How to check ECU on 1G FWD turbo auto.... - DSM Forums: Mitsubishi Eclipse, Plymouth Laser, and Eagle Talon Forum: DSMtalk.com
» Wheel & Tire Center
Closed Thread
Old 01-21-2007, 02:51 PM   #1
andrewdees
1992 Lexus SC400
andrewdees's Gallery
Hey guys, Im trying to get my sisters 1G FWD Turbo Automatic to start. Ive tried replacing the coil and transistor, and still it wont get any spark. The last thing to check is the ECU, however I dont another ECU to throw in, so what im wondering is - is there any way to check the ECU?? Thanks
-Drew
andrewdees is offline
Old 01-21-2007, 05:59 PM   #2
RobSterKraw
Hardcore DSMtalker
RobSterKraw's Avatar
92 Eagle Talon TSi AWD
RobSterKraw's Gallery
Feedback Score: 13 reviews
Re: How to check ECU on 1G FWD turbo auto....
You can pull it out and check for cap leakage. If it looks like this or smells like nasty garbage/fish then its probably bad.
Kinda hard to check it other than visual tho.
Harv
1992 Eagle Talon TSi AWD 5spd
RobSterKraw is offline
Old 01-21-2007, 08:56 PM   #3
larc
Hardcore DSMtalker
larc's Avatar
larc's Gallery
Only way other than visually inspecting it, is to find another car to throw it into.
Although leaky transistors plague our ECU's so hopefully you'll be able to see it right off the bat.
90' Eclipse - evo16g setup, all supporting mods - R.I.P.
89' CSM - AWD Swap, 4G63T Swap, Evo16g, 650's, Link, and supporting mods. Best 1/4 is 12.4 secs. Aiming for <12.
larc is offline
Old 01-22-2007, 07:52 AM   #4
andrewdees
1992 Lexus SC400
Okay I pulled off the cover and everything looks OK. No bad smells or anything that looks like it was leaking. What else would cause the car not to get spark and fuel? Thanks
-drew
Old 01-22-2007, 11:05 AM   #5
larc
Hardcore DSMtalker
larc's Avatar
larc's Gallery
I would start with a search. There will be many many threads that will be able to help you.
larc is offline
Old 01-22-2007, 11:47 AM   #6
QuasiMondo
Hardcore DSMtalker
QuasiMondo's Avatar
91 Galant VR-4
QuasiMondo's Gallery
Feedback Score: 1 reviews
When you turn the key to the ON position does the CEL stay active for five seconds before it clears away? No CEL means the ecu isn't turning on. If the ecu is fine like you said, check the MPI relay, that's what controls power to the ECU. I don't have any wiring diagrams with me, so I can't tell you the wiring diagram, but I do know the ecu wiring is in the Chilton's manual, which you should get if you don't have one already.
QuasiMondo is offline
Old 01-22-2007, 03:27 PM   #7
andrewdees
1992 Lexus SC400
Okay does anyone know where that realy is at? I have heard that is the fuel pump relay is bad, then it wont get fuel or spark. Thanks
-Drew
Old 01-22-2007, 03:45 PM   #8
andrewdees
1992 Lexus SC400
**UPDATE**
Okay I turn the key to ON and the CEL isnt on at all. So this means that the ECU isnt getting power?
-Drew
Old 01-22-2007, 03:52 PM   #9
93talon06
DSMtalker
93talon06's Avatar
eagle talon 1993
93talon06's Gallery
Feedback Score: 7 reviews
The fuel pump relay is sitting right in front of the ecu and right below the radio,its a big relay you cant miss it.Oh you might also want check the cas.
93talon06 is offline
Old 01-27-2013, 03:39 PM   #10
TheBrain
92 Talon Tsi
TheBrain's Gallery
QuasiMondo. Thank you for the tip on the CEL light not coming on! I was having the same problem of parking the car then a couple months later, no spark. I was going to test everything else before the ECU. I checked the CEL and it did not come on. Pulled the ECU and had cap puke all over.
Thanks!
TheBrain is offline
Old 01-27-2013, 03:41 PM   #11
Sean485
Senior Moderator
Sean485's Avatar
99 Spyder "GSX"
Sean485's Gallery
While we appreciate people using the search function, and I am glad the post helped you out please dont necro 5 year old threads
99 Spyder "GSX"
Sean Clancy
Sean485 is offline
Closed Thread
