(Searched)How to replace valve stem seals on a 95 gs-t?(without removing head) - DSM Forums: Mitsubishi Eclipse, Plymouth Laser, and Eagle Talon Forum: DSMtalk.com
Wheel & Tire Center
Notices
Old 11-22-2007, 09:05 PM   #1
4g64fiero
Ridiculous DSMtalker
4g64fiero's Avatar
1997 gs-t stock
4g64fiero's Gallery
Feedback Score: 27 reviews
Ok, I;ve never had to do this before and it sounds really easy. But, so does replacing a piston at first thought.(!) I've attained this 2g gst with 120000 miles and no modifcations whatsoever. Upon startup it smokes(its obviously burning oil) but it goes away until it starts idling again. So this leaves me to believe its the valvestem seals, especially since compression tests out fine. Not that that absolutely means the rings are ok. But I;d rather start with the valve stem seals since I hear theyre easier to deal with. So this is what I know about replacing them: The valve cover has to come off(dur da dur).
I can use an air compressor set at 100 psi to hold the valves up in the cylinder so they dont fall.
The pressurised cylinder should be at tdc incase the valve does fall.
I compress the valve spring then remove the valve spring retainer then remove the valve spring. After that, I can remove the valve stem seal.
Repeat 16x.
Ofcourse, I understand the process to be easier if I remove the cams, so I probably will. Then I'll retime the engine.
I dont know if theres more to this or not, I'd appreciate any advice you guys have.
Evos are gay.
4g64fiero is offline   Reply With Quote
Old 11-22-2007, 10:18 PM   #2
BIG_brother
DSMtalker
BIG_brother's Avatar
Eagle/Talon TSI/1990
BIG_brother's Gallery
Re: (Searched)How to replace valve stem seals on a 95 gs-t?(without removing head)
You have to take off the timming belt. Compress the cylnder and use the VS Comp tool.
BIG_brother is offline   Reply With Quote
Old 11-22-2007, 10:30 PM   #3
Red1991TSI
Site Administrator
Red1991TSI's Avatar
1991 Eagle Talon Tsi
Red1991TSI's Gallery
Feedback Score: 78 reviews
There's always the coiled rope method.
Read the rules people!
Red1991TSI is offline   Reply With Quote
Old 11-22-2007, 11:00 PM   #4
flexnuts02
Ultra DSMtalker
flexnuts02's Avatar
1998 eclipse GS-T
flexnuts02's Gallery
Feedback Score: 9 reviews
Yeah coiled rope works the best, You risk turning the engine over when pressurizing it if it isn't perctly straight up. Like red said just stuff rope down in there so you don't have to worry about it falling at all then.
daily driven
98GS-T//built 2.0//Built head//50 trim//20psi//2.5" JMF o2 open dump//tial 38mm//LSD//DSMlink//1050cc//much more//350hp at 20psi
98GS-T//96Civic-Sold//80FirebirdFormula//93Altima-sold//93S-10pickup//04YamahaYZF600R
flexnuts02 is offline   Reply With Quote
Old 11-22-2007, 11:02 PM   #5
4g64fiero
4g64fiero's Avatar
1997 gs-t stock
4g64fiero's Gallery
Hmm, that definitely makes more sense. Will do!
Evos are gay.
Old 11-24-2007, 01:40 PM   #6
4g64fiero
4g64fiero's Avatar
1997 gs-t stock
4g64fiero's Gallery
What other special tools am I going to need?
Evos are gay.
Old 11-24-2007, 02:07 PM   #7
Dsm Rocket
Hardcore DSMtalker
Dsm Rocket's Avatar
Eagle Talon 97
Dsm Rocket's Gallery
Feedback Score: 25 reviews
Go to www.vfaq.com and click on the DSM mod site link. click on the Engine tab on the top of the page and then about half way down you'll see Replacing Valvestem Seals click on that and theres all you'll need to know to do the trick
Dsm Rocket is offline   Reply With Quote
Old 11-24-2007, 11:12 PM   #8
4g64fiero
4g64fiero's Avatar
1997 gs-t stock
4g64fiero's Gallery
Thanks that helped alot. I cant believe I overlooked that in the first place.
Evos are gay.
Old 11-25-2007, 08:26 AM   #9
ImBoostedRu
ImBoostedRu's Avatar
Mitsubishi/Eclipse/95
ImBoostedRu's Gallery
To hold the valves in place you can also use compressed air. Just get a compression tester and hook an air hose to the end instead of the gauge. Just used this method on a buddies Vet.
ImBoostedRu is offline   Reply With Quote
