Fuel Gauge Not Functioning - DSM Forums: Mitsubishi Eclipse, Plymouth Laser, and Eagle Talon Forum: DSMtalk.com
Wheel & Tire Center
Notices
Old 02-18-2009, 11:37 PM   #1
Esky
Ultra DSMtalker
Esky's Avatar
2001 Saturn SL1
Esky's Gallery
Feedback Score: 26 reviews
Hey everyone,
This is probably more noob than I want to believe, but I bought my 90 GSX a while back now, and the fuel gauge has never worked. The needle just sits on empty. The fuel light still works, so I know when I'm getting low, so that's good.
Everything else on the cluster works perfectly, so I'm guessing it's not connection related. I guess the motor for the needle itself could be dead, but how can I test that? Buy a new cluster and see if that works?
Maybe it's the sender, which I assume is on the fuel pump assembly, or close by? How do I go about testing the sender? Can I test it? I would assume that since I still get my low level light, the sender is ok...
I searched around but couldn't find anything on this...all I found were tach issues. I looked at the pin outs seeing if there was anything there, but didn't expect much and found nothing.
Basically, since I've not dug into this spectrum before...what is the list of logical steps towards diagnosing the cause of this? Preferably starting with the cheapest/easiest step and working up from there.
I could assume since I still get a level light, the sender is ok, and since the rest of the cluster works, the connection is ok...so am I left with a dead needle?
Thanks,
Adam
Esky is offline   Reply With Quote
Old 02-19-2009, 12:57 AM   #2
need2fix
Hardcore DSMtalker
need2fix's Avatar
92 Talon TSI AWD
need2fix's Gallery
Feedback Score: 2 reviews
Re: Fuel Gauge Not Functioning
Hrm. Do you have a spare cluster sitting around?
With all the hassle it will take to repair the cluster if it is a burned out motor, you will probably just bite the bullet and throw one in there. The gas light runs on the same signal as the needle does, it comes on when I *believe* there is 0.2v or less in the circuit, and the easiest way to test for that is with the fuel pump out, to pull up the little floater thing, and check the voltage with a multimeter, and watch the multimeter's voltage change as you slowly let the float drop down the mount shaft.
I say that's the easiest way, simply because you'd have to pull the gauge cluster out to check anything else, but, maybe you're lucky and the shaft is turning inside the needle, but the needle just needs to be glued back on!
If you really DID want to keep the original cluster, it would be as simple as de-soldering all the links that hold on the motor, and soldering on a new (hopefully tested) needle assembly, but like I stated earlier, unless you're REALLY good with a soldering iron, you can easily munk up the whole cluster.
need2fix is offline   Reply With Quote
Old 02-19-2009, 10:38 PM   #3
Esky
Ultra DSMtalker
Esky's Avatar
2001 Saturn SL1
Esky's Gallery
Unfortunately I do not have a spare cluster, so I would have to buy a known working one first, then hope that is the issue. But, that's probably going to be the best bet...I'm sure the needle is still attached because it hasn't swung straight down, and doesn't bounce at all. It's just frozen on E. I'm guessing the motors have physical stops in them so the needle doesn't go below E or above F...because there aren't physical stops that I can see on the front that would be holding the needle on E.
It would be nice if there was a way in the pockletlogger or other OBD software that could send voltage to each gauge through the dataport to move the needles to check for functionality. I mean...that doesn't seem like a far stretch, does it?
Old 02-20-2009, 12:21 AM   #4
need2fix
Hardcore DSMtalker
need2fix's Avatar
92 Talon TSI AWD
need2fix's Gallery
Well, you can do that! the sending unit on the in tank fuel pump has wires coming out of it for that specific reason. With the standard 3 wire setup (I haven't taken mine apart in a while, so this is pretty general) One is a positive, one's a ground, and one's a sending wire. The easy way to check the gauge is to touch the sending wire across the ground wire, removing the resistance from the actual unit, and see if the needle moves.
Old 02-20-2009, 09:05 AM   #5
Esky
Ultra DSMtalker
Esky's Avatar
2001 Saturn SL1
Esky's Gallery
The wires are easily accessible from just under the back seat, right? They come out of the top of the fuel pump mounting unit right? I'll dig for some more info on those wires and maybe try that out.
Thanks
Old 02-20-2009, 10:43 AM   #6
Jp90Talon
Senior Moderator
Jp90Talon's Avatar
90 Talon TSI AWD
Jp90Talon's Gallery
Feedback Score: 3 reviews
Does it still have the stock pump? If it has been upgraded the person that did the swap may have bent the float arm or gotten it snagged so the gauge doesn't register. The reverse happen to me in one of my cars. The float arm got bent and wouldn't register past 1/2 empty.
90 TSI AWD- 74k original miles (my baby!)
92 GSX- SOLD
92 Laser AWD-The track car
Click Here For Instant Enlightenment!
10 Hundred Racing
Duckin' beer cans and rollin' 50 deep.
Jp90Talon is offline   Reply With Quote
Old 02-20-2009, 10:46 AM   #7
Esky
Ultra DSMtalker
Esky's Avatar
2001 Saturn SL1
Esky's Gallery
Yep, the car is still 100% stock. I guess damage is a possibility if he tried to change the pump, then bailed on the project. But, if the float operates both the gauge and the light, and it was the float that is causing the "E" reading all the time, shouldn't the light be on all the time?
