Re: Inner tube on truck tires that are meant to be tubeless
You just have to be sure to get a tube with a metal valve stem. The rubber ones wont poke through the hole in the wheel and will get sliced.
94 TSi AWD~ 6 bolt, 2.5" turbo back no cat, short route fmic 2.5" piping, Evo 3 16g at 24 psi, ECMLink V3, AEM wideband, Dephi 680's, Wally 255 rewired, Aeromotive AFPR at 37.5 psi base, GM 3bar, GM IAT, running SD
If it can't be fixed with a hammer, it's an electrical problem!
