Originally Posted by mattokoo1
I have a 1998 spyder gs. It runs fine when it warms up but it takes a longtime to warm up and till it does it runs really ruuf low rpms. Can sumone point me in the direction to fix the problem?? I also am throwqing codes for map sensor and maf sensor.
First off.
Rough and Someone. Text speak does not fly here. If you have any questions, Rule #7 in my signature will answer them.
As for your warming up problem. I would first say thatyou should fix the problems with the map and maf and see if that solves your problem. When was the last time you replaced your Thermostat? It could be stuck open, causing a longer then normal warm up period for the car.
Do you have a logger handy?
