So why the hell did battery acid spray everything under my hood?
Sup guys, I justr put in a BRAND new battery today and terminals and has replaced my alternator about a month ago.
I drove the car around today on a hot day for about 2 hours applying for jobs so it was alot of driving..and it ran just fine. I park the car at my house and pop the hood to let it cool down a bit faster and I notice...WTF this cap from my battery is completely blown off and there is acid sprayed all over the top of the hood (Not a stupid amount but you can see where it ate the paint).
*This isnt my actual battery but one of those caps that say "danger poison etc" was blown off and I found it in the engine bay. I have no clue how long I was driving it liek this BUT WHAT THE HELL IS GOING ON HERE!, car was running fine and had no voltage issues going on. I did notice my windows were rolling up extra fast , but AHHH What the hell.
I wiped up most of the acid with somewater and there is minimal damage but still help!!
__________________ White/Black 91' TSi AWD-|" BB76mm Custom exhaust system". Red/Black 90' TSi AWD..R.I.P/SOLD. 2008 Kawasaki Ninja ZX-6R 1995 Ram 2500 12V Cummins Diesel, pulling out tree stumps near you.
Re: So why the hell did battery acid spray everything under my hood?
My alternator was overcharging my Optima red top, at 17 volts.
The SEALED Optima red top starting spraying out acid from where the grey plastic meets the red plastic....it discolored some paint right by the battery.
Originally Posted by Sean485
Faulty voltage regulator. Requires replacement/rebuild of the alternator.
Yea either check voltage at the battery while you rev. My old Probe had the regulator go bad and it had a volt meter on the dash. At anything less than 3k rpm it would read normal. After that it would go up to 18v, then things started turning off; the radio, the dash lights. Once you would bring the revs back down everything would come back on. (Oh yea, wear safety glasses and a long sleeve shirt while you do this, just in case it blows again )
Or take the alt. out and go to the 'Zone and get 'er tested.
Bryan
1997 Talon AWD 1987 Yamaha Radian
1980 Rabbit - Road racer 1993 F250 - car hauler
Bronco Motorsports at WMU
There is a good posibility that your alternator is over charging. I once saw a VW Jetta that was over charging and the battery semi-exploded and covered the engine bay with acid. I also had a Merc Grand Marquis that was over charging that fried the ecu, ip cluster, and the radio. I would get the alt tested for correct output, voltage and amperage.
Okay I just turned it on and in less than a minute I witnessed the other cap BLOW off and liek shot itself out of the engine bay. Im going to go get a multimeter..FUCKKKK
step 1. pull alternator
step 2. have it tested
step 3. buy new alternator or battery.
