» Wheel & Tire Center
» Sponsors
» Sponsors
Go Back   DSM Forums: Mitsubishi Eclipse, Plymouth Laser, and Eagle Talon Forum: DSMtalk.com > Parts/Vendor Discussion Area > Parts Reviews Only
Old 12-21-2006, 01:04 PM   #16
VisionPaintball
DSMtalker
VisionPaintball's Avatar
Eagle/Talon/1993
Trader Rating: (1)
VisionPaintball's Gallery
Re: Powertrain Technologies Twin Disc Clutch
http://videos.streetfire.net/categor...1800eba72f.htm
This is supposedly the Devo clutch.
VisionPaintball is offline   Reply With Quote
Old 12-21-2006, 09:56 PM   #17
DSMonster
DSMtalker
DSMonster's Avatar
1998 TSi AWD
Trader Rating: (2)
DSMonster's Gallery
thats alot of clutch, very nice wirte up.
6bolt, built head, SCM 61, 880's, DSMlink and more..
DSMonster is offline   Reply With Quote
Old 12-23-2006, 10:43 AM   #18
blackflame
DSMtalker
blackflame's Avatar
98 Eclipse GSX
Trader Rating: (1)
blackflame's Gallery
Is that the clutch that is making all that noise? Damn man, thats a loud little bugger. I was gonna go with that clutch, but I might lean towards something else.
blackflame is offline   Reply With Quote
Old 12-23-2006, 06:02 PM   #19
GAstroker
DSMtalker
GAstroker's Avatar
eclipse,gsx,97
Trader Rating: (3)
GAstroker's Gallery
I'd just like to add my 2 cents here. I bought the PTT clutch a few months ago and for the first time all year I was able to make a clean pass at the track. 1st pass was a 10.3. Before that my best pass had been an 11.0. Steve at PTT is an awesome guy and will walk you through just about any question you have. I was running the CompCLutch Ironman disk before and the weight of the disk created to much inertia so I would always miss every gear at high rpm. I use the iron disks the Vic was speaking of and its not that noisey at all.
Mike
8.8 @ 165mph
http://www.youtube.com/watch?v=2izAlxAY8UY
GAstroker is offline   Reply With Quote
Old 12-27-2006, 11:37 AM   #20
bowerboy_1
eagle talon tsi awd 95
Trader Rating: (0)
bowerboy_1's Gallery
Who has the webpage for powertrain technologies?
bowerboy_1 is offline   Reply With Quote
Old 12-27-2006, 12:35 PM   #21
11secdsm
11secdsm's Avatar
'06 Evo IX
Trader Rating: (33)
11secdsm's Gallery
Google is your friend.
http://www.powertraintech.com/
-Chris
GVautosport sponsored '06 Evo IX
OLD setup- STOCK everything HTA 35r
502 whp- Dynojet
11.19@128 (pump gas)
NEW setup- forged 2.3L BW S362
520 whp//414 ft lbs- Mustang Dyno
track #s soon
11secdsm is offline   Reply With Quote
Old 12-28-2006, 12:34 AM   #22
DSMonster
DSMtalker
DSMonster's Avatar
1998 TSi AWD
Trader Rating: (2)
DSMonster's Gallery
when the car is running agian we need a "driveabliliy" review.
Old 01-01-2007, 05:30 PM   #23
1slocolt
1989 Dodge Colt Turbo
Trader Rating: (0)
1slocolt's Gallery
Originally Posted by maximumbob
The slave cylinder is part number cs12247 from partsamerica. They are affiliated with advance auto parts who sells it local to me for 29$ and no shipping charges. Just fyi for anyone looking to get the clutch.
