More power out of Non Turbo - DSM Forums: Mitsubishi Eclipse, Plymouth Laser, and Eagle Talon Forum: DSMtalk.com
Wheel & Tire Center
Go Back   DSM Forums: Mitsubishi Eclipse, Plymouth Laser, and Eagle Talon Forum: DSMtalk.com > DSM Tech Central > Non Turbo Tech
Notices
Old 01-27-2009, 09:41 PM   #1
Psycho5150
DSMtalker
Psycho5150's Avatar
1992 Talon TSI AWD
Psycho5150's Gallery
I have a non-turbo 2.0 Eagle Talon and am looking to pop a few more ponies out, atleast 200hp if not a bit more. I own a TSI as well, but this here is my all motor daily driver. So far I got an intake and a two inch catback.
All suggestions will be looked into.
Psycho5150 is offline   Reply With Quote
Old 01-27-2009, 09:59 PM   #2
brokeawd
Hardcore DSMtalker
brokeawd's Avatar
90 Eagle Talon TSi,
brokeawd's Gallery
Feedback Score: 3 reviews
Re: More power out of Non Turbo
Sell it and use the money towards your TSi.
J/k.Do some searching, someone made a good thread about this a while back.
"Some say that he lives in a tree and that his sweat can be used to clean precious metals... all we know is, he's called the Stig."
-If you post after me, the terrorist's will win.-
brokeawd is offline   Reply With Quote
Old 01-27-2009, 10:05 PM   #3
Loner
Hardcore DSMtalker
Loner's Avatar
Mitsubishi Eclipse GSX
Loner's Gallery
A header, High Flow cat, cams, 55mm TB. Thats all I can think of that isn't going to kill your bank.
Loner is offline   Reply With Quote
Old 01-27-2009, 11:54 PM   #4
740 Turbo Brick
Hardcore DSMtalker
740 Turbo Brick's Avatar
2003 Evo 8
740 Turbo Brick's Gallery
200 HP? Good luck....and thats coming from a 2GNT driver. Are we talking 200 at the crank or wheels. And is this Auto or Standard? That will make a huge difference. Im building my GS as a DD car that has some beefy power to it, but Im not shooting that high. You will want:
Full CAI
Header, 4-1 recommended
UDP
MSD coil pack/wires if you want to spend the extra cash
Exhaust, nothing bigger than 2.5"
Higher flowing muffler.
As loner said, a 55mm, or if you want to spend the big bucks get a MPx 60mm billet aluminum TB. I just got one, and holy fuck ass did my car wake up.
I also bought an F1 Racing stage 1 clutch, easy pedal feel with awesome engagement.
03 Evo 8: More fun than a non turbo Eclipse
95 Eclipse GS: 186 WHP
14.69@93 MPH - 10.5:1, Crower 2s, and MSnS, ALL MOTOR!
740 Turbo Brick is offline   Reply With Quote
Old 01-28-2009, 12:02 AM   #5
Loner
Hardcore DSMtalker
Loner's Avatar
Loner's Gallery
Pretty much what me and Turbobrick is all the basic things you can do, unless you want to do internals.
Old 01-28-2009, 06:00 AM   #6
xXPROJECT94Xx
DSMtalker
xXPROJECT94Xx's Avatar
1994 Mitsibushi Eclipse
xXPROJECT94Xx's Gallery
Whats a 55mm TB or MPx 60mm billet aluminum TB? What does it do?
xXPROJECT94Xx is offline   Reply With Quote
Old 01-28-2009, 06:20 AM   #7
Wtfeeezy
Wtfeeezy's Avatar
1991 GS-X
Wtfeeezy's Gallery
It's Short for Throttle Body. 55 millimeters. 60 millimeter throttle body by MPx.
Wtfeeezy is offline   Reply With Quote
Old 01-28-2009, 06:46 AM   #8
cs82685
Super DSMtalker
cs82685's Avatar
Evo IX/96 RS-T
cs82685's Gallery
Feedback Score: 2 reviews
you can also do a jeep 60mm TB, cheaper, but they require some modification.
UDP and the throttle body will most likely be your best bets. LIGHT rims will also help
Originally Posted by Red1991TSI
I'm not a doctor but I play one on DSMTalk!
cs82685 is offline   Reply With Quote
Old 01-28-2009, 07:29 AM   #9
Sean485
Senior Moderator
Sean485's Avatar
99 Spyder "GSX"
Sean485's Gallery
Feedback Score: 7 reviews
The OP never really specified if the NT was a 1g or 2g, if it is a 1g the stock throttlebody is 60mm and flows plenty for far more power than it will ever make. Without the aid of forced induction or a bottle you will not get 200hp for less than 8k.
