» Wheel & Tire Center
» Sponsors
» Sponsors
Old 07-22-2004, 07:47 PM   #1
QuasiMondo
Hardcore DSMtalker
QuasiMondo's Avatar
91 Galant VR-4
Trader Rating: (1)
QuasiMondo's Gallery
Logging boost with MMCD
If this is a repost, my apologies. The only other places I saw this topic were on the 3SI and GVR4 forums.
While checking the GVR4 forums, I came across this thread:
http://www.galantvr4.org/ubb/ultimat...c;f=4;t=000536
This thread linked to the 3si boards which had the link to mmcd ver 1.6n,
http://www.3si.org/forum/showthread....6&page=1&pp=10
which then lead me to this thread where the discussion about being able to log your boost through the use of a MAP sensor
http://www.3si.org/forum/showthread....highlight=mmcd
What it boils down to is that for DSM's with Federal emissions, you can tap into the unused egrt connection with the MAP sensor. With the updated MMCD program, it will convert the voltage that the egrt sees into your boost pressure.
The previous thread gives instructions on using both a 3-bar GM sensor, and a 2-bar sensor chip developed by Motorola (they have the part number and link to who sells the Motorola chips in that thread as well)
So seeing that it worked well for 3si cars, I figured why not give it a shot on the ol' 1G? I cracked open my Chilton's manual, and checked the ecu diagrams and this is what I came up with:
The egrt connector for 1g's is located behind the intake manifold, It should not be connected to anything, so it's probably still taped to the engine wiring harness.
The signal side of the connector is blue with a yellow stripe.
The signal ground is green with a black stripe.
They also indicate that a 5v source can be tapped from the TPS, on the green/white stripe wire.
After that, use a t-fitting to hook up the sensor the same way you would install your boost gauge.
So how did it go?
With fingers crossed, I checked my connections and started up the ol' bird. She came to life, settled down to a nice idle of 750 rpm, and no CEL. So far, so good.
Next came a few highway runs. With one eye on the speedo, one on the road, another on the boost gauge, and my last eye on the logger, I did a couple of 3rd, 4th, and 5th gear pulls. My boost gauge read 16 psi, my logger read 15.9. I tried a few more 5th gear pulls to see if the logger would match the movement of my boost gauge needle. The logger matched it at 5 psi, 10 psi, and 15 psi.
The only thing that bothered me about the run was that the whole time while driving, I encounted random misfires. Some happened at cruising speeds, and I had a few at my full throttle runs. Thinking it was a loose spark plug, I checked and found nothing wrong. I then double checked my connections to make sure none of them were shorting to ground, and did two more runs. The misfire was still there. I finally decided to pull the 5v wire that I had tapped into my TPS. Obviously, the TPS is not going to be a good place to get my 5 volts. Suprisingly enough, the map sensor worked just fine without it. I even went back on the highway to record a few more runs to see if it would work any differently. It ran great all the way up to max spool.
So, is this modification worth it? You bet your bottom dollar! This can only help to make tuning on your car that much easier. The beauty of this modification is that with MMCD, they can use this egrt connection not only to monitor boost, but you can connect your wide-band o2 sensor, EGT, oil pres, oil temp, and fuel pressure sensors to this connection (keep in mind, you can only hook up one item at a time )
So if you have MMCD, this just makes it 10X more beautiful. If you use the TMO software, they have an input for the egrt, but I'm not sure if they upgraded their software to allow you to read it a map sensor reading. If you use pocketlogger, you'll have to create some sort of table to read the raw egrt data which will come out as a value from 0-255 and convert it that way.
I've checked the ecu diagrams for 2G's but I don't see where the egrt connectors are for those cars, if you're willing to give it a try for your 2G, let me know if it works.
Many thanks to Clint Batters from the 3si forum who helped with the software upgrades, Shaun Polson for developing this kick ass program, and all the other contributors to this program for giving us DSM'ers another wonderful tool to use to help with our tuning!
QuasiMondo is offline   Reply With Quote
Old 07-22-2004, 09:54 PM   #2
noreaga0221
Ultra DSMtalker
1990 eclipse gst
Trader Rating: (1)
noreaga0221's Gallery
awesome!! How much was spent? Pics would be cool.
So the 3 bar sensor taps into stock wiring and a boost source then relays a signal to the motorola chip that talks to your logging software?
2002 c230 coupe.
noreaga0221 is offline   Reply With Quote
Old 07-22-2004, 10:14 PM   #3
QuasiMondo
Hardcore DSMtalker
QuasiMondo's Avatar
91 Galant VR-4
Trader Rating: (1)
You can use either the 3 bar GM map sensor to tap into the egrt connection, or you can use the motorola chip.
The gm sensor will cost $40, the motorola chip will run you $18.
While the motorola chip is less than the gm sensor, you're also paying for the durability since the motorola chip would be exposed to the heat of the engine, who knows how long it would hold up.
Both will wire up to the egrt connection the same way.
I'll try to make pics this weekend to show all how it connects.