Bob
That is the part number for the tru torque Isuzu slave, and it will run people $37.77. I am the initial finder of that slave for twin disk purposes. I was asked to find a larger bore slave than the stock 13/16" 2g slave to reduce clutch fork movement. 1g cars will not want to run the Isuzu slave cylinder because they already have shorter throws than 2g cars. Most 1g cars run the 3/4" bore slave, in which case if you did want less clutch movement for a given amount of pedal movement then you can go with a FWD turbo slave, which is 13/16" bore. I even found that slave to be a bit large on 1st gen AWD cars but it will work, you just may not have to run a pedal stop, which some people may prefer. In order to run the trooper slave you will have to modify it by grinding the ears off and drilling new bolt holes, but for 2g owners it seems well worth it.
The same guy who designed the PTT designed the Quartermaster. Victor's organic disks were unable to hold the 500ft/lbs he was making on the dyno, though I believe PTT fixed that problem. Is that correct Victor?
1slocolt is offline   Reply With Quote
Old 01-01-2007, 06:58 PM   #24
DR.Spock
Ultra DSMtalker
DR.Spock's Avatar
95 6-bolt Talon AWD
Trader Rating: (0)
DR.Spock's Gallery
Nice man, thanks for the reveiw, I will definatly look into gettin one for my next clutch when my 2600 burns out.
one questions, is it possible to buy just the ring gear from Satan? since im running a fidanza and i will most likely sell it when i pick this clutch up.
"You just got killed by a Daewoo Lanos MUTHAF**KA!!"
DR.Spock is offline   Reply With Quote
Old 01-01-2007, 08:40 PM   #25
GAstroker
DSMtalker
GAstroker's Avatar
eclipse,gsx,97
Trader Rating: (3)
GAstroker's Gallery
Yees you can order the ring gear separately thru the dealer.
Mike
8.8 @ 165mph
Old 01-02-2007, 08:30 AM   #26
nukefission
Honorary Administrator
nukefission's Avatar
1991 Eclipse GSX
Trader Rating: (1)
nukefission's Gallery
The ring gear is around $30 from JNZ.
Yeah, the way I had it set up with the organic discs wasn't enough for the power I ended up making (627hp/505tq). I will be sending the clutch back to PTT to get the discs upgraded to the ferametallics and the pressure plate upgraded to their "high-torque" version which supposedly is good for 150ft-lb more than the original. Driveability will be affected somewhat, but it's so easy to drive with this clutch anyway I'm not too worried about it.
-Victor
'91 GSX
'91 GVR4 76/2000
'02 VW Golf TDI
PM'ing me about forum business in which I am no longer involved may result in your premature death.
nukefission is offline   Reply With Quote
Old 01-02-2007, 09:41 AM   #27
DR.Spock
Ultra DSMtalker
DR.Spock's Avatar
95 6-bolt Talon AWD
Trader Rating: (0)
DR.Spock's Gallery
Nice, so what discs and pressure plate would you reccomend for a set-up like mine?
2.3L stroker
FP3052
meth injection
my goal is 500HP at least.
could I stick with the organic disks? the stock pressure plate?
Thanks
Old 01-02-2007, 12:50 PM   #28
nukefission
1991 Eclipse GSX
Trader Rating: (1)
You may as well get the metallic discs and high-torque pressure plate. I'm not sure how much more expensive it is to get the clutch with those components vs. the regular stuff. Probably not much, if at all.
-Victor
'91 GSX
'91 GVR4 76/2000
'02 VW Golf TDI
Old 01-14-2007, 02:09 PM   #29
DR.Spock
Ultra DSMtalker
DR.Spock's Avatar
95 6-bolt Talon AWD
Trader Rating: (0)
DR.Spock's Gallery
just ordered my PTT twin disc clutch
Old 01-14-2007, 02:57 PM   #30
97gstbabe
Hardcore DSMtalker
97gstbabe's Avatar
97 Misubishi Eclipse
Trader Rating: (7)
97gstbabe's Gallery
How is it for noise? I hear bad things about it being incredibly noisy....
I'm ordering this clutch next week after I get paid....Maybe by the end of the week if I have enough....
Low Boost, Race Gas
96 GSX Auto 10.16 @ 125
04 SRT-4 13.9 @ 100
97gstbabe is online now   Reply With Quote
vB code is On
Powered by vBulletin®
