White Smoke - DSM Forums: Mitsubishi Eclipse, Plymouth Laser, and Eagle Talon Forum: DSMtalk.com
Wheel & Tire Center
Notices
Old 02-28-2009, 03:47 AM   #1
GstBeast
GstBeast's Avatar
Mitsubishi gst 97
GstBeast's Gallery
White Smoke
so the other day i thought i was bone dry no more oil... so i put 1 quart of oil but it overfilled it... i ran it for a while... then i got my oil change and now im blowing white/blueish smoke from the exhaust after i let go of the gas pedal...
its only blows when i floor the gas then let go of the pedal... what can be the problem?
GstBeast is offline   Reply With Quote
Old 02-28-2009, 10:47 AM   #2
suprakidd
pontiac gto
suprakidd's Gallery
Re: White Smoke
That generally means your burning something that you shouldn't be...lol
if its a non turbo prolly a head gasket, if its a turbo, it could also be the turbo, turbo gasket...
suprakidd is offline   Reply With Quote
Old 02-28-2009, 11:00 AM   #3
Joescool2008
Super DSMtalker
Joescool2008's Avatar
Eclipse GSX 1990
Joescool2008's Gallery
Re: White Smoke
Time for a turbo rebuild possibly. Check for shaft play and visually inspect for leaking oil.
Joescool2008 is offline   Reply With Quote
Old 02-28-2009, 04:56 PM   #4
Ken81590
Super DSMtalker
Ken81590's Avatar
Eagle/Talon TSI/1995
Ken81590's Gallery
Feedback Score: 7 reviews
Re: White Smoke
Yea check the seals on the turbo. If its not that, then do a compression test and whichever cylinder has the lowest reading, do a leakdown test on that cylinder, because it could be rings, hg, or valve guide seals which would cause buildup on the valve causing it not to seat fully.
Ken81590 is offline   Reply With Quote
Old 02-28-2009, 09:02 PM   #5
GstBeast
GstBeast's Avatar
Mitsubishi gst 97
GstBeast's Gallery
Re: White Smoke
can it be from the oil that leaked out of the engine.. cuz there is oil on the engine that wasnt there before... can it be burning still and being shot out of my exhaust... i aslo changed my pcv valve and that wasnt the problem
Old 03-01-2009, 03:23 PM   #6
xXPROJECT94Xx
DSMtalker
xXPROJECT94Xx's Avatar
1994 Mitsibushi Eclipse
xXPROJECT94Xx's Gallery
Re: White Smoke
Does white smoke always mean that you have a blown head gasket? BTW my car is non turbo.
xXPROJECT94Xx is offline   Reply With Quote
Old 03-01-2009, 04:04 PM   #7
suprakidd
pontiac gto
suprakidd's Gallery
Re: White Smoke
project 94- No it could be a couple other things, the only for sure thing is that you are burning oil or coolant. you could have a minor crack in the head, uncommon, check and see if your spark plug tubes have oil in them. my buddies galant with 4g63 swap just had this problem not too long ago. If you have never replaced the head gasket and you have over 85000 miles on a motor that old i think a head gasket would be most likely.
gst beast- if you are referring to oil that was outside the motor that is burning then there would be no way for that smoke to get into the exhaust so unless the smoke is coming from under the hood then the answer would be no...
Old 03-01-2009, 04:07 PM   #8
suprakidd
pontiac gto
suprakidd's Gallery
Re: White Smoke
The first thing you both need to do is a compression test that will tell you if its a crack/gasket, or possibly something else. You can diagnose from there.
Old 03-01-2009, 05:26 PM   #9
GstBeast
GstBeast's Avatar
Mitsubishi gst 97
GstBeast's Gallery
Re: White Smoke
when i rev it there is smoke coming out of the engine where the oil is at.. i was told if i clean all the oil spots with degreaser that could fix the problem if not then its a head gasket that being cracked....
i also was told to use the repair gasket seal to fix the head gasket but then i was told that it would not help its only temporary and if i use that i have a higher of blowing the head gasket with the motor also
Old 03-01-2009, 07:52 PM   #10
suprakidd
pontiac gto
suprakidd's Gallery
Re: White Smoke
so is it the exhaust or under the hood cuz im mad confused now.
that sealer stuff is a temporary fix and can cause other problems plus its ugly. The rest of your question was confusing to me so i dunno. rephrase it maybe?
Old 03-01-2009, 08:46 PM   #11
GstBeast
GstBeast's Avatar
Mitsubishi gst 97
GstBeast's Gallery
Re: White Smoke
when the hood is open there is smoke that comes out where the oil spots are...
but when i let go fo the gas pedal after i floor it smoke comes out of the exhuast
Old 03-01-2009, 09:02 PM   #12
Ken81590
Super DSMtalker
Ken81590's Avatar
Ken81590's Gallery
Re: White Smoke
White smoke = water/coolant. The only way thats getting in the cylinder is a head gasket, or cracked head.
Blue/gray smoke= oil
Old 03-01-2009, 09:13 PM   #13
suprakidd
pontiac gto
suprakidd's Gallery
Re: White Smoke
ok then the spots under the hood will eventually burn off, or you can try and clean them if you want. the smoke from the exhause needs to be dealt with...either your turbo or head gasket, check the turbo first
Old 03-01-2009, 09:35 PM   #14
GstBeast
GstBeast's Avatar
Mitsubishi gst 97
GstBeast's Gallery
Re: White Smoke
if its my turbo.. if there is shaft play am i going to need a new turbo?
Old 03-01-2009, 10:53 PM   #15
96dsmdemon
Hardcore DSMtalker
96dsmdemon's Avatar
1999 GSX
96dsmdemon's Gallery
Re: White Smoke
If the valve cover gasket is leaking it could be running onto the exhaust manifold and burning from there. As for it coming out of the exhaust, it could be rings, turbo seals, head gasket, head, valve seals. Do a compression test and check the turbo for excessive play. Go from there.
1996 GS-T 455whp - Sold.
1999 GSX can't stop breaking - In progress.
I'm back...
Originally Posted by natedawg9640 View Post
Punctuation saves lives. Case in point:
"Hey let's eat, Grandma!" vs "Hey let's eat Grandma!"
96dsmdemon is offline   Reply With Quote
