Car WAY out of tune wuth safc 2 - DSM Forums: Mitsubishi Eclipse, Plymouth Laser, and Eagle Talon Forum: DSMtalk.com
Wheel & Tire Center
Notices
Old 11-04-2005, 03:06 PM   #1
jim90TSi
1990 Eagle Talon TSi
jim90TSi's Gallery
Ok guys i just got a dsm, has a big 16g, 550's, 2.5" exhaust, ported 2g o2, and an safc 2. right now the boost is set at around 15 psi i belive. The car is way out of tune though. I do not have a logger yet, getting tommorow if it got mailed. Anyway, is there anything i can do to shut the safc down? i bought the car this way and it is way out of wack. I do not want to mess with it as i have no idea how i would do it without a logger......Is there a way to just erase it, zero it, or shut it down to where i can drive the car and tune it when i get my logger?
jim90TSi is offline   Reply With Quote
Old 11-04-2005, 04:07 PM   #2
french_hustler
Honorary Moderator
french_hustler's Avatar
1997 Eclipse Gsx
french_hustler's Gallery
Feedback Score: 8 reviews
Re: Car WAY out of tune wuth safc 2
set all low and high trim levels to 0....
french_hustler is offline   Reply With Quote
Old 11-04-2005, 04:25 PM   #3
jim90TSi
jim90TSi's Gallery
ok everything is set to zero that i can see........ne points are still set, but have 0 correction.......low throttle is 0% and hi is 1%(wouldnt go to 0). Anything else?
Old 11-04-2005, 04:32 PM   #4
Chicago_DSM
Ultra DSMtalker
Chicago_DSM's Avatar
90 Tsi AWD
Chicago_DSM's Gallery
Feedback Score: 13 reviews
at least do the correction for your injectors..that should help...also check for boost leaks <---its usually that
-Josh-
'90AWD - Garage whore SOLD
'95AWD - Daily bitch
Chicago_DSM is offline   Reply With Quote
Old 11-04-2005, 04:34 PM   #5
jim90TSi
jim90TSi's Gallery
what kind of correcttion do you think i would need with 550's? The car does run pretty rich by the way.
Old 11-04-2005, 04:48 PM   #6
diablooffire03
Super DSMtalker
97 Eclipse GST
diablooffire03's Gallery
Now how do you know the car does not run rich without a logger or wideband... You can't always go by seeing smoke
full manifold-back exhaust, 550cc,T28killer,Victory O2,afc2,widebandO2,FAL-slimfans,thickradiator,GreddySbov,hahn sidemount,intake,APEXI avcr,20PSI *SOLD*. Now Own Boosted IS300 400whp
diablooffire03 is offline   Reply With Quote
Old 11-04-2005, 04:54 PM   #7
jim90TSi
jim90TSi's Gallery
exhaust fumes smell like gas, mostly what i noticed was the gas mileage which was 14.47 and that was slightly spirited but nothing to much. I understand boost eats fuel but i try to stay out.
Old 11-04-2005, 08:23 PM   #8
french_hustler
Honorary Moderator
1997 Eclipse Gsx
its coo the way it is for right now i think... put your boost down to 13-15 and try not to push the car until you get it fully tuned...
Old 11-04-2005, 08:54 PM   #9
greenstreak
Honorary Administrator
I don't have a life DSMtalker
greenstreak's Avatar
1996 Talon Tsi AWD
greenstreak's Gallery
Feedback Score: 19 reviews
With larger injectors like you have you can't just zero out the afc. You need it for the injector correction. Bump the low to -12% or so as a guess point. Get a logger and learn to tune it yourself from that point. Leave the high at 0 and you will run rich. You really need to take some fuel out there too. -10% should be safe until you can get a logger on it.
Old 11-04-2005, 09:21 PM   #10
jim90TSi
jim90TSi's Gallery
so run the low at around -12% and the high at 0%? or did you mean take -10% out of the hi also?
Old 11-04-2005, 10:09 PM   #11
pepsi21463
DSMtalker
Mitsubishi GSX 95
pepsi21463's Gallery
Sounds like my car. It's very rich, infact I failed emissions twice because of it. Although, the first time I forgot to turn the AFC down, and today I forgot to lower the settings for 1,000 rpm. Both were my fault but it's still rich. My friend complained about it after I put 10 car lengths on his LT1.
Do what I'm doing, save up and get DSM Link.
pepsi21463 is offline   Reply With Quote
Old 11-04-2005, 11:35 PM   #12
jim90TSi
jim90TSi's Gallery
i bought a datalogger which will get me by just fine.........should be here soon
I got it worked out..........runs a little rich but runs good at 15psi.
Old 11-05-2005, 09:57 AM   #13
Chicago_DSM
Ultra DSMtalker
90 Tsi AWD
Exactly what I was saying, without the exact numbers...With larger injectors, just zero-ing out the safc will not help you out, you would be running rich and boggy at low-hi rpm's...But, you should idle and run a little better if you are taking out fuel to compensate for the larger fuel setup, and then taking a little bit about up top should help also
I still think un-tuned 15psi is a little risky but as long as you keep your boosting conservative and get that logger on soon, you should be fine...
Post some logs after you get that logger
-Josh-
Old 11-16-2005, 12:25 AM   #14
tarantula
Ultra DSMtalker
98 Eagle Talon TSi AWD
tarantula's Gallery
Feedback Score: 21 reviews
You changed your throttle points to 0/1? Change them to 30% low and 70% high for starters. With the 0 low and 1 high, it won't even use the lo throttle correction. It will run off the highs throttle settings as soon as you touch the gas.
Sold the legend! Eagle has lifted its wings and flew away.
tarantula is offline   Reply With Quote
Old 11-16-2005, 10:07 PM   #15
jim90TSi
jim90TSi's Gallery
i did that to zero out the safc, so i could get a base start.....they are at 30/85 now
