Replacing piston rings help... - DSM Forums: Mitsubishi Eclipse, Plymouth Laser, and Eagle Talon Forum: DSMtalk.com
Wheel & Tire Center
Notices
Old 12-09-2008, 03:45 PM   #1
hawaiifiveoh
Ultra DSMtalker
hawaiifiveoh's Avatar
Hotwheels
hawaiifiveoh's Gallery
Feedback Score: 17 reviews
So I've been back and forth with it, and finally just want this out of the way. I'm gonna just throw in some new piston rings, replace everything I need to, and get my car done to either keep it, or sell it for a reasonable price. What I need to know is, what all should be replaced while putting in piston rings? As in what should I do to help it out, and not skimp by? I don't plan on building it, just making it healthy again.
This is my list so far...
-Piston rings, of course
-Main bearings
-Rod bearings
-Headgasket ( I have an oem which can't be reused)
I'm not sure if I can or not, but I have a newer timing belt (less than 4k miles on it), but would it be bad to reuse this? And my once used arp's can be used again correct?
If there is anything else that should be replaced, chime in, thanks
El Es Gone
hawaiifiveoh is offline   Reply With Quote
Old 12-09-2008, 03:49 PM   #2
Burnett03
Ridiculous DSMtalker
Burnett03's Avatar
1997 Eclipse GSX
Burnett03's Gallery
Feedback Score: 34 reviews
Re: Replacing piston rings help...
The block must be honed for the new rings.
Ryan Burnett
95 TSI AWD
"Project 600 horse auto"
2008 R1
Burnett03 is offline   Reply With Quote
Old 12-09-2008, 03:51 PM   #3
lilredeclipse
lilredeclipse's Avatar
The Purple Monster
lilredeclipse's Gallery
Feedback Score: 16 reviews
I would add an oil pan gasket to the list. If you are replacing the mains then the front case has to come off. Or at least I never took the crank out and was able to leave it on. So a front case gasket, and the rear and front main seals that go around the crank.
That's what else I would add if I was freshening up the bottom end.
* The belt can be used BUT things happen.
partsamerica.com has gator back ones cheap. They are good I have used them on all of mine.
Boosted INC, Purple Monster:
2010, 730awhp- 10.2@154, 10.19@150, 10.15@140
2011, 801AWHP- 9.7@149, 9.8@151, 9.9@151
2013, 823awhp- 9.9@150
lilredeclipse is offline   Reply With Quote
Old 12-09-2008, 03:56 PM   #4
Burnett03
Burnett03's Avatar
1997 Eclipse GSX
Burnett03's Gallery
Originally Posted by lilredeclipse View Post
I would add an oil pan gasket to the list. .
No, you mean RTV (The right stuff rtv) to seal the pan. Gaskets should not be used.
Ryan Burnett
95 TSI AWD
2008 R1
Old 12-09-2008, 03:56 PM   #5
hawaiifiveoh
Ultra DSMtalker
Hotwheels
Of course, I forgot to add that I will be honing the block, RTV***, rear and front main seals, and a front case gasket...check. Anything else?
El Es Gone
Old 12-09-2008, 04:03 PM   #6
lilredeclipse
The Purple Monster
Good on you if you can get your pan to seal with just RTV I never can..
But I do the gasket + RTV and not a drop comes out.
There is a gasket on the oil pick-up, but that can be made with gasket paper.
Old 12-09-2008, 04:31 PM   #7
BISHILVR
BISHILVR's Avatar
MITSUBISHI GST 1999
BISHILVR's Gallery
Feedback Score: 4 reviews
Cam seals for sure, they are a known leaker especially if you run synthetic oil. A valve cover gasket of course, the oil pump shaft seal, and you can reuse the timing belt if you mark the direction of rotation when you take it off and then install it in the same direction, the only aftermarket belt the I would ever use is a Gates, its actually stronger than a stock Mitsubishi belt, unless you run a kevlar belt. Why are you replacing the piston rings?
While it's true beauty is only skin deep, UGLY goes clear to the bone... BISHILVR
Old 12-09-2008, 04:33 PM   #8
hawaiifiveoh
Ultra DSMtalker
Hotwheels
Compression is way down...90-100 across the board
El Es Gone
Old 12-09-2008, 05:26 PM   #9
BISHILVR
BISHILVR's Avatar
MITSUBISHI GST 1999
BISHILVR's Gallery
Are you positive that it is not a head gasket or a valve sealing problem? Piston rings in these cars (stock) are pretty stout, I have a car with 300,000 on it that still has great compression, and another with 250,000 on it. They have had head/valve problems in the past, but not lower end related.
Old 12-09-2008, 05:43 PM   #10
hawaiifiveoh
Ultra DSMtalker
Hotwheels
I'm pretty sure the headgasket is good, only has about 3k miles on it and arp's. But, on the valves...I'll have to look into that, what should I do to test everything out?
El Es Gone
Old 12-09-2008, 06:41 PM   #11
rad_dsm
Hardcore DSMtalker
rad_dsm's Avatar
96 Eagle Talon Tsi AWD
rad_dsm's Gallery
Feedback Score: 26 reviews
Do a leakdown compression test.
http://www.geocities.com/dsmgrrrl/FAQs/leakdown.htm
You can get a leak down compression tester at harbor freight and you may be able to borrow/rent one at Autozone.
2g Stock Ex manifold, Forced Performance FP2544, SSAC FMIC, SS tubular o2 housing, 3" DP and cat back, 1000cc PTE injectors, Walbro 255 FP, AFPR, NGK BPR6ES, DSMLINK V2.5, Forge 1G BOV, 1G TB ported, Ported 2g intake manifold, Autometer cobolt Boost Gauge, 18x9 R1 Victory, Nexen N7000 tires, Tokico 2" drop Springs & Shocks/Struts
rad_dsm is offline   Reply With Quote
Old 12-09-2008, 06:53 PM   #12
hawaiifiveoh
Ultra DSMtalker
Hotwheels
That's what I figured, well looks like I'm gonna be doing a leakdown test...in the meantime, anyone got any other suggestions?
El Es Gone
Old 12-10-2008, 12:43 PM   #13
green_bread
Hardcore DSMtalker
green_bread's Avatar
'92 Eagle Talon TSI AWD
green_bread's Gallery
Feedback Score: 14 reviews
Dont skimp on the bearings. I always liked King bearings for the mains/rods.
green_bread is offline   Reply With Quote
Old 12-10-2008, 12:52 PM   #14
BISHILVR
BISHILVR's Avatar
MITSUBISHI GST 1999
BISHILVR's Gallery
Federal Mogul makes great bearings also!
Old 12-10-2008, 01:32 PM   #15
Gamble
Gamble's Avatar
02 Hyundai
Gamble's Gallery
Feedback Score: 41 reviews
Personally, I would do a balance shaft eliminator kit.
Mitsu MLS headgasket
ARP headstuds
You can use oem studs on the bottom if you like.
Just pull out the block and have a machine shop do all the work. They could honestly do it in a day, but I'm sure it would at least a week with how busy they get.
Might as well throw some cams on that head if you don't have any.
Gamble is offline   Reply With Quote
