What is correct torque sequence for cylinderhead - DSM Forums: Mitsubishi Eclipse, Plymouth Laser, and Eagle Talon Forum: DSMtalk.com
Wheel & Tire Center
Notices
Old 06-10-2009, 12:27 PM   #1
UPSJoKeR
Eagle Talon TSi AWD
UPSJoKeR's Gallery
Feedback Score: 7 reviews
Okk well I just put my ARPS in my block last night with the moly lube, a little silicon on the edge of the block, then put the cylinder head onto the block and just tightened it, however im supposed to torque it down to 120ft.lb with the arp nuts/washers i believe, my question is:
1- Am i supposed to use the moly lube on the top end of the head stuf where the washer/nut go ?
2- what is the correct torque sequence looking at the head from the CAS side (Left to right)
UPSJoKeR is offline   Reply With Quote
Old 06-10-2009, 06:16 PM   #2
newtodsm
Eagle Talon TSI AWD 95
newtodsm's Gallery
Re: What is correct torque sequence for cylinderhead
First off you don't want to torque the studs to 120 ft/lbs. With the use of moly lube you only have to torque them to 80ft/lbs. Yes you should put the moly lube on the part of the stud that sticks out of the head. As for the torque sequence it depends what year your car is. On a final note if you dont have a manual for your car, get one. The manual is your best friend.
newtodsm is offline   Reply With Quote
Old 06-10-2009, 06:42 PM   #3
xuberantz
Hardcore DSMtalker
xuberantz's Avatar
92 Galant VR4 161/1000
xuberantz's Gallery
Feedback Score: 14 reviews
9 5 1 4 8
10 6 2 3 7
xuberantz is offline   Reply With Quote
Old 06-12-2009, 01:17 PM   #4
mr95gst
Mitsubishi Eclipse GST
mr95gst's Gallery
General rule of thumb is to work from the outside in when removing objects and middle out when installing.
mr95gst is offline   Reply With Quote
Old 06-12-2009, 01:51 PM   #5
91turbodsm
Super DSMtalker
91turbodsm's Avatar
91 gst--sold
91turbodsm's Gallery
Feedback Score: 3 reviews
X2
91turbodsm is offline   Reply With Quote
Old 06-12-2009, 06:36 PM   #6
UPSJoKeR
Eagle Talon TSi AWD
UPSJoKeR's Gallery
Hmm Well why is it no good to torque them to 120ft.lbs ? I already did which is why I'm asking, and also thanks for the info guys.
Old 06-15-2009, 04:31 PM   #7
newtodsm
newtodsm's Gallery
Arp says to torque them to 80ft/lbs with the use of moly lube and 120ft/lbs if using motor oil. They also go on to say that the torque values of the studs are based on 75% of the fasteners yield strength. So if you over torque them than you are getting closer to maxing out your fastener. Which defeats the purpose of buying Arp's and not stock.
Old 06-15-2009, 04:53 PM   #8
HOT97ECLIPSEGSX
Site Administrator
HOT97ECLIPSEGSX's Avatar
1997 Mitsu Eclipse GSX
HOT97ECLIPSEGSX's Gallery
Feedback Score: 27 reviews
Moved to Gen Tech.
- Dustin
DSMtalk Rules and FAQ!!
1997 Mitsubishi Eclipse GSX - 12.281 @ 115.85 MPH (KCIR) - Weekend Terrorizor
2012 Subaru Impreza Limited AWD - The Daily
HOT97ECLIPSEGSX is offline   Reply With Quote
