1st gear pops out.... - DSM Forums: Mitsubishi Eclipse, Plymouth Laser, and Eagle Talon Forum: DSMtalk.com
Wheel & Tire Center
Notices
Old 04-26-2007, 02:30 AM   #1
nahtanoj
Eagle Talon 90
nahtanoj's Gallery
my tranny is starting to pop out of gear (only in 1st) when you are on a dead stop ready to go, it does this occasionally, any info would be great...
nahtanoj is offline   Reply With Quote
Old 04-26-2007, 02:37 AM   #2
1gawd4g63
Ultra DSMtalker
1gawd4g63's Avatar
91 eagle talon tsi awd
1gawd4g63's Gallery
Feedback Score: 4 reviews
Re: 1st gear pops out....
try adjusting the cables, if that doesn't work look for obstructions around the linkage. If still nothing than you have a bad bearing on the end of the intermediate shaft or a bad slider/dogs
1gawd4g63 is offline   Reply With Quote
Old 04-26-2007, 08:57 AM   #3
quazz209
Ultra DSMtalker
quazz209's Avatar
1996 Eclipse GSX
quazz209's Gallery
Feedback Score: 9 reviews
I have also heard of worn/old poppet balls and springs no longer holding the shifter into gear. Easy thing to check out. After the cables and linkages of course.
quazz209 is offline   Reply With Quote
Old 04-26-2007, 10:41 PM   #4
nahtanoj
Eagle Talon 90
nahtanoj's Gallery
thanks, will check out the cables and adjust the linkage at the shifter and see how things are....
my c/master is not leaking, slave still looks good...
Old 04-26-2007, 10:48 PM   #5
nahtanoj
Eagle Talon 90
nahtanoj's Gallery
can you clarify where i can check this, thanks
Old 04-27-2007, 01:11 AM   #6
1gawd4g63
Ultra DSMtalker
1gawd4g63's Avatar
1gawd4g63's Gallery
that doesn't hold it in gear persay.
Old 04-27-2007, 07:05 AM   #7
Piranha451
Piranha451's Avatar
'97 Eclipse Spyder GS-T
Piranha451's Gallery
Feedback Score: 5 reviews
Mine will pop out of first if I am going along slowly. For example, if a light is about to turn green and I do not want to come to a full stop. If I apply constant pressure to the shifter it still try but goes right back without being able to pop out. I figured my syncros are/getting worn out. Could a misadjusted cable cause that?
Piranha451 is offline   Reply With Quote
Old 04-27-2007, 07:12 PM   #8
1gawd4g63
Ultra DSMtalker
1gawd4g63's Avatar
1gawd4g63's Gallery
syncro's have nothing to do with holding the gear in. at all, don't think they do because they don't, it is just a brake to slow down the gear for a smoothe shift
Old 04-27-2007, 10:16 PM   #9
turbofonz
Super DSMtalker
turbofonz's Avatar
91 Eagle Talon TSi AWD
turbofonz's Gallery
Can you shift fast into 2nd? I've had that happen on 2 different trannys. i suspect broken/bent shift fork.
91 TSi AWD - 11.06@123.1mph - evo3 e85
11.11@127.8 - 2010 DSM Shootout DST winner
11.6@119mph - pumpgas
352 awhp evoIII 93 octane
92 Galant VR-4 - 255/1000
turbofonz is offline   Reply With Quote
Old 04-27-2007, 11:58 PM   #10
NoidGST
97Mitsubishi EclipseGST
NoidGST's Gallery
Had the same problem with my 95AWD. It ended up being a bad end bearing on the imtermediate shaft so i just replaced them both.
NoidGST is offline   Reply With Quote
Old 04-28-2007, 12:04 AM   #11
97wwr1915
DSMtalker
97wwr1915's Avatar
97 GST
97wwr1915's Gallery
My GST does this every now and then but I think it may be due to having a short-shifter and me just being to lazy to make sure its in all the way before moving...
97wwr1915 is offline   Reply With Quote
Old 04-28-2007, 02:35 PM   #12
nahtanoj
Eagle Talon 90
nahtanoj's Gallery
adjusted the shifter cables, the c/ master cylinder rod is almost coming out of the pedal(all the way to the end) bled properly, pump 10 times and hold, slave bleeds open then closed before release of pedal and repeat several times...
thinking about getting the extended slave rod..... new master.... and new slave.... before i pull the tranny to check the fork if it is bent.
for now it is also starting to grind when i put it in first gear and occasional
2nd gear, btw it also has very low engagement, about half to an inch off the floor...
thanks
Old 04-28-2007, 03:56 PM   #13
quazz209
Ultra DSMtalker
quazz209's Avatar
1996 Eclipse GSX
quazz209's Gallery
I would try to solve that engagment problem first and then tackle any issues that remain. It sounds like you have all of your bases covered for getting the engagement back off the floor. That is as long as your fork isnt bent. Remember to check your pedal assembly for play as well.
Old 04-28-2007, 04:53 PM   #14
1gawd4g63
Ultra DSMtalker
1gawd4g63's Avatar
1gawd4g63's Gallery
if it won't stay in gear it has nothing to do with master adjustment or a bent clutch fork, that would just have to do with enguagement. This problem is more than likely internal inside the tranny.
Old 04-28-2007, 04:59 PM   #15
quazz209
Ultra DSMtalker
quazz209's Avatar
1996 Eclipse GSX
quazz209's Gallery
I agree that it most likely a transmission related problem. However with the amount of issues he has going on it will be easier to elimnate them one at a time. Otherwise its like trying to hit a moving target. The engagement issue is much easier to address first, thereby isolating his transmission problems.