Old 07-25-2004, 09:25 PM   #4
QuasiMondo
Hardcore DSMtalker
QuasiMondo's Avatar
91 Galant VR-4
Trader Rating: (1)
I still haven't gotten around to taking pictures of this setup, but I have learned some things.
1. You DO need that 5v source for this motorola chip, and for the GM MAP sensor as well. It'll work without it, but it won't be accurate. I was logging boost while my gauge still read a vacum. With the voltage in, it regained it's accuracy. The misfire problems I had with the 5v wire tapped was because I tapped it into the wrong wire on the TPS. Chalk that one up to differences in the wiring harness of 3SI's and DSM's.
2. The motorla chip may have a limit. Even when I had a boost had crept up to 19psi on one run, the logger peaked at 15.9psi. If that's the case, I might end up getting a 3 bar MAP sensor just so I can log my readings past 16 psi. This sensor is good if you just want something to show when your car is on boost, then you can stick with this chip, but I want accurate readings. I'm going to ask the 3SI people if they have that problem with this chip as well, and let you guys know what I come up with.
Old 07-25-2004, 09:27 PM   #5
noreaga0221
Ultra DSMtalker
1990 eclipse gst
Trader Rating: (1)
I have tmo software. how can i get mmcd?
2002 c230 coupe.
Old 07-25-2004, 10:58 PM   #6
QuasiMondo
Hardcore DSMtalker
QuasiMondo's Avatar
91 Galant VR-4
Trader Rating: (1)
This is the 3SI link to MMCD ver. 1.6n. I usually keep an eye on the other threads to see if there are any updates.
Old 07-26-2004, 08:40 PM   #7
QuasiMondo
Hardcore DSMtalker
QuasiMondo's Avatar
91 Galant VR-4
Trader Rating: (1)
Here's an update:
The motorola chip is fine. I had it wired backwards which is why I was reaching the 16psi limit. I'm going to fix that problem tomorrow and test it again. Once everything is said and done, I'll write up a how-to with pictures. Many thanks to the folks over at the 3SI boards who helped me figure out where I went wrong.
Old 07-28-2004, 12:20 AM   #8
QuasiMondo
Hardcore DSMtalker
QuasiMondo's Avatar
91 Galant VR-4
Trader Rating: (1)
The FAQ
This FAQ is the one drafted up by Clint Batters, one of the 3SI moderators for wiring up a MAP sensor to your EGRT input for 1G DSM's with Federal Emissions:
_________________
ELECTRONIC BOOST LOGGING FOR 1st GEN ECU
Just a short FAQ on an easy mod for adding a boost signal for anyone using either the MMCd or Shiver's SW on a 1G ECU. The mod takes advantage of an unused EGRT sensor on all of the Federal ECU's.
Many thanks to Jeff Lucius for putting the bug in my ear on an earlier post about an "unused input."
FAQ
EGRT ECU input is just a 0-5 VDC signal. ECU doesn't care whether it is a boost signal, wideband O2, oil pressure or fuel sensor. MMCd and Mirage Datalogger have sensor configurations to correctly scale either the 2.5 or 3.0 BAR MAP sensors.
For those of you running PocketLogger, ask them to get on the ball and provide user scaling options for the EGRT input.
WIRING
Only 3 wires to get boost logging working. +5V, Ground and signal.
Note: EGRT input has 10K ohm resistor to +4.5V to provide excitation for the EGRT sensor. This is why the logger will show the count at ~229 counts or 90% of full scale before you connect anything to it. (If your connect the EGRT signal to EGRT ground the count will go to zero.) THe 10K oullup resistor does not have any material affect on the accuracyof the MAP sensor.
MAP - HARNESS 3SI Updated color codes from RDMellon - Thanks!
+5V - TPS Connector (Green/Yellow)
Ground - EGTR Connector (A22 - Black)
Signal - EGTR Connector (A22 - Light Green/Black)
A-22 Connector is located near the injector resistor module - may be taped up with some other wires.
MAP - HARNESS DSM
+5V - TPS Connector (green/red)
Ground - EGTR Connector (green/black)
Signal - EGTR Connector (blue/yellow )
GM SENSOR INFO (provided by Jeff Lucius)
The GM 3-bar MAP sensor is available from MSD Ignition. Search google for MSD2313 or MSD-2313. The store below sells it for $49.70
http://www.aquamist.co.uk/sl/plist/...66/806-666.html
You'll also need a socket/harness connector. Conduct Tite (PN 85146) sells some that are a close match or that may need only a little bit of knife work to make the correct notch for the key on the sensor connector. See middle pic and red rectangle in the web page below for where notch needs to be added.
http://www.tognottisautoworld.com/s...DUCT_ID=MSD2313
http://www.hondata.com/3barinstall.html
ALTERNATE SOURCE for GM SENSOR (Provided by TurboBob)
www.gmpartsdirect.com
Sensor part number 12223861
Connector # 15305891
AUTOMETER BOOST GAGE
If you have an AutoMeter Boost gage you already have a GM 3.0 BAR MAP sensor installed. All you have to do is connect the signal wire from the MAP sensor to the EGRT input on A22. (Only connect the signal line, not the ground.)
