1G Engine Ground diagram (please help) - DSM Forums: Mitsubishi Eclipse, Plymouth Laser, and Eagle Talon Forum: DSMtalk.com
Wheel & Tire Center
Go Back   DSM Forums: Mitsubishi Eclipse, Plymouth Laser, and Eagle Talon Forum: DSMtalk.com > DSM Tech Central > Electronics Tech
Notices
Old 06-19-2006, 07:54 PM   #1
racer96x
1990 Laser 2.0 N.T.
racer96x's Gallery
Greetings all, first and foremost I am glad to see that there are a mass of peeps sharing in DSM's and this is my first post to the board. Last year I bought a 90 Lazer NT 2.0 with a stick. Trans was bad, so I re-built it(output shaft ground a bearing). Anywho I removed the trans and the car was running fine. It sat for 3 months before I worked up the ambition to put it back in. I re-connected the cables to the batt terminals(the guy I bought the car from used marine terminals for batt terminals ) needless to say I cooked the ecu, which by the great vast knowledge from this forum I realized it was a common problem from the cars sitting for a while. I'm putting a used ecu in (with replaced caps) But I want to make sure that my grounds are correct and in perfect working order. Does anyone have a diagram for these grounds or a drawing? I saw one on here about a week ago (hand drawn) but I can't find it and am not sure if it will work for the non-turbo, considering the diagram was for the 1g turbo. Thanks for the help, and I"ll post whatever I can to help with the "throbbing brain" of forums.
racer96x is offline   Reply With Quote
Old 06-23-2006, 08:00 AM   #2
Skywise
Hardcore DSMtalker
Eagle Talon 1991
Skywise's Gallery
Re: 1G Engine Ground diagram (please help)
ground points are the same on a 1g
Skywise is offline   Reply With Quote
