Coolant bubbling\boiling , temp gauge overheating help please! - DSM Forums: Mitsubishi Eclipse, Plymouth Laser, and Eagle Talon Forum: DSMtalk.com
Wheel & Tire Center
Notices
Old 06-01-2009, 10:11 PM   #1
jhood99
DSMtalker
Eclipse Spyder GST 96
jhood99's Gallery
Angry Coolant bubbling\boiling , temp gauge overheating help please!
Hey guys i need some serious help and I have no clue to what is going on with my car.I have a 96 spyder gst. Yesterday out of nowhere I noticed my car was overheating. It has coolant in the reserve tank , but the temperature gauge went past the max.Also i keep my radiator fans are on all the time. I pulled over and I noticed that the coolant that was in my tank was bubbling\boiling. I let the car cool down then drove 5 minutes home.( the temp gauge went back up again). So i let the car cool down for about 2 hours , went back outside and again the temperature gauge began going up again.(while the car just sat and idle). So i turned the car off , poured about 1/2 of a tank of anti-freeze into the radiator cap and then turned the car back on. I let the car idle far approximately 20 minutes and the temperature returned and stayed at normal.Today I drove to work and everything was fine. Tonite I drove home from work and when I got home I noticed the temperature gauge going up again. I turned off the car and I could hear to coolant boiling again. Can someone please help me figure out whats wrong with my car. Is it my radiator or what?
jhood99 is offline   Reply With Quote
Old 06-01-2009, 10:21 PM   #2
Red1991TSI
Site Administrator
Red1991TSI's Avatar
1991 Eagle Talon Tsi
Red1991TSI's Gallery
Feedback Score: 78 reviews
Re: Coolant bubbling\boiling , temp gauge overheating help please!
Replace your radiator cap. I think our cars take 13 pound caps but I've seen 16's used too.
Read the rules people!
Red1991TSI is offline   Reply With Quote
Old 06-01-2009, 10:23 PM   #3
jhood99
DSMtalker
jhood99's Gallery
And that will stop my car from overheating?
Old 06-01-2009, 10:24 PM   #4
Red1991TSI
Site Administrator
Red1991TSI's Avatar
If the current one is bad, yes.
Old 06-01-2009, 10:26 PM   #5
lazylaser
Moderator
lazylaser's Avatar
97 talon tsi awd 6 bolt
lazylaser's Gallery
Feedback Score: 27 reviews
It could be that your thermostat is stuck closed or something else not allowing the coolant to make its way through the system, allowing it to boil out.
I would pull the thermostat and test it in hot water to see if it is working correctly, and or replace it because they are cheap.
Or it could be something like a head gasket, allowing the cylinder pressure into the coolant over pressuring the coolant system.
To rule out a head gasket you may want to do a compression test, and also check your oil to make sure that coolant and oil are not mixing.
These are just a couple of guesses. Start with the thermostat and work from there.
My 97 Talon My 98 Eclipse
lazylaser is offline   Reply With Quote
Old 06-01-2009, 10:30 PM   #6
Red1991TSI
Site Administrator
Red1991TSI's Avatar
Order of dianosis in my book:
Cap
Thermostat
Waterpump (check the weep hole)
Clogged radiator (if it's stock or poorly maintenanced)
Pressure test the cooling system
Head Gasket
Old 06-01-2009, 11:27 PM   #7
HOT97ECLIPSEGSX
Site Administrator
HOT97ECLIPSEGSX's Avatar
1997 Mitsu Eclipse GSX
HOT97ECLIPSEGSX's Gallery
I'd do it this way (least expensive to most expensive):
1. Check for coolant in oil/oil in coolant
2. Pressure test the cooling system (free tester from the parts store you just have to front money. You get it back when you return the tester.) Fix leaks and hoses as necessary. You can test your cap this way as well.
3. Check your A/C condenser for a whole bunch of bent fins, bugs, and other things which may not allow airflow to your radiator. Clean, remove, replace as necessary.
4. Ensure both of your fans turn on to their full potential.
5. Check the water pump weep hole
6. Replace radiator cap
7. Replace thermostat (180* thermostat)
8. Clogged radiator (pull, flush with water from a hose, clean off bugs, etc.) Now buy some cooling system flush and flush your entire cooling system by following the directions on the bottle. You'll do this with everything put back together. Use distilled water.
