GS-T OBD II scanner connection issue - DSM Forums: Mitsubishi Eclipse, Plymouth Laser, and Eagle Talon Forum: DSMtalk.com
Wheel & Tire Center
Notices
Old 04-27-2009, 06:09 PM   #1
rocafellafw
1998 Eclipse GST
rocafellafw's Gallery
Exclamation GS-T OBD II scanner connection issue
I'm having a issue with the OBD II Code reader/scanner I just purchased communicating with my car. I follow the directions fine and everytime it tries to find the protocol I get this error "Failed to establish communication - Verify the connection at the DLC. Verify the ignition is ON. And press any key."
I checked the power and grounds and it came up positive, ground at pins #4&5 and power at pin #16. I was told our cars use protocol ISO 9141 and my tool supports that.
The scanner is the Memoscan U581 "CAN OBD II". I tried to update the software but the website www.memoscan.cn is down and I'm unable to update.
The car: 1998 Eclipse GS-T (with 6-bolt swap, could that cause the issue ? )
The scanner works fine on a friends KIA, but just cannot connect with my car. Does anybody have any suggestions ?
rocafellafw is offline   Reply With Quote
Old 04-27-2009, 06:57 PM   #2
Hellvector
Super DSMtalker
Hellvector's Avatar
926/2000,96 AWD,97 GSX
Hellvector's Gallery
Feedback Score: 4 reviews
Re: GS-T OBD II scanner connection issue
Did you do the 6-bolt swap? Is it safe to assume that all sensors are connected properly? Is it still running the factory ECU?
I'm also assuming you had the car running...
I don't know much about the scanner you're using, since myself, as well as most others on this site use PocketLoggers or DSMLink.
Nathaniel
Originally Posted by rpc91GSX
!#@#!@# Xbox 360's are the DSM's of the gaming platforms.
Hellvector is offline   Reply With Quote
Old 04-27-2009, 07:09 PM   #3
rocafellafw
1998 Eclipse GST
The previous owner did the 6-bolt swap so I have no idea what ECU is in it. I'm not 100% sure about the sensors, what else needs to be hooked up in order for the scanner to communicate ? The car is running but not even close to right so I purchased the scanner so I could maybe get pointed in the direction of the problem.
Old 04-30-2009, 04:57 PM   #4
jwhalen07
1995 mitsu GSX
jwhalen07's Gallery
Sometimes i cannot connect to my ECU.. It gets quit old but keep trying and make sure the OBD2 has all the wires pushed into it...
jwhalen07 is offline   Reply With Quote
Old 05-03-2009, 02:37 AM   #5
rocafellafw
1998 Eclipse GST
I'm going to take the plug off the metal bracket, pull it out a little and make sure all the wires are snug like you said. Thanks for the response.
