When we rebuilt my 1g engine I was not really the most knowlegable about dsm's but I do remember asking my build partner if we should use the oil pan gasket I bought and he replied no we never do we always use rtv so return it. I said are you sure I got it but he insisted so as a good padawon would do I left it alone. Now with the car running and numerous hours spent looking for a pretty annoying leak thats staining the shit out of my garage I 'm sure it's the pan. So was I right we should've used the gasket or is this a fluke and it's just bad luck.
There is no oil pan gasket. Use Hi Temp RTV. Solid consistent continuous bead inside the ridge and bolt holes. Let it sit for 24 hrs to cure, than do whatever you please.
Ok I'm pretty sure we didn't let the rtv cure for 24 hours and the parts store did sell me a oil pan gasket so they probably sold me something wrong. So here's my next question I have the 2g tranny bolted up to it and the transfer case is in the way of the pan bolts so I'm guessing I need to take out the axles first then the transfer case? I'm capable of turning a wrench and I've got the book but just to be safe do I need to know anything before doing that, if that's even correct. And is there an aftermarket pan that's better since i'm already taking it apart and how much, if you know. Thanks for the info.
moroso , makes a bad-ass pan for all 4g63 motors , kinda pricey but it has great baffles , and a side kick out so it holds like 6.5qts.
I have never personally used one but I have read somewhere that there was fitment issues with their design.
90 TSI AWD- 74k original miles (my baby!)
92 GSX- SOLD
92 Laser AWD-The track car Click Here For Instant Enlightenment!
10 Hundred Racing
Duckin' beer cans and rollin' 50 deep.
It was originally not designed to use a gasket. Since you didn't let it fully cure I wouldn't consider it a fluke, just a faulty install. Pull the pan again and use an RTV designed for high temp and oil stable use, then let it fully cure before use.
But make sure that when you remove it, you use a razor blade and really clean off the old crap and smooth the edges out before reinstalling it.
92 GSX- SOLD
10 Hundred Racing
Ok I got that part but the axles and transfer case that's coming out before right and if so is there any things I should know before simply removing these parts. thanks
It only fits 1Gs, not 2Gs.
To replace the oil pan you must remove the oil return line from the turbo, the downpipe and transfer case. There is no need to be removing any of the axles or any of that.
Remove the pan. Clean off the pan and the block. Apply a good consistent bead.
I usually wait a few minutes before I slap the pan back on the car. Slap the pan back on the car carefully, don't let it move side to side, it needs to go straight up.
Put the bolts back in criss-cross pattern, do not tigthen them down too much. Just a bit to where you see some RTV push out a bit. Wait a few hours. Take an 8mm socket, put it onto a screw driver and hand tigthen it, don't use a ratchet, the oil pan bolts need barely 10-15lbs of torque on them, hand tigthen is enough.
Wait 24 hrs, put everything back, don't forget the oil. Start the car let it warm up, look for leaks.
Go crash into tree.
I have one and it is bad ass as far as how much oil it holds and how cool it helps to keep the oil. Anyway, there were some slight fitment issues when installing the pan. I don't know what the AMS had to do to put it in. I didn't do this myself I was kind of chicken a few years back. But they said it's nothing crazy.
The bottom of the pan needs to be clearanced for the oil pickup, it sits too close and causes starvation issues. At least the earlier design, Moroso also no longer exists.
If you want a suggestion on a good RTV I can give it to you along with a picture of the tube it came in. I got this stuff from Autozone and it took me nearly a hour to get the damned oil pan off my car. The stuff worked wonders!
Ex owner of a 97 GSX: Built 7-Bolt | 1g race head | Evo 3 mani / stock o2 | 3" GM MAF | 1g TB | JMFab SMIM | FIC 950cc | 255 Rewired | HKS 272 | Fidanza cam gears | BW 57 Trim | DSMLINK V3 | Fluidampr pully | 3" N1 | AEM WB | QM Twin Disk | DSS Drive Shaft | Eibach pro's | Nitto Invo's | 11.85 @ 130.18 on E-85 - 3582r Rule #7 Impoorved Spelings! - With high HP comes great Responsibility (Take it to the track!) If you want 300-400hp read this first