9. Get your cooling system tested for exhaust gases, this will indicate a bad headgasket and give you a good reason for doing it. If you're doing a head gasket, might as well do your timing belt and water pump while you're at it. Use only OEM here (except for the headgasket, you can use what you like, although OEM is GREAT).
- Dustin
DSMtalk Rules and FAQ!!
1997 Mitsubishi Eclipse GSX - 12.281 @ 115.85 MPH (KCIR) - Weekend Terrorizor
2012 Subaru Impreza Limited AWD - The Daily
HOT97ECLIPSEGSX is offline   Reply With Quote
Old 06-02-2009, 01:18 AM   #8
napoleon198905
91 Eclipse 1.8L
napoleon198905's Gallery
Your problem sounds exactly like what I had. The overheating ever so often. Mine was the head gasket. But like everyone else is saying do the run down and pray its not the head gasket but I'm afraid it might be. Check your oil to see if it's milky, then you know it's head gasket.
napoleon198905 is offline   Reply With Quote
Old 06-02-2009, 06:00 AM   #9
The_EE
07 Dodge Caliber
The_EE's Gallery
Feedback Score: 61 reviews
I've had this problem twice in less than a year.
I purchased a block tester, which looks for exhaust gases in the cooling system. Things might be different with pump gas but I cannot detect anything with E-85 lol.
Basically, head is coming off the car today to make sure its straight and a MLS headgasket is being put on the car.
Ex owner of a 97 GSX: Built 7-Bolt | 1g race head | Evo 3 mani / stock o2 | 3" GM MAF | 1g TB | JMFab SMIM | FIC 950cc | 255 Rewired | HKS 272 | Fidanza cam gears | BW 57 Trim | DSMLINK V3 | Fluidampr pully | 3" N1 | AEM WB | QM Twin Disk | DSS Drive Shaft | Eibach pro's | Nitto Invo's | 11.85 @ 130.18 on E-85 - 3582r
Rule #7 Impoorved Spelings! - With high HP comes great Responsibility (Take it to the track!)
If you want 300-400hp read this first
The_EE is offline   Reply With Quote
Old 06-02-2009, 01:43 PM   #10
jhood99
DSMtalker
jhood99's Gallery
I haven't had the chance to do all your guys very helpful and useful advice because I had no time today.(& I do appreciate the advice) Today when I drove the car around the temp remained normal but when i turned off the car the coolant in the reservoir was bubbling. Is it normal for the coolant to be bubbling in the reserve tank or no?
Old 06-02-2009, 01:54 PM   #11
HOT97ECLIPSEGSX
Site Administrator
You're welcome. And no, that is not normal. You have some sort of problem.
- Dustin
Old 06-02-2009, 08:51 PM   #12
91Bluebird
Ultra DSMtalker
91Bluebird's Avatar
93 Talon TSI (m/t)
91Bluebird's Gallery
Feedback Score: 6 reviews
Originally Posted by jhood99 View Post
...but the temperature gauge went past the max...and I noticed that the coolant that was in my tank was bubbling\boiling
On no please do not drive car when coolant temp gauge gets past the 3 o'clock position or risk blowing a head gasket and mechanics charge mucho deniro to replace that for you. Also shut down engine ASAP if your low oil light ever comes on unless you like paying 1000's of dollars to repalce the motor.
2 basics of most internal combustion engines: they need water + oil to cool/lubricate them or they will self-destruct.
91Bluebird is offline   Reply With Quote
Old 06-02-2009, 08:53 PM   #13
HOT97ECLIPSEGSX
Site Administrator
The op has a GS-T which has the coolant gauge on the right side of the car instead of the left. He wouldn't want it to pass the 9 o'clock mark.
- Dustin
Old 06-02-2009, 09:10 PM   #14
91Bluebird
Ultra DSMtalker
91Bluebird's Avatar
93 Talon TSI (m/t)
Huh?
You mean on 2g's at normal operating temps the needle isn't hanging around the 12 o'clock position like on 1g's Well then, you learn something new everyday
Old 06-03-2009, 06:00 AM   #15
The_EE
07 Dodge Caliber
The_EE's Gallery
Originally Posted by 91-Bluebird View Post
Huh?
