Re: fmic piping need help
Yep, I just bought a couple 90 degree bends, some 45 degree bends and some straight pipe. Cut em to what I needed and used couplers to get em together. Might not be as 'easy' and buying a kit, but definatly more fun.
1998 GSX - Ported EvoIII Big16G @ 25psi, 272/272 Cams, 2600 Clutch, 680cc Injectors, 24x12x3 FMIC, Ported Exhaust Manifold, 255hp Fuel Pump, AFPR, DSMlink, Wideband 02, K&N Intake, Dejon Tools Intake Pipe, Profec B Spec II, Boost, EGT, & Oil Pressure Gauges, 02 Recirculating Dump, 2.5" DP & TP, 3" Catback Exhaust, 1G BOV, Short Throw Shifter, Shocks, Springs, ADR Rims, T1-S Tires, NGK Plugs & Magnacore Wires, Turbo Timer, Front & Rear Strut Bars...
http://www.mcmpoolandtree.com/eclipse.html
