» Wheel & Tire Center
» Sponsors
» Sponsors
Old 07-02-2008, 10:55 AM   #1
4g64fiero
Ridiculous DSMtalker
4g64fiero's Avatar
1997 gs-t stock
Trader Rating: (24)
4g64fiero's Gallery
megasquirt sticky!
I believe that there should be a thread that links all the resources for installing megasquirt v1 and v2 on the v2.2 or 3.0 board into a dsm.
I'll start with what I've found and know:
If you have a dsm and need to want to install megasquirt into your car you have to decide whether or not you want mega squirt 1 or 2. I'm not going to make that decision for you of course because I'm no expert on the matter. I'm pointing out the fact because to mod a v2 or v3 board for ms1 for use in a dsm is diferant than modding those boards for use with a dsm with ms2.
Say if you choose ms1 for whatever reasons, you need to do the following mods for the board:
http://www.diyautotune.com/tech_arti...alon_laser.htm
But if you chose megasquirt 2 like I did, you can do this:
http://www.msextra.com/ms2extra/MS2-...g63.htm#wiring
It should be noted also that any year dsm needs to use a 1g cas with any version of megasquirt.
Rebuild number 3 underway.
4g64fiero is offline   Reply With Quote
Old 07-02-2008, 01:34 PM   #2
wishihadatalon
Super DSMtalker
1991 eagle talon
Trader Rating: (5)
wishihadatalon's Gallery
Re: I think there should be a megasquirt sticky!
That is 100% wrong. If you have a 7 bolt you can use the stock crank and cam angle sensors.
Megasquirt is the shit. I ran it, my buddy runs it (crank sensor and cam sensor), my fiance runs it, another buddy runs it on his colt, and my buddy who builds them for me has one on his laser and 1998 Eclipse RS-T.
After finally being able to play with MS2 this week, I don't ever see myself going back to one. The car runs so much better with the ms2 chip in there.
wishihadatalon is offline   Reply With Quote
Old 07-02-2008, 01:39 PM   #3
4g64fiero
4g64fiero's Avatar
1997 gs-t stock
Trader Rating: (24)
4g64fiero's Gallery
Well , that is good to know. I was just going by diyautotune.com
Did you have to modify the board in anyway to use the stock crank and cam sensor?
Old 07-02-2008, 05:23 PM   #4
tt281gt
DSMtalker
Black 1995 GST Coupe
Trader Rating: (3)
tt281gt's Gallery
PLEASE inform me on how to use the STOCK cam and crank sensor with my 7 bolt 2g.
If that's the case my DSM will have megasquirt on in a matter of weeks, I have had MS V2.2 sitting in my closet for over a year....
tt281gt is offline   Reply With Quote
Old 07-02-2008, 10:59 PM   #5
4g64fiero
4g64fiero's Avatar
1997 gs-t stock
Trader Rating: (24)
4g64fiero's Gallery
I think it should be noted that the 95 camshaft position sensor is diferant from the other 2g camshaft position sensors as its output is inverted in comparison.
Old 07-02-2008, 11:08 PM   #6
wishihadatalon
Super DSMtalker
1991 eagle talon
Trader Rating: (5)
I will get my buddy to come here and explain how to put it in with the stock sensors.
Old 07-03-2008, 11:39 AM   #7
tt281gt
DSMtalker
Trader Rating: (3)
tt281gt's Gallery
So that does that mean that I would follow procedure to wire the stock sensor but "backwards" since it's inverted? [Yeah I know, noob]
Hopefully this guy comes through and I can have MS up and running, all I would need is a AFPR, injectors, and wide band.
Old 07-03-2008, 01:11 PM   #8
4g64fiero
4g64fiero's Avatar
1997 gs-t stock
Trader Rating: (24)
4g64fiero's Gallery
It means its output is inverted in comparison to the other cps's. I personally just bought a 1g cas for 35usd shipped instead of worrying about how to use the stock sensors. People have documented and used the 1g cas many times with megasquirt. I'd rather just have the insurance that my sensor works correctly for the application than try to formulate a way to use the stock sensor and save 35$.
Old 07-03-2008, 02:31 PM   #9
tt281gt
DSMtalker
Trader Rating: (3)
tt281gt's Gallery
True, I did some searching but could not find anything about a 1g CAS on a 2g head...Everthing I found about a 1g CAS in a 2g had to do with a 6 bolt swap...
So I guess it's time for a head swap at least I do have a 1g head and manifold sitting in my garage, I have to finish porting it and see if it's usable lol [I used this head to learn to port, looks good except this one area and I still have to complete it...].
Old 07-03-2008, 02:35 PM   #10
wishihadatalon
Super DSMtalker
1991 eagle talon
Trader Rating: (5)
NO NO NO. 1g cas will work just fine on a 2g head. Just make sure that your cam has the key way for the 1g cam angle sensor.
Old 07-04-2008, 07:01 PM   #11
gSx-LeX
Honorary Administrator
2007 V
Trader Rating: (19)
gSx-LeX's Gallery
Good info guys! A long time ago, I was working on making a DSM specific Plug-and-play MS. This is very good info!
Stickied.
2007 Black Cts-V
ZiptieBandit
gSx-LeX is offline   Reply With Quote
Old 07-04-2008, 11:30 PM   #12
TurboTiger
TurboTiger's Avatar
92 Plymouth Laser
Trader Rating: (0)
TurboTiger's Gallery
MS2-Extra user here, chiming in. Running it on my 1G Turbo AWD. I'm so close on getting it running good.
TurboTiger is offline   Reply With Quote
Old 07-05-2008, 12:07 AM   #13
4g64fiero
4g64fiero's Avatar
1997 gs-t stock
Trader Rating: (24)
4g64fiero's Gallery
What set of sensors are you using and what board?
Old 07-05-2008, 11:03 AM   #14
4g64fiero
4g64fiero's Avatar
1997 gs-t stock
Trader Rating: (24)
4g64fiero's Gallery
Here is some pics of my progress with the ms2 v3.0 board:
Old 07-05-2008, 04:54 PM   #15
4g64fiero
4g64fiero's Avatar
1997 gs-t stock
Trader Rating: (24)
4g64fiero's Gallery
I will also note that the firmware you put on your MS processor must match the firmware you configure megatune to use, otherwise bad things happen.
If you follow the information at megamanual.com though, there is not really much to input here. Its pretty straight forward.
Also, you dont need a megastim to install the firmware like it says so in the directions.
All you have to do is hook a 9 volt battery up to the megasquirt board to pins18(ground) and 19(ground) and positive to pin 28.
That should turn the megasquirt on.
Remember to install the jumpers on the processor everytime you want to change the firmware, and remember to take the jumpers off when trying to access the megasquirt board from megatune. Always turn the board off before removing or installing the jumpers. I started getting crazy errors because I didnt turn my board off after deciding on a different firmware and putting the jumpers on. No permanent damage done, though.
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
vB code is On
Powered by vBulletin®