99 Spyder "GSX"
Sean Clancy
Sean485 is offline   Reply With Quote
Old 01-28-2009, 11:38 AM   #10
Psycho5150
DSMtalker
Psycho5150's Avatar
1992 Talon TSI AWD
Thanks for the input so far. I have a 1992 non-turbo Talon. Automatic Transmission. Haven't found a car with a tranny I wanted to tear up trying to teach myself standard.
Now to address money issues
I am planning to build this and have capabilty to save for what is needed, problem is I am unsure what I need.
I am but a noob mechanic so from the info I got from Turbobrick & Loner.
Cams: I have been looking for performance n/t cams. No luck. If you know where let me know.
Headers: I know what they are, though what does 4 to 1 mean?
CAI and UDP I need elaboration here just to know what is being spoken of.
Wires/Coil: I have stock coil pack with magstar wire.
Exhaust: So a straight up 2.5 inch exhaust the whole way would be best?
To Brokeawd: If you only knew how often I was told that.
Old 01-28-2009, 12:30 PM   #11
na94eclipse
Hardcore DSMtalker
na94eclipse's Avatar
'92 Laser AWD
na94eclipse's Gallery
Feedback Score: 19 reviews
Cams:I thought I heard of some cams for a N/A, maybe only custom grind, or people were putting turbo cams in N/A's or something but there should be a non-stock option out there. Your going to have to do some research here.
CAI = Cold Air Intake
I believe UDP = Underdrive Pulley
A 4-1 Header have four pipes into a single collector with just one pipe out. A 4-2-1 header would be four pipes into two, then those two into one. BTW you will only have a header, not header(s).
Its hard to say what will be "best" for an exhaust. Do you want more bottom end or top end? Generally speaking, a smaller size pipe will make more bottom end and a larger pipe would make more top end. As stated, if you do go up in size I woulden't go over 2.5 inch. Also if your state laws dont require it, toss the cat in favor of straight pipe.
Originally Posted by lazylaser View Post
What you have is "the FWD regret".
1992 Laser AWD
na94eclipse is offline   Reply With Quote
Old 01-28-2009, 02:20 PM   #12
2LiterRiceEater
2LiterRiceEater's Avatar
08 Evo GSR / 93 TSi AWD
2LiterRiceEater's Gallery
Feedback Score: 8 reviews
Exhaust wise, I got a 2.5 Cat-back, no resonators, mandrel bent up to the end, where there is a sport muffler. Like stated above, top end increased quite a bit. You will be surprised how much opening up these engines helps.
And people still put cams on N/Ts.
200 sounds like a bit too much on a N/T 4G63. Simple mods like an intake, full exhaust, balance shaft free, and no A/C if you want will help, but no 200. It will just make it peppier.
Not sure about the auto thing though. I have driven a few cars, same models, but one auto and one manual, and I have found that autos are a bit more sluggish. Never driven an auto DSM though, so I wouldn't know for sure.
2LiterRiceEater is offline   Reply With Quote
Old 01-28-2009, 09:00 PM   #13
JimG4652
91 Eclipse N/A 2.0
JimG4652's Gallery
http://www.dsmtalk.com/forums/showth...sepower&page=3
Check out post #45 on Page 3.
JimG4652 is offline   Reply With Quote
Old 01-29-2009, 02:30 PM   #14
movingman
Galant
movingman's Gallery
Mitsu made NT cams(i.e. 94 Galant GS), they are 260/264 and their come with either 10mm/9.5mm or 9.3mm/8.5mm lift.
Mitsu also made a 170hp NT 4G63, it probably not that hard to squeeze out another 30hp.
Use a 92 Galant GSR ecu(MD172575), its Eprom and has knock and made for 93+ octane.
But seriously, go with a G4CS block and G4CN head with cams, Galant GSR ecu, and your regular I/H/E if you really want 200+hp.
movingman is offline   Reply With Quote
Old 01-30-2009, 07:41 AM   #15
Matt Cramer
DSMtalker
1985 Dodge Ram 50
Matt Cramer's Gallery
I'd expect a NA 4G63 built to make 200 hp would drive like a Honda without the low RPM torque. 100 hp per liter means you'll have to rev it like crazy to get it there; a turbo motor would have a more street friendly powerband. Not to mention pairing better with an automatic transmission; you might need a high stall torque converter to make good use of the powerband on a high winding motor.
I'm surprised nobody has mentioned trying to use a 4G64 block to build a stroker motor.
Matt Cramer is offline   Reply With Quote
