car will not shift into gear when engine is on PLEASE HELP - DSM Forums: Mitsubishi Eclipse, Plymouth Laser, and Eagle Talon Forum: DSMtalk.com
Wheel & Tire Center
Notices
Old 11-18-2006, 03:08 PM   #1
jeepman1998
Super DSMtalker
jeepman1998's Gallery
Feedback Score: 4 reviews
Angry car will not shift into gear when engine is on PLEASE HELP
92 talon awd turbo.
it has always had a little difficulty shifting from 1 to 2 gear or just getting into reverse.
after driving today i noticed it was hard to get into any gear without being stopped
I tried adjusting the clutch pedal out thinking maybe it was not pushing it in far enough.
After i turned the screw a few times out (there were not many threads on it anyway) i started the car and went to shift into any gear and it will not go
before I tried to adjust it I noticed when I put the clutch in and put it in first gear waiting at a light. I could hear a rattle or grinding sound only when car is on and in gear with clutch pushed in.
my guess is the clutch master cylinder does that sound right.
I am not low on any fluids.
I changed the tranny fluid a few weeks ago.
synchromesh
Do these cars ever stop breaking, this car is more unreliable than my mustang was and it was a race only car!!!!!!!!!! lots of hp 150 shot of nos.
jeepman1998 is offline   Reply With Quote
Old 11-18-2006, 03:12 PM   #2
ziggyman
DSMtalker
ziggyman's Avatar
'04 Hayabusa '90 TSiAWD
ziggyman's Gallery
Feedback Score: 2 reviews
Re: car will not shift into gear when engine is on PLEASE HELP
Its the T.O.B. or the pressure plate or both.
ziggyman is offline   Reply With Quote
Old 11-18-2006, 03:12 PM   #3
dtowneclipse
Super DSMtalker
dtowneclipse's Avatar
03' GT
dtowneclipse's Gallery
Feedback Score: 3 reviews
Does it grind when you try to put it in gear? Or it its quiet and it just wont go in?
dtowneclipse is offline   Reply With Quote
Old 11-18-2006, 03:17 PM   #4
jeepman1998
Super DSMtalker
first will not go in and second grinds like hell
Old 11-18-2006, 03:17 PM   #5
jeepman1998
Super DSMtalker
what is t.o.b
Old 11-18-2006, 03:19 PM   #6
dtowneclipse
Super DSMtalker
03' GT
Throw Out Bearing, if it grinds it is likely to be a clutch or TOB problem.
Old 11-18-2006, 03:21 PM   #7
dtowneclipse
Super DSMtalker
03' GT
I had a pressure plate go out on me one time, when I sat there with the clutch in i could hear a funny, almost grinding noise. It would not go into gear either.
Old 11-18-2006, 03:23 PM   #8
jeepman1998
Super DSMtalker
how come that before i adjusted clutch screw out a few turns it would shift when car is on and after I adjusted the rod out some it does not shift when car is on.
the car ran fine this morning, went out to tune and after about 1hr driving was hard to shift into gear.
got home adjusted clutch lever out. tried it car on and would no go into gear.
then i adjusted lever in and now same thing
Old 11-18-2006, 04:35 PM   #9
jeepman1998
Super DSMtalker
Thumbs down Re: car will not shift into gear when engine is on PLEASE HELP
well not leaking any fluid and the shift fork seems to be pushing far it does not look like it could be pushed any farther.
so new clutch, pressure plate and throw out bearing time
HOW MUCH DOES THE TRANNY WEIGHT SINCE I HAVE TO REMOVE IT TO PUT NEW CRAP IN..
BOY I JUST LOVE MY CAR POS
Old 11-18-2006, 06:32 PM   #10
LordDigi
Super DSMtalker
LordDigi's Avatar
1993 GSX
LordDigi's Gallery
Exclamation Re: car will not shift into gear when engine is on PLEASE HELP
Before you go and do that ... check your crank end play.
-- 1993 GSX Auto | 2.3L 6Bolt | 8.8 Wiseco | Eagle Rods | Ferrea Valves | Crower Springs | HKS 272s | JMF SMIM | s90 TB | 3" short route FMIC | BW s366SX-E 66/73 | Tial v44 | Link v3 SD | MSD DIS-2 w/COP | AEM 340LPH & Walbro 255LPH | PTE 1600 | e85
LordDigi is offline   Reply With Quote
Old 11-18-2006, 07:54 PM   #11
11secdsm
11secdsm's Avatar
91 GSX
11secdsm's Gallery
Feedback Score: 33 reviews
Has the tranny been off recently? If so (or even if it wasn't), make sure all the bell housing bolts are on tight. If not, it can cause the tranny to separate from the block a little. I had this happen to me once and I've seen others that had the same problem.
-Chris
9.14@151
9.40@154
9.50@120
Wiseco HD 10.5:1, R&R rod, CBRE head, Kelford 280, FP Super99, Magnafuel 4301, FIC 2150s , built auto, Bradco converter, JMF int/exh manifolds, FMIC, piping, Link v3 w/ SD, KP Tuned
11secdsm is offline   Reply With Quote
Old 11-19-2006, 12:14 PM   #12
jeepman1998
Super DSMtalker
tranny has been on for 15000 miles i bought it few months ago have a recipts for rebuild of tranny engine and t case.
The throw out bearing is only 15000 miles old and was oem.
Is there any thing I can do to test things before I take it out.
I looked at the clutch fork only the part sticking out, It seems to be moving at full push. Should I try to just unbolt the slave and put a shim in there to see if i can get it to push out enough.
Or did I possibly bend the fork or break the pivot ball? Is there any way to check without removing tranny.
It looks like it might be easier to just pull engine instead or transaxle.
That looks like a whole lot of work and lot of time to do.
If I unbolt the slave and move the clutch fork by hand will I be able to tell anything.
This is my first man trans I have worked on.
Old 11-21-2006, 01:01 PM   #13
jeepman1998
Super DSMtalker
Smile Re: car will not shift into gear when engine is on PLEASE HELP
ok I went out to push the car closer to the garage to work on. well I was parked at a slope on gravel and couldn't push it.
So I decided to go ahead and shift it into reverse and start the car with the brake on well it didn't catch the first time, it is always a little difficult to engauge reverse. Worked great then before I went to turn the car off to shift into first I tried it, It shifted fine in all gears with car running!!!!!!!
could anything have been jammed and come loose not it seems to be working just fine.
Before I go road test it I would like some opinions.
I have no clutch chatter seems to be not slipping not shure though.
I know there is a search button but it is not helping could someone please
give me your thoughts.
good or bad
thanks brad
Old 11-21-2006, 03:41 PM   #14
jeepman1998
Super DSMtalker
anyone?
going to go on test drive after some input.
anything could have got stuck and then started working fine?
Old 11-22-2006, 11:40 AM   #15
samtheman1975
DSMtalker
1992 plymouth laser rs
samtheman1975's Gallery
Feedback Score: -1 reviews
hi all:
I took mine to garage I got exactly the same problem. He is a talon specialiste and he said it is the transmission fork. There is a pivot in there that gets used with time and u need to add a washer so it can push the through out bearing properlly. If I knew this I could have saved 400$ but for now I am sick of it some letting him do it for me. Once you change a clutch or a transmission ALWAYS change the fork at the same time.
Hope this will help
Sam
samtheman1975 is offline   Reply With Quote
