now i can't get the U's back on... I hope someone understands what i'm talking about.. is there a way to replace them or is the block messed up for good?
Also, should i go with a stock valve bore, .5 over or 1.0 over? and 3 or 5 angle valve job?
Thanks...
