I bought a 1g head, how can I tell if it's a 6 bolt or not? - DSM Forums: Mitsubishi Eclipse, Plymouth Laser, and Eagle Talon Forum: DSMtalk.com
» Wheel & Tire Center
Old 12-05-2006, 09:29 AM   #1
maximuspaynimus
1995 Talon Tsi AWD
maximuspaynimus's Gallery
Exactly what the title says. I bought a 1g head a while back, and that was back when I never thought to ask if it was a 6 or 7 bolt. It supposedly came off of a 1993 tsi awd manual trans. I havent been able to find anywhere how to tell the difference...
maximuspaynimus is offline   Reply With Quote
Old 12-05-2006, 10:06 AM   #2
4g64fiero
Ridiculous DSMtalker
4g64fiero's Avatar
1997 gs-t stock
4g64fiero's Gallery
Feedback Score: 27 reviews
Re: I bought a 1g head, how can I tell if it's a 6 bolt or not?
If it came off of 93 then it *most likely* is a head off of a 7 bolt block.
Why do you care anyways?
Evos are gay.
4g64fiero is offline   Reply With Quote
Old 12-05-2006, 10:30 AM   #3
maximuspaynimus
1995 Talon Tsi AWD
I dont really care. But I was thinking of sometime down the road doing a 6 bolt swap after I blow this 7 bolt I have. It has 97k on it.
Old 12-05-2006, 10:36 AM   #4
Turboeagletalon
Super DSMtalker
Turboeagletalon's Avatar
mitsubishi/eclipse/95
Turboeagletalon's Gallery
any pre 95 head say 89-94 dsm 2.0L heads are all the same unless its a turbo or non- turbo. then the only diffrence is the cams
1995 Eclipse GSX
She brakes all four tires loose, and slides sideways on dry pavement.
And I give people whip lash.
Turboeagletalon is offline   Reply With Quote
Old 12-05-2006, 10:41 AM   #5
4g64fiero
4g64fiero's Avatar
1997 gs-t stock
4g64fiero's Gallery
Right, and the only differance with the cams is between the A/t models and the M/T. It actually has nothing to do with turbo or not.
Evos are gay.
Old 12-05-2006, 11:26 AM   #6
spooling_high
Hardcore DSMtalker
spooling_high's Avatar
1990 eclipse gsx
spooling_high's Gallery
Feedback Score: 6 reviews
The only thing that you have to worry about is what the guys said above. If it is a AT head, then you dont want it if you have a MT car. So other then that, dont worry about it being 6 or 7 bolt.
1990 GSX
Mods so far.... RRE 3" DP, RRE High Flow Cat, Apexi Cat Back, Apexi Turbo Timer, SAFC II, Tubular O2 Housing w/ external dump, hacked can, autometer boost and oil pressure.
spooling_high is offline   Reply With Quote
Old 12-05-2006, 11:44 AM   #7
T_K
Hardcore DSMtalker
T_K's Avatar
2003 BMW 530i
T_K's Gallery
Feedback Score: 11 reviews
I thought there was a difference in the head studs between 6 and 7-bolts?
03 530i
93 TSI AWD - sold
T_K is offline   Reply With Quote
Old 12-05-2006, 12:06 PM   #8
EclipseRST
Hardcore DSMtalker
95 TSI AWD
EclipseRST's Gallery
There is... 6 Bolt motors have larger head studs. So If you cant easily fit a 6 bolt head stud through one of the holes, then you know what block the head came off of.
Jake
95 AWD Talon
GT42r
Supporting mods.
EclipseRST is offline   Reply With Quote
Old 12-05-2006, 12:14 PM   #9
T_K
Hardcore DSMtalker
T_K's Avatar
2003 BMW 530i
T_K's Gallery
So what do you do if you want to put a 7-bolt 1G head on a 6-bolt motor? Drill it? And vice-versa, if you want to put a 6-bolt head on a 7-bolt 1G motor doesn't the smaller size of the studs give problems?
03 530i
93 TSI AWD - sold
Old 12-05-2006, 12:53 PM   #10
EclipseRST
Hardcore DSMtalker
95 TSI AWD
To put a 7 bolt head on a 6 bolt block, the correct way is to drill it. Some people say it is ok to just push the studs through the head but honestly I dont want little metal shavings floating in my oil from the stud having to push through the metal. Its not about what you can get away with, its about doing it the right way the first time.
To put a 6 bolt head on a 7 bolt block is different. The block has dowl pins that hold the head in place, so using the smaller head studs doesnt hurt anything.
Jake
95 AWD Talon
GT42r
Supporting mods.
Old 12-05-2006, 01:39 PM   #11
1gawd4g63
Ultra DSMtalker
1gawd4g63's Avatar
91 eagle talon tsi awd
1gawd4g63's Gallery
Feedback Score: 4 reviews
You guys are confused with 1g to 2g stuff. All 1g's have the same exact head, and the head bolt holes are the same also.
1gawd4g63 is offline   Reply With Quote
Old 12-05-2006, 03:05 PM   #12
seefour
93 Eagle Talon TSi AWD
seefour's Gallery
No, 1g 6-bolt heads have 12mm headstuds, while 7-bolts have 11mm headstuds.
seefour is offline   Reply With Quote
Old 12-05-2006, 04:19 PM   #13
punisher
Ultra DSMtalker
punisher's Avatar
1992 TSI AWD/1991 GSX
punisher's Gallery
Feedback Score: 13 reviews
All 1g's (except 1.8's) use the same head, it doesn't matter whether its a non-turbo, turbo, 6 bolt or 7 bolt, all have identical heads. The cams are the only difference.
2g's use the redesigned head with smaller head studs.
Do a search if you don't believe me. Even look at various vendors pages, ever notice how when they sell heads they will only ask if its a 1g or a 2g.
punisher is offline   Reply With Quote
Old 12-05-2006, 07:18 PM   #14
JaxTalonTurbo
90' Talon TSi AWD
JaxTalonTurbo's Gallery
Feedback Score: 1 reviews
Wow. I thought this shit was common knowlege.
As far as cylinder head port sizes and how the head flows, 90-94 4G63 NA, and 90-94 turbo are IDENTICAL. The difference between 6 bolt and 1g 7bolt heads are the headstud sizes, 12mm on the 6 bolt and 11mm on the 7bolt. The 7 bolt head can be drilled over 1mm in those holes to accomodate the 6 bolt studs/bolts.
NA 4G63 heads have different valvetrain parts including cams and valvesprings. So if you use one of those, make sure when it is assembled it is assembled with turbo valvetrain. As far as the different cam profiles between the auto and the manual tranny, I doubt that it's noticable with regular bolt ons, but who gives a fuck anyhow, just swap out the cams.
JaxTalonTurbo is offline   Reply With Quote
Old 12-05-2006, 07:27 PM   #15
seefour
seefour's Gallery
Thank you for helping stop the spread of bad information. I can't believe someone can have over 300 posts and not know common things such as this.
