1g mirror glass removal - DSM Forums: Mitsubishi Eclipse, Plymouth Laser, and Eagle Talon Forum: DSMtalk.com
Wheel & Tire Center
Go Back   DSM Forums: Mitsubishi Eclipse, Plymouth Laser, and Eagle Talon Forum: DSMtalk.com > DSM Tech Central > Body Tech and Appearance
Notices
Old 08-21-2008, 12:24 PM   #1
cdc5205
Eagle/Talon/1993
cdc5205's Gallery
I cracked the passenger side mirror glass on my 93 Eagle Talon and I want to replace it.
Does the glass just pop off or is there something holding it back? Do I need to remove the mirror housing first?
I cannot seem to find the answer after a few search queries. So if this has been asked just direct me to the forum.
Thanks.
cdc5205 is offline   Reply With Quote
Old 08-21-2008, 01:06 PM   #2
Skywise
Hardcore DSMtalker
Eagle Talon 1991
Skywise's Gallery
Re: 1g mirror glass removal
You cannot replace the glass, only the whole assembly.
Skywise is offline   Reply With Quote
Old 08-21-2008, 01:26 PM   #3
93_GSX
Ultra DSMtalker
93_GSX's Avatar
1993 Mitsu GSX
93_GSX's Gallery
You may wanna try a junk yard, or try looking in your Haynes or Chilton and see if they explain how to take the assembly apart.
Not to be a dick, but I find it hard to believe you have to replace the whole assembly just for your side view mirror. Not that Mitsu/Cryco had ALL good ideas when building these cars, I just think there has to be SOME way....
93_GSX is offline   Reply With Quote
Old 08-21-2008, 02:05 PM   #4
kronus
Ridiculous DSMtalker
kronus's Avatar
'98 GS - '97 TSi AWD
kronus's Gallery
Feedback Score: 26 reviews
You can replace the glass. It's called a 'redi-cut' and most auto glass places should be able to order one for you and install it. That's the 'brand new' way. Just go to a junkyard and grab a whole unit off a car, so you can learn to take a mirror apart your self.
Originally Posted by Wes393 View Post
If you do move on, just make sure it's to something equally interesting. Going from a DSM to some generic people carrier never ends well.
kronus is offline   Reply With Quote
Old 08-21-2008, 02:06 PM   #5
cdc5205
Eagle/Talon/1993
cdc5205's Gallery
Autozone sells just the mirror glass for 1g eagle talon. So you have to be able to replace them.
And i have a chilton but all it explains is how to remove the entire mirror from the car, not just the glass.
Old 08-21-2008, 02:42 PM   #6
kronus
kronus's Avatar
kronus's Gallery
Once you remove it from the car, you'll see that the bottom side of the mirror has holes. Thats where you insert the screwdriver to remove the screws holding the mirror internals together. There should be two there, and then if you move the mirror around, you'll see a third on towards the outside edge of the 'case' and you'll need a long screwdriver to get to it from the mirror side.
Old 08-21-2008, 04:18 PM   #7
cdc5205
Eagle/Talon/1993
cdc5205's Gallery
Alright, thanks. I just mainly wanted to know if it were possible without removing the full mirror.
But should be easy enough anyway.
Old 08-21-2008, 04:57 PM   #8
DSM Rook
Moderator
DSM Rook's Avatar
Eagle Talon TSi 90
DSM Rook's Gallery
Feedback Score: 30 reviews
This is a mirror on a 93. Remove the 1 phillips screw on the underside of the mirror housing. (there are 2 holes, 1 you will see a screw) The screw may not drop out, this is ok, the mirror will most likely move upwards which you want. There are 2 tabs that the mirror backing slides down on seen in the pics. BECAREFUL about these, if 1 breaks your mirror will vibrate. You'll need to remove the triangular cover inside the door and I think you can access the plug. Unplug that and you can remove the mirror. You can then break out all the old glass. I'm guessing the glass is glued or double sided taped onto the lens insert. Search on google for "1993 eagle talon mirror glass" You should see some places where you can buy a single lens.
Here's a pic of the insides, don't mind the dirt. This car has/was sitting outside for 2 years. Its getting rebuilt this winter.
DSM Rook is offline   Reply With Quote
Old 08-21-2008, 06:24 PM   #9
kronus
kronus's Avatar
kronus's Gallery
Holy! Wow. Even better! Thanks for the picture!
Old 08-21-2008, 07:03 PM   #10
DSM Rook
Moderator
DSM Rook's Avatar
Eagle Talon TSi 90
DSM Rook's Gallery
You're welcome. Had a few minutes to spare. Obviously the top picture is looking inside of the mirror housing and the bottom is looking at the back of the mirror... insert.
And for anyone who has a mirror that shakes while driving, one or both of those white tabs on the back side of the mirror are broken. If you're lucky like I was with my last car the piece is still there and you can expoxy it back on and make it work.
