How to disassemble a 1g awd 5 speed transmission - DSM Forums: Mitsubishi Eclipse, Plymouth Laser, and Eagle Talon Forum: DSMtalk.com
Wheel & Tire Center
Notices
Old 11-13-2008, 05:53 AM   #1
1gawd4g63
Ultra DSMtalker
1gawd4g63's Avatar
91 eagle talon tsi awd
1gawd4g63's Gallery
Feedback Score: 4 reviews
I was taking some pictures of a transmission that i am in the process of rebuilding and i though that i'd make a documentary on steps to disassemble and assemble the transmission:
Step 1: Remove all bolts from the end cover and remove the end cover (this might require a rubber hammer and a little prying to get off.
before
After
Step 2: Remove the 2 nuts on the ends of the shafts, and the snap ring on the viscous coupler, next remove the roll pin in the 5th gear shift fork, now you can remove the 5th gear assembly and the viscous coupler (be careful there is a little ball bearing in the center diff shaft that the viscous coupler slides over, make sure to remove that and set it aside. At this point you can remove the transfer case output shaft also.
5th gear and viscous coupler removed
Removing output shaft
Step 3: Remove the 3 shift selector nuts, springs and balls
Step 4: Remove the bearing plate from the end of the tranny case and remove center diff
This is the bearing plate
REmove center diff
Step 5: Remove the reverse idler retaining bolt from the back side of the trans case, remove all case bolts that hold the top to the bottom.
Step 6: Carefully pry the top casing from the bottom and remove the reverse idler gear
Step 7: At this point you can remove the front differential, and the diff drive gear assembly
Step 8: Remove the roll pins on the 1-2 and 3-4 shift forks and remove the input and intermediate shaft's
Now you can remove the shift rails and go onto cleaning and measuring everything for reassembly. I will have pics of me doing the gear sets and reassembling everything in the next week. Hope this is helpful so someone out there.
1gawd4g63 is offline   Reply With Quote
Old 11-13-2008, 12:36 PM   #2
93_GSX
Ultra DSMtalker
93_GSX's Avatar
1993 Mitsu GSX
93_GSX's Gallery
Re: How to disassemble a 1g awd 5 speed transmission
Oh, this will DEFINATELY be helpful! I would think about requesting this being a sticky, or an addition to the VFAQ, even!!
93_GSX is offline   Reply With Quote
Old 11-15-2008, 11:06 PM   #3
zckry
Ultra DSMtalker
zckry's Avatar
'98 GSX
zckry's Gallery
Feedback Score: 36 reviews
Def sticky, I wish someone would do this to a 2G also because I've been wanting to take my apart.
zckry is offline   Reply With Quote
Old 11-16-2008, 08:06 AM   #4
1gawd4g63
Ultra DSMtalker
1gawd4g63's Avatar
1gawd4g63's Gallery
The 2g transmission has the same exact internals if it is awd. The fwd's are very simular they just don't have the center diff, viscous coupler, and output shaft.
Old 11-16-2008, 10:41 AM   #5
98gsxjeff
DSMtalker
mitsubishi eclipse gsx
98gsxjeff's Gallery
This is really great. Thanks for sharing the know how with us. Any idea how to modify these transmittions like shepard.
98gsxjeff is offline   Reply With Quote
Old 11-16-2008, 10:43 AM   #6
1gawd4g63
Ultra DSMtalker
1gawd4g63's Avatar
1gawd4g63's Gallery
IT all depends on what you are trying to accomplish. Shep just add's alot of different parts. They are very easy to make shift like butter if you know how to setup the syncro's and clearances correctly.
Old 11-16-2008, 12:33 PM   #7
zckry
Ultra DSMtalker
zckry's Avatar
'98 GSX
zckry's Gallery
Really? That's awesome, I got the FWD.
Old 11-16-2008, 01:21 PM   #8
AKboost
AKboost's Avatar
92 Eagle Talon AWD
AKboost's Gallery
Nice! Now i just wish i didnt pay some shop to rebuild it wrong....Thanks ill use this in the near future.
AKboost is offline   Reply With Quote
Old 02-10-2009, 12:58 PM   #9
blamclep
eagle talon TSI 1992
blamclep's Gallery
just saved myself $1000.00 took it apart and all it was was 1-2 shift fork. awesome thanks dude!
blamclep is offline   Reply With Quote
Old 02-11-2009, 10:56 PM   #10
Project90Talon
Project90Talon's Avatar
'93 Eagle Talon TSi AWD
Project90Talon's Gallery
yeah I had a similar situation, I broke a shift rail (1-2) and saved myself some dough as well
Project90Talon is offline   Reply With Quote
Old 02-11-2009, 11:03 PM   #11
hawaiifiveoh
Ultra DSMtalker
hawaiifiveoh's Avatar
Hotwheels
hawaiifiveoh's Gallery
Feedback Score: 17 reviews
This needs to be a sticky. Nice job man!
El Es Gone
hawaiifiveoh is offline   Reply With Quote
Old 02-11-2009, 11:04 PM   #12
i need a dsm
Ultra DSMtalker
i need a dsm's Avatar
93 AWD talon
i need a dsm's Gallery
Feedback Score: 43 reviews
Haha nice write up! I took apart my trans about a year ago cause of no 2nd gear...
I never touched a motor/trans before and now I can take it apart! This would of been helpful back in the day!
I have better pics I took.. If a mod wants to add them in or something
Originally Posted by Skywise View Post
The knock sensor is a microphone. You can test it the same way.
Originally Posted by STikillinTsi View Post
^How? Like this: testing 1, testing 1 2, testing 1 2 3? How woudl you actually test that?
i need a dsm is offline   Reply With Quote
Old 02-11-2009, 11:11 PM   #13
indyeagle
indyeagle's Avatar
1990 EAGLE TALON AWD
indyeagle's Gallery
I'm sure I will have a few questions, but I just want to know if there is any special tool involved in doing this?
indyeagle is offline   Reply With Quote
Old 02-12-2009, 01:10 PM   #14
need2fix
Hardcore DSMtalker
need2fix's Avatar
92 Talon TSI AWD
need2fix's Gallery
Feedback Score: 2 reviews
Yeah, I think I'm about to do a full rebuild on my 2g tranny, now to find another tranny to stick in while I rebuild!
need2fix is offline   Reply With Quote
Old 02-12-2009, 09:13 PM   #15
JamesH
Hardcore DSMtalker
JamesH's Avatar
90 Laser RS Turbo
JamesH's Gallery
Any help on replacing synchros? Mine are cooked.
JamesH is offline   Reply With Quote
