Water noise under dash??? - DSM Forums: Mitsubishi Eclipse, Plymouth Laser, and Eagle Talon Forum: DSMtalk.com
Wheel & Tire Center
Go Back   DSM Forums: Mitsubishi Eclipse, Plymouth Laser, and Eagle Talon Forum: DSMtalk.com > DSM Tech Central > Non Turbo Tech
Notices
Old 02-09-2007, 07:17 PM   #1
99slvrs
99slvrs's Avatar
99 eclipse GS-T-sold
99slvrs's Gallery
O.K I did a search for this but was not happy with what I found. Basically im getting water noises under my dash. It usally happens in the mornings but its been happening a lot also whenever I turn the car on. I remember changing my thermostat last winter because I had the same problem and it went away. So has anyone else had this problem recently? I will probably change out the thermostat again anyway but I just want to be sure its not something else before I do. Any suggestions would be appreciated!
99slvrs is offline   Reply With Quote
Old 02-09-2007, 08:28 PM   #2
11secdsm
11secdsm's Avatar
91 GSX
11secdsm's Gallery
Feedback Score: 33 reviews
Re: Water noise under dash???
What does a water noise sound like? Sloshing, bubbles? Your heater core is under your dash so it's probably related to that.
-Chris
9.14@151
9.40@154
9.50@120
Wiseco HD 10.5:1, R&R rod, CBRE head, Kelford 280, FP Super99, Magnafuel 4301, FIC 2150s , built auto, Bradco converter, JMF int/exh manifolds, FMIC, piping, Link v3 w/ SD, KP Tuned
11secdsm is offline   Reply With Quote
Old 02-09-2007, 08:40 PM   #3
mach.80
mach.80's Avatar
93 Talon TSI
mach.80's Gallery
My wife has the same problem. I tried burping her cooling system to no avail.
The noise does sound like a small waterfall under your dash a babbling brook of some sorts. any ideas I might try the thermostat.
mach.80 is offline   Reply With Quote
Old 02-09-2007, 08:42 PM   #4
1gawd4g63
Ultra DSMtalker
1gawd4g63's Avatar
91 eagle talon tsi awd
1gawd4g63's Gallery
Feedback Score: 4 reviews
you guys probably have too much water in your coolant, i have had cars do this before, and it was always from slushy coolant going thru the heater core. Look into this, i would bet this is your problem.
1gawd4g63 is offline   Reply With Quote
Old 02-09-2007, 08:50 PM   #5
mach.80
mach.80's Avatar
93 Talon TSI
mach.80's Gallery
50/50 mix on a motor rebuilt 15k ago and new radiator.. ..everything.
Old 02-09-2007, 08:57 PM   #6
1gawd4g63
Ultra DSMtalker
1gawd4g63's Avatar
1gawd4g63's Gallery
50/50 isn't the correct ratio for a cold area, more like 70/30 is probably what you need if you are still having the issue. That is what everyone should run in the wintertime, it says so on the coolant jug.
Old 02-09-2007, 09:00 PM   #7
11secdsm
11secdsm's Avatar
91 GSX
11secdsm's Gallery
He lives in Houston according to his info...doesn't exactly get cold there. But I would agree with you otherwise.
-Chris
9.14@151
9.40@154
9.50@120
Old 02-10-2007, 04:39 PM   #8
99slvrs
99slvrs's Avatar
99slvrs's Gallery
Well the water noise sounds like a trickle then sloshing when I apply the gas pedal. I talked to a mechanic and he said its a common problem with chrysler motors. But thanks for replying guys, I will probably do a system flush soon and be sure to add 70/30 mixture.
Old 02-16-2007, 05:23 PM   #9
DR1665
97 2GNT | 91 GVR4
DR1665's Gallery
Low coolant level.
Most common causes:
A Dried-out radiator cap
B Hose in overflow bottle falls off bottom of cap
Solution A:
- Buy radiator cap.
- Buy jug of premix coolant.
- Remove old radiator cap.
- Start engine.
- Turn heater to full heat, medium fan speed.
- Add coolant as needed.
- Wait for engine to get up to operating temperature.
- When thermostat opens, continue to add coolant as needed (no bubbles).
- Install new radiator cap.
Solution B:
- Remove overflow bottle cap.
- Verify hose on bottom of cap.
- If hose is missing, install new hose.
- See Solution A. You're still low on coolant.
DR1665 is offline   Reply With Quote
Old 02-16-2007, 05:32 PM   #10
1timehondalover
Hardcore DSMtalker
1timehondalover's Avatar
93 Eagle TSi AWD
1timehondalover's Gallery
Feedback Score: 11 reviews
You can also try and raise the front of the car off of the ground. This helps the bubbles in your system reach the filler neck. You might try to rent a vacuum powered coolant fill tool somewhere. I paid $200 for my Snap-On, and is worth every last dime. Go try a drain and fill on a 2000'ish Celica if you want to see why these are helpful. http://buy1.snapon.com/catalog/item....store&tool=all
1993 Talon AWD : Mahle-Manley 6 bolt 2.0 / MLS hg / HX35 12cm T3 / JMF Race SMIM / Crower 272's / FIC 1050's / DSMLink / 2g MAS / Supra TT pump / Punishment Racing FMIC and radiator / ShepTrans Stg. 3 / RPS Max PP and ACT solid disc / 3" turbo back exhaust / interior stripped and 6 pointed :
1997 Eclipse GSX : DD Status :
1timehondalover is offline   Reply With Quote
Old 02-25-2007, 09:00 AM   #11
RiseoftheEclips
DSMtalker
RiseoftheEclips's Avatar
RiseoftheEclips's Gallery
Is it fixed? Yea do a system flush and get that old sh!t out of there and put some new fluid in. Should help.
RiseoftheEclips is offline   Reply With Quote
Old 02-25-2007, 09:40 AM   #12
ROAD RACE VR-4
Hardcore DSMtalker
ROAD RACE VR-4's Avatar
public transportation
ROAD RACE VR-4's Gallery
Feedback Score: 1 reviews
I've noticed this problem with my work van (2005 chrysler town&country).
I've been hearing that water noise under the dash since we picked it up from the dealer lot. I took it to my friends shop and had the coolant flushed twice and its still doing it now and the car has almost 40k miles on it.
my galant does it sometimes too. everything has been changed and there are no air bubbles in the system.
91 Galant VR-4 1759/2000...sold
91 Eclipse GS-X...sold
93 Civic DX...sold
ROAD RACE VR-4 is offline   Reply With Quote
Old 03-22-2007, 09:54 PM   #13
LkyblK
DSMtalker
LkyblK's Avatar
94 Eclipse GS(t)
LkyblK's Gallery
check for loose buckets of water hidden throughout the car
LkyblK is offline   Reply With Quote
Old 03-22-2007, 10:03 PM   #14
mitz19
mitz19's Avatar
1998 Mitsubishi Eclipse
mitz19's Gallery
hahaha.... yea i got the same problem. i hear it every time i turn on the car. is it possible that it could be the heater hose?
mitz19 is offline   Reply With Quote
Old 03-23-2007, 12:23 PM   #15
rush6432
DSMtalker
92 Eclipse GS-T
rush6432's Gallery
Feedback Score: 3 reviews
Does the carpet ever get wet on the passenger side????
check the evaporator case from the ac system under the dash, if the tray gets clogged where all the condensation dripss off and out of the car it can make the same noises your talking about.
rush6432 is offline   Reply With Quote
