Fuel pump wiring straight from battery??? - DSM Forums: Mitsubishi Eclipse, Plymouth Laser, and Eagle Talon Forum: DSMtalk.com
Wheel & Tire Center
Go Back   DSM Forums: Mitsubishi Eclipse, Plymouth Laser, and Eagle Talon Forum: DSMtalk.com > DSM Tech Central > Electronics Tech
Notices
Old 10-28-2007, 12:58 PM   #1
stockfornow
1G Talon TSI AWD
stockfornow's Gallery
Lightbulb Fuel pump wiring straight from battery???
I was wondering if it's possible to wire the positive wire for a fuel pump straight from the battery? Wire connects to the "+" of battery then has 30A fuse (or whatever you suggest), then on/off switch (to manually activate it) and then the wire goes straight to the black and white wire on the fuel pump. Yes, I'll be using thicker wires, my question is do you think this would work? Would I need another fuse after the switch or a a bigger one and etc.
Thanks for all the comments.
In case you're wondering why I want to do this rather than just a regular fuel pump rewire thing, one less relay, and against theft.
stockfornow is offline   Reply With Quote
Old 10-28-2007, 04:09 PM   #2
4g63tcrazy
Ultra DSMtalker
4g63tcrazy's Avatar
91 Talon TSI FWD
4g63tcrazy's Gallery
Feedback Score: 9 reviews
Re: Fuel pump wiring straight from battery???
I don't see why that wouldn't work. Just don't forget to switch it on when you go to start the car and think something is wrong with it! Lol, I know I would do something stupid like that.
91 Talon FWD - gt3076r on E85 - 75k original miles
90 Colt GT - 4g63 swapped - Daily driver
4g63tcrazy is offline   Reply With Quote
Old 10-28-2007, 05:50 PM   #3
EyelineredEyes
DSMtalker
EyelineredEyes's Avatar
Plymouth/Laser/1993
EyelineredEyes's Gallery
I was just about to ask that question. Smart! I like your thinking!
EyelineredEyes is offline   Reply With Quote
Old 10-28-2007, 06:14 PM   #4
stockfornow
1G Talon TSI AWD
Thanks for replying guys!!! So, I can use the 30A fuse, and not worry about blowing that, since I think that's what the regular fuel pump rewiring uses...
I'm usually on dsmtuners.com but I will post pics in "Lounge" once I'm done with my car. Check back in a month. It should be a blast 2.3 with BC280 cams= idles like a V8, still need a couple things like IC piping, etc.
Old 10-28-2007, 09:46 PM   #5
halucinator
Super DSMtalker
halucinator's Avatar
'91 Eagle Talon TSI AWD
halucinator's Gallery
Feedback Score: 7 reviews
Just make sure your running a switch that can handle the electrical load of a fuel pump.
halucinator is offline   Reply With Quote
Old 10-29-2007, 01:57 PM   #6
parttime
parttime's Gallery
Or use an automotive relay.
someone brought this same idea up in an anti theft alternative thread i think...
parttime is offline   Reply With Quote
Old 10-29-2007, 11:06 PM   #7
maui6651
Hardcore DSMtalker
98 GSX A/T
maui6651's Gallery
The cleaner option is to just do a standard rewire and use the relay. What's better about finding a high load switch that has to be mounted in the dash area as opposed to a relay hidden next to the pump? If you want the ability to switch the pump on and off, run a seperate (low load) wire to the relay instead of using the stock trigger.
EvoIII :: DSMLink :: FMIC :: Supporting Mods
New Transmission :: Cooler :: Shift Kit :: TCUGo :: 3g shifter
maui6651 is offline   Reply With Quote
Old 10-30-2007, 05:27 PM   #8
stockfornow
1G Talon TSI AWD
Good one! I think I can actually use the relay from ABS unit that I removed. So, I'll just run a low load wire to the relay (with switch in it), got it. Thanks.
Another reason for this would be, that I can fill the fuel rail with gas, and then crank the car, since I removed the solenoids, and running a DSMLink... The fuel pump starts working once the engine is cranking, rather than when the key is in "ON" position(with solenoids). DD/winter car, I hope this makes some sense.
Old 10-31-2007, 12:54 PM   #9
RippinGSX
Honorary Moderator
RippinGSX's Avatar
1993 Eclipse GSX
RippinGSX's Gallery
Feedback Score: 2 reviews
The rewire is the same thing he is asking here. Just get a relay and do it.
RippinGSX is offline   Reply With Quote
Old 10-31-2007, 04:27 PM   #10
Luni420
Super DSMtalker
1991 Toyota MR2 Turbo
Luni420's Gallery
If youre asking about wiring in a switch, the switch IS a relay. Its the same amount of work to install a switch as it does a relay. You could make it a hidden switch only you knew where it was located, but ultimately, who would want to steal one of our POS DSMs anyway? (I keed I keed)
But yeah, same exact process as a relay. The switch IS a relay of sorts anyway.
The Weapons: 1993 Talon TSI AWD
Luni420 is offline   Reply With Quote
Old 10-31-2007, 07:21 PM   #11
stockfornow
1G Talon TSI AWD
Here's a link, I just made posted a quick pic/diagram there.
http://www.dsm-power.hotmail.ru/
"RippingGSX" Where did you get that intake manifold, any close-up pics? PM me about it. Thanks.
Old 10-31-2007, 11:12 PM   #12
Luni420
Super DSMtalker
Luni420's Gallery
I clicked on that link and my security software came up with an HTML Exploit warning.
Old 11-01-2007, 04:51 PM   #13
stockfornow
1G Talon TSI AWD
Ok, I just forgot how write websites in HTML code.... Anyway try here:
http://www.dsm-power.hotmail.ru/fuel_pump_rewire.bmp
Old 11-03-2007, 10:30 AM   #14
945liter
Ford mustang GT 1994
945liter's Gallery
Just rewire it , dont put a switch no one would steal a dsm in a hundred years to get one block away before it breaks.
945liter is offline   Reply With Quote
Old 11-03-2007, 12:30 PM   #15
stockfornow
1G Talon TSI AWD
Well, somebody tried stealing it twice, and it was mostly all stock back then...