MOTOROLLA MPX4250AP MAP SENSOR
You can also use a Motorolla MPX4250AP 2.5 BAR sensor but you will have to either solder or find a suitable connector for the small leads and provide some mechanical protection for the sensor. (Consider using a .100" connector for easy attachment / service.)
http://www.3si.org/forum/attachment...achmentid=30773
PINOUT
PIN1 - Vout (Signal) Note: Pin 1 has notch on pin
PIN2 - GND
PIN3 - +5V
PIN4 - NC
PIN5 - NC
PIN6 - NC
ORDERING INFO
http://rocky.digikey.com/WebLib/Mot...0A%20SERIES.pdf
Exact part number is MPX4250AP-ND. It is available for under $20 directly from DigiKey.
HISTORY
http://www.3si.org/forum/showthread...56&page=1&pp=10
MMCd V1.6F posted 3/17/04
http://www.3si.org/forum/attachment...achmentid=35334
More MMCd info / Latest versions
http://www.3si.org/forum/showthread...26&page=1&pp=10
_________________________
I finally have my setup in, and after a few test runs, I can confirm that it works as advertised. If you're boosting no more than 20psi, the 2.5 bar sensor from Motorola will work fine for you, otherwise you extreme boosters will have to use a 3-BAR sensor.
Finally, if you have a Turbo Colt or GVR4 and you plan on doing this setup, drop Clint a line so he can update his faq. I'm sure both of those cars have different wiring codes and it would be a great help.
Mondo
Old 12-28-2005, 08:12 PM   #9
green_bread
Hardcore DSMtalker
green_bread's Avatar
'92 Eagle Talon TSI AWD
Trader Rating: (14)
green_bread's Gallery
Re: Logging boost with MMCD
the latest version of MMCD, and the one you would want to use, is MMCD version 1.8g. You can find it several places online by way of Google search or you can email me... I have a copy saved on my computer, as well.. green_bread182@hotmail.com
ADAM
green_bread is offline   Reply With Quote
Old 12-29-2005, 02:48 PM   #10
DSMturbo2
Ultra DSMtalker
altrevo
Trader Rating: (0)
DSMturbo2's Gallery
hate to hijack... but i does anyone have a link to logging autometer egt readings on mmcd. i have been all over all the forums i can find including 3S and have found nothing.
i need to know if the autometer module has a 5v output? thanks, Erik
Erik
1991 GVR4 1189/2k
1992 Eagle Talon TSI (needs home)
1992 Plymouth Laser RS AWD (SeaBass)
1992 Plymouth Laser RS AWD (the Black Car)
DSMturbo2 is offline   Reply With Quote
Old 12-29-2005, 04:06 PM   #11
QuasiMondo
Hardcore DSMtalker
QuasiMondo's Avatar
91 Galant VR-4
Trader Rating: (1)
http://www.dsmchips.com/mmcdv18g.zip
This is the link for the newest version of MMCD 1.8G.
To log EGT readings via mmcd, the same principle applies. A federal ECU is required, and the 0-5v outputs on the EGT probe would connect to the unused EGRT connector the same way the MAP sensor would be connected. The MMCD program has options to use this connector to hook up a 2.0, 2.5, or 3.0 BAR sensor, a wideband oxygen sensor, or an EGT sensor. You'd probably have to contact autometer themselves to see if the probe they use with your meter uses a 0-5v output.
Old 12-29-2005, 05:17 PM   #12
mytmous
mytmous's Avatar
90 Eclipse GSX
Trader Rating: (0)
mytmous's Gallery
ADAM
Where is this MMCD version 1.8g? I've searched, and the highest I can find is 1.7
mytmous is offline   Reply With Quote
Old 12-29-2005, 06:25 PM   #13
eyebrowski
eyebrowski's Avatar
90' Talon TSI AWD
Trader Rating: (1)
eyebrowski's Gallery
http://www.dsmloggers.com/mmcd1.8g.zip
Greg Dombrowski
eyebrowski is offline   Reply With Quote
Old 12-29-2005, 08:55 PM   #14
DSMturbo2
Ultra DSMtalker
altrevo
Trader Rating: (0)
DSMturbo2's Gallery
yeah i have ver.18g and i was just hoping someone has done it. it is the typical tre probe, autometer egt combo, that a million people have. i know i have always heard of people logging their egts with mmcd, however have never seen a how to.
i would be able to figure it out myself however i seem to be getting some odd readings from the dvom. i did suspect that my guage was going, now it may be more.
but if anyone knows which wire is the signal wire for the autometer it would be great to know. and also if anyone knows what the voltage range is for it, that would be awesome too.
another question would be, is mmcd set so i can say i have my egt signal on this channel (egt port), is it going to give me accurate readings... just like that, or will i have to scale it? thanks Erik.
Erik
1991 GVR4 1189/2k
Old 12-29-2005, 08:59 PM   #15
QuasiMondo
Hardcore DSMtalker
QuasiMondo's Avatar
91 Galant VR-4
Trader Rating: (1)
When you go to the Preferences, there is an entry for the EGRT sensor. That's where you make the change to have it read your EGT. No scaling is necessary.
vB code is On
Powered by vBulletin®
