Gravity bleeding the clutch master and slave cylinders - DSM Forums: Mitsubishi Eclipse, Plymouth Laser, and Eagle Talon Forum: DSMtalk.com
Wheel & Tire Center
Notices
Old 11-01-2007, 01:26 PM   #1
blkchr91
91 Galant VR-4
blkchr91's Gallery
Alrighty, I plan on replacing my clutch master and slave cylinders due to a disengagement issue.
It "seems" that if I pump the clutch pedal a few times when the clutch is not fully disengaging that the symptoms go away.
I have no pals and no one to help me.
I would like to gravity bleed both cylinders. I have done plenty of searching on the subject here, but don't get one thing.
How do I know that it is time to stop bleeding?
When I replaced my slave with an aftermarket one, I saw no air bubbles whatsoever.
How can I tell that I am done gravity bleeding?
It is obvious that I don't want to let the master run empty, but after that I am lost and don't want to put it back in too soon and have air in the line.
Thanks!
blkchr91 is offline   Reply With Quote
Old 11-02-2007, 03:37 PM   #2
mechanic
mechanic's Avatar
1991 GVR4, 1991 Tsi
mechanic's Gallery
Re: Gravity bleeding the clutch master and slave cylinders
just let it drip for a while, watching your reservoir and topping it up as needed. after you've run maybe half a bottle of fluid through, tighten up the bleeder and test your clutch. if it works, you're done. if not, do it for a while longer. you may have to pull the clutch pedal up the first time; i've seen them drop to the floor the first time you hit it but then it's fine.
mechanic is offline   Reply With Quote
Old 11-05-2007, 12:15 AM   #3
Stephen
Senior Moderator
Stephen's Avatar
1995 Talon TSi AWD
Stephen's Gallery
Feedback Score: 2 reviews
You can also get a brake bleeding vacuum suction pump thing. That would work better and faster.
Stephen is offline   Reply With Quote
Old 11-05-2007, 01:10 PM   #4
RippinGSX
Honorary Moderator
RippinGSX's Avatar
1993 Eclipse GSX
RippinGSX's Gallery
I bought one of those brake bleeder pumps for about $50. It was the worst $50 I ever spent. I would highly recommend using the old brake fluid in a bottle with the hose submerged trick.
RippinGSX is offline   Reply With Quote
Old 11-05-2007, 02:35 PM   #5
evoir
Ultra DSMtalker
evoir's Avatar
Turbo Spyder '98
evoir's Gallery
Feedback Score: 1 reviews
I got one of those miti-vac ones, and I ended up using a water bottle and fish tubing...less messy, holds more.
Evoir
98 Spyder GST
evoir is offline   Reply With Quote
Old 11-05-2007, 02:46 PM   #6
RippinGSX
Honorary Moderator
RippinGSX's Avatar
1993 Eclipse GSX
RippinGSX's Gallery
All that stupid pump I bought did was leak like a rusty bucket. Total waste of money.
Old 11-07-2007, 08:47 AM   #7
blkchr91
91 Galant VR-4
blkchr91's Gallery
See when I gravity bled, It just seemed like I had no issues with my clutch wayyy to fast.....e.g. in about 20 minutes or so, not the hour that I saw others post.
(Keep in mind that I just replaced the slave, not the master)
Is that normal?
Just makes me wonder
