Originally Posted by Revolution
Do you have any specs on the car or mod list? Have you had any problems with the rearends? Nice looking car and great passes!
No rear or transfer case problems yet, im sure the slow launches and 4 spider center diff are helping save the rear
Car has since gone 10.16 @ 146.23mph on BFG's ( 1.797 60 ft )
http://videos.streetfire.net/video/4...7b000d4f7a.htm
mods list is currently changing
mods as of last run, built 2.0, borg warner s366 turbo, SFP T4 manifold, FRH intake, SBR head, crower 64414 cams, 1600cc injectors, magnafuel fuel pump, E85 fuel, AEM EMS, trans from Jacks transmission ( 4 spider diff ), QM twin disk, ect..... race weight 3050-3100 with driver
new mods being installed now,
S372 turbo ( old was maxed out @ 700+whp ), large ram air setup to feed turbo, new larger 4" thick FMIC ( old was 3.5 thick ), new larger 3 inch intercooler piping ( old was 2.5 inch ), Q45 90mm throttle body ( old was 62mm ), new wheels and hoosier QTP's ( 60lb weight savings and better traction ), smaller battery ( 30+lb weight savings ), gas tank removal and 3 gal fuel cell install up front ( 50+ lb weight savings )
Next time out, car should be solidly in the 9's on E85 "pump gas" even with another crappy 1.797 60ft
