worst case symptoms/damage caused by bad PCV valve? - DSM Forums: Mitsubishi Eclipse, Plymouth Laser, and Eagle Talon Forum: DSMtalk.com
Wheel & Tire Center
Notices
Old 04-12-2004, 09:44 PM   #1
airbrush1
airbrush1's Avatar
2003 evo 8, miata
airbrush1's Gallery
what problems could a bad PCV valve cause? what symptoms would occur? I had a problem with blowing the hose to the pcv valve off when I drove the car hard, I "fixed" it by zip tying the hose on. the hose seemed like it had been "sucked flat" afterwards... still is, and the car runs like crap and smokes like hell now ( see post- "I think I killed it...") Might replacing this valve remedy my problem? The car runs like absolute crap when the hose is disconnected, I assume it could cause some problems if the valve went bad? SUGGESTIONS????
airbrush1 is offline   Reply With Quote
Old 04-12-2004, 09:56 PM   #2
Sean485
Senior Moderator
Sean485's Avatar
99 Spyder "GSX"
Sean485's Gallery
Feedback Score: 7 reviews
Check to make sure your throttle plate is adjusted right. If your car made enough vaccumm to flatten out that hose something is up. What does the vaccumm read at idle?
As for the pcv valve... if its stuck open it will let boost into the crank case and blow the dipstick out. If its stuck closed its not a huge deal really.
99 Spyder "GSX"
Sean Clancy
Sean485 is offline   Reply With Quote
Old 04-13-2004, 02:44 PM   #3
airbrush1
airbrush1's Avatar
2003 evo 8, miata
airbrush1's Gallery
say the dipstick doesn't bloe out for some reason, could the built up pressure cause more severe preblems... IE: blown gaskets etc???
Old 04-13-2004, 02:54 PM   #4
outbost
Super DSMtalker
92 Laser RS AWD
outbost's Gallery
It would be more likley to shoot your dipstick through your hood and into orbit than blowing a gasket from a open PCV valve.
"Eclipses and Talons are cool, but Lasers
are poser cars." (some chick on CarDomain)
I just don't understand why people think that,
so here it is.
outbost is offline   Reply With Quote
Old 04-13-2004, 04:28 PM   #5
Stephen
Senior Moderator
Stephen's Avatar
1995 Talon TSi AWD
Stephen's Gallery
Feedback Score: 2 reviews
Ive seen that happen LOL
Just imagine some guy is driving down the highway with his wife when a random dipstick goes right through the hood of his car and is embedded into the asphalt
Stephen is offline   Reply With Quote
Old 04-14-2004, 09:19 AM   #6
barney
03 EVO VIII
barney's Gallery
Worse case scenario - underhood fire fueled by oil blown out of the engine.
The only thing I can think of that would cause the pcv hose to be sucked flat is an air cleaner element completely plugged. Maybe you need a new hose.
"It's a segment characterized by attention deficit disorder." - Finbarr O'Neill, Mitsubishi Motors North American CEO on the Eclipse's market segment. Hmm, is this why we have so much trouble with timing belts?
barney is offline   Reply With Quote
