Red 5 speed 1992 Eagle Talon TSI AWD
Excellent shape red exterior (no rust – no dents) with excellent shape gray cloth interior. 5 speed AWD turbo. Excellent compression 160 across board -- 136K miles – 6 bolt block – 4 bolt rear end – Low mileage replacement 14B turbo. and almost new (less than 500 miles) ACT 2100 clutch -- new throw out bearing.
Maintance and modifications which I just did:
Brand new timing belt tensioner & waterpump–
Timing belt & pulley’s and balance shaft belt & balance shaft tensioner with less
than 5K miles on them.
New NGK 7’s sparkplugs – almost new Bosch wires – -- new pcv valve –
New 180 degree thermostat -- new coolant –Almost new all accessory belts.
Brand new oil change and filter – new synthetic gear oil fluids in transfer case and rear
diff. New BG syncroshift in transmission.
Almost new brake pads on front brakes – new rear rotors and one new rear caliper –
new rear brake pads. Almost new Radiator.
2 almost new front axles.
New outer tie rod end.
Almost new 2G exhaust manifold
Modified 1G MAF with brand new K&N filter
Almost new ACT 21200 clutch -- Shifter cables adjusted. – Shifter arms from
transmission disassembled and cleaned. –
Mint shape 92 - 16” Talon rims with almost new all season tires.
New Autometer boost gauge – New manual boost controller
Re-wired fuel pump
Kenwood aftermarket stereo with 400 amp power booster
Almost new battery
2G shifter knob
Brand New Apex'i N1 downpipe back exhaust
brand new greddy rs BOV
Asking $5,200 o.b.o
Check it out on Craig's list
http://boston.craigslist.org/bmw/car/371129200.html
Contact greg mcnally
978-420-7376
McNallyg84@yahoo.com