Old 02-20-2009, 11:57 AM   #8
indy1979
Super DSMtalker
1990 Eagle Talon AWD
indy1979's Gallery
Not necessarily. If the float is as old as the car, they will develop leaks and fill with gas. Depending on where the leak is, there could still be some air in the float.
If this is the case, when you put gas in the tank, the float will rise just enough to kick the light off (while still being submerged) and will fall back down when you are running empty.
Sam
I like to live by Einstein's theroy regarding the speed of light. Basically it says "The faster you go, the longer you live."
indy1979 is offline   Reply With Quote
Old 02-20-2009, 06:39 PM   #9
Jp90Talon
Senior Moderator
Jp90Talon's Avatar
90 Talon TSI AWD
Jp90Talon's Gallery
Well my gauge wouldnt dip below 1/2 empty but the gas light would still work. I guess there are 2 sensors.
92 GSX- SOLD
10 Hundred Racing
Old 06-02-2009, 10:35 PM   #10
da1sexmonk83
96 Eagle Talon TSi AWD
da1sexmonk83's Gallery
What is the voltage on the 2g fuel gauge? I have been looking for an aftermarket to replace my factory gauge.
0=empty
90 = full?
da1sexmonk83 is offline   Reply With Quote
Old 07-01-2009, 11:44 AM   #11
carusoswi
1998 GSX
carusoswi's Gallery
This sounds like my problem (and I'm searching now for an answer). I recently experienced a fuel pump failure - left me sitting and I had to have the car towed. Dealer put in a new fuel pump and I had to wait an extra day because some part of the fuel line was broken, so they had to order a replacement part. Long story short, the tank was full when the pump failed. I happen to notice that the low fuel light came on when the needle registered 1/4. Kept an eye on the needle and it never moved over some 45 miles. Stopped for gas and the fill-up was slightly over 15 gallons (means I didn't have much fuel left in the tank, for sure).
I asked the dealer to look at this and the reply was that I need a new sending unit. $80 for the part (no problem I think), and $300 to install (I balked at that figure, thinking they should have caught this when the tank was down for the pump replacement).
I'm going to live with this situation until I exhaust other avenues of fixing it without having to layout so much money.
Wish I knew what more of what to look for, but figuring if I keep searching/asking here, I'll eventually find the answer.
Like your car, my light comes on at the proper time - when it stays on steady, I figure I'm safe for 50 miles if necessary.
Additional advice would be appreciated.
Caruso
carusoswi is offline   Reply With Quote
Old 07-01-2009, 12:09 PM   #12
kronus
Ridiculous DSMtalker
kronus's Avatar
'98 GS - '97 TSi AWD
kronus's Gallery
Caruso
That for sure is the sending unit. IMHO, $80 is way too much for one to begin with, but $300 to install? Heck to the no. Do it yourself man. It's not that hard. I don't know where they are located on 2g's but I know at least on a 1g FWD, it's on the rear of the tank. Something like 6 bolts to remove. I imagine the difficulty is on par with a standard fuel pump replacement.
Originally Posted by Wes393 View Post
If you do move on, just make sure it's to something equally interesting. Going from a DSM to some generic people carrier never ends well.
kronus is offline   Reply With Quote
Old 07-01-2009, 05:38 PM   #13
cmspaz
Super DSMtalker
cmspaz's Avatar
03 Evo VIII
cmspaz's Gallery
There are in fact two sensors on the AWD cars, since the tank is split into two main sections by the driveline tunnel. Each outputs half the total voltage for the reading.
I'm guessing that one of my floats is cracked, because my gas gauge accuracy varies each time I drive the car.
~Charles
cmspaz is offline   Reply With Quote
Old 07-02-2009, 03:46 AM   #14
Colin
Super DSMtalker
1990 TSi AWD (auto)
Colin's Gallery
Caruso
On 2g's there is no alignment piece for the pump module when putting it back in the tank. IF you put it in slightly off from where it should sit the float arm will contact the fuel tank baffle in the tank and won't let it drop below 1/4 tank. I've accidentally done this before.
Either that or the dealer bent your arm when doing the pump. My $ is on its not in there correctly and its getting caught up on the internal tank baffle.
The low fuel light is coming on due to its an independent sensor from the float sensor.
To the OP: Sounds like your fuel level sensor is shot. You can test by pulling it out of the tank using a volt meter and registering the change in ohms on the signal line.
Colin is offline   Reply With Quote
Old 07-02-2009, 08:31 AM   #15
Esky
Ultra DSMtalker
Esky's Avatar
2001 Saturn SL1
Esky's Gallery
Which is the signal line, and what should the reading be? I'm guessing it should be very small, and if it's large, then that's the problem?
-Adam
97 GST: Urethaned 6 Bolt, ARPs, BSEK, 5031e, TiAL F38, PR o2, SBR Exhaust Manifold, Dejon 4" Intake, ETS Pro Race FMIC, GReddy Type S, Hallman MBC, MR 3" TBE, CFDF, ACT Flywheel. DSMLink v2.5, GM/MAFT. Remote Oil Filter, B&M Oil Cooler. 17" Motegi RT5s, Brembo Drilled/Slotted, Hawk HPS, Eibach Prokits. Autometer Boost, WB, EGT, Oil Press, and Oil Temp. - SOLD
90 GSX: MR 3" TBE. Autometer Boost Gauge. CRUSHED
