Delayed/hard shift into drive - DSM Forums: Mitsubishi Eclipse, Plymouth Laser, and Eagle Talon Forum: DSMtalk.com
» Wheel & Tire Center
Old 11-02-2006, 01:39 PM   #1
Cold Dark Shado
Cold Dark Shado's Gallery
Car: 1993 Eclipse GS
When shifting from park to Drive (N to drive) it takes like 3 seconds or so and then it goes into drive hard. Is that normal for these cars or could something be up?
Goes into reverse fine
Cold Dark Shado is offline   Reply With Quote
Old 11-02-2006, 02:01 PM   #2
foxgst
Ultra DSMtalker
foxgst's Avatar
1991 Eclipse GSX
foxgst's Gallery
Feedback Score: 9 reviews
Re: Delayed/hard shift into drive
How many miles does your tranny have on it??? Just wonderin.
foxgst is offline   Reply With Quote
Old 11-02-2006, 02:10 PM   #3
Cold Dark Shado
around 112K
Old 11-02-2006, 03:17 PM   #4
Daywalker69
DSMtalker
Daywalker69's Avatar
1990 Eclipse GSX
Daywalker69's Gallery
When was the last time you checked your tranny fluid level? That's the first sign it's a bit low.
Billy
Daywalker69 is offline   Reply With Quote
Old 11-02-2006, 05:20 PM   #5
Cold Dark Shado
good question, forgot about that lol
Ill check itout tomorrow and post back
Thanks
Old 11-02-2006, 06:53 PM   #6
BABAGANOOSH
Super DSMtalker
BABAGANOOSH's Avatar
91/TSi/FWD~92/ESi/NT
BABAGANOOSH's Gallery
Feedback Score: 2 reviews
Fluid, unless your having other problems.
~ I am the self proclaimed DSMtalk.com Noob King ~ All Noobs Must Worship ~
See, now it's car related
BABAGANOOSH is offline   Reply With Quote
Old 11-02-2006, 07:02 PM   #7
Cold Dark Shado
other then that when it is in gear its got a rough idle @ 1K and below above 1.5K it smooths out a bit
Hitting stop signs and lights the idle drops to like 700 or 800 and gets rough and sometimes feels like it wants to die and then bounces backup to 1K
Old 11-02-2006, 08:11 PM   #8
Daywalker69
DSMtalker
1990 Eclipse GSX
That last part sounds like it's time for a tune up :-)
Old 11-02-2006, 08:24 PM   #9
Cold Dark Shado
plugs, wires, fuel/oil filters and oil have been changed within the last 300 or so miles
Water pump and headgasket with head, timming belt and a few other things done within the last 3K
Old 11-02-2006, 08:25 PM   #10
Cold Dark Shado
The idle surges as well in park (1 or 2 hundred RPM)
Old 11-02-2006, 08:29 PM   #11
Daywalker69
DSMtalker
1990 Eclipse GSX
Hmmmm....I'm thinkin Arby's. Oh, sorry I mean idle air control valve. Might just need to clean out the passage.
Billy
Old 11-02-2006, 08:53 PM   #12
Cold Dark Shado
i got a spare IAC, could swap it out and see what happens (actaully have a near complete low mileage 4g63T setup) but change my mind on doin the swap so its all gettin sold. I just got this car (and a galant) about 2 weeks ago.
Im actually pretty new to the whole FWD import OHeverything scene. im more of the V8 sub mid 70s stuff. Did have an RX7 vert i traded for the above cars
Its got a pretty bad case of lifter tick as well, i heard swappin in 3g lifter will cure it?
Old 11-02-2006, 09:04 PM   #13
Daywalker69
DSMtalker
1990 Eclipse GSX
Won't hurt to flush out that port while you've got the old AIC out.
As far as the lifters, I dunno, I'm brand new to this engine....but I know a treatment of Rislone hushes up the 3.0's, and they tick just because.
Billy
Old 11-03-2006, 01:21 PM   #14
Cold Dark Shado
Went out and took it for a ride and checked the trans fluid, Levels good just a touch below that top check hot line and there was a few little bubble in it. Still alot of vibration in gear (R and D)
what would it take/cost to change the trans fluid and filter in it if i took it in to a shop? IM in MN and its cold out otherwise id do it myself
Old 11-03-2006, 02:29 PM   #15
coryd
Super DSMtalker
Eagle Talon TSI AWD 92
coryd's Gallery
Feedback Score: 12 reviews
all u need to do is unbolt the pan and the filter should be right there on the valve body so just unscrew it screw a new one on and install a new pan gasket and fill it up, (whatver u do, do NOT us rtv on the gasket)
540 whp 35r powered 2.0L
coryd is offline   Reply With Quote
