Alarm randomly goes off - DSM Forums: Mitsubishi Eclipse, Plymouth Laser, and Eagle Talon Forum: DSMtalk.com
Wheel & Tire Center
Notices
Old 06-17-2009, 01:53 PM   #1
EclipseGST_97
1997 White Eclipse GST
EclipseGST_97's Gallery
A few nights ago my alarm went off around 11:30 and not a single person was within 50 feet of the car. It was parked in the garage. Then when I get out of work, the alarm is going off (once again, no one near.) Now when I open the doors, the alarm goes off again! I replaced the batteries in the remote, thinking it was that but no. Has this happened to anyone else or anybody know why this is happening?
Thanks
EclipseGST_97 is offline   Reply With Quote
Old 06-17-2009, 02:35 PM   #2
SionGrey66
Hardcore DSMtalker
SionGrey66's Avatar
1998 Eclipse GST
SionGrey66's Gallery
Feedback Score: 15 reviews
Re: Alarm randomly goes off
Is this the stock alarm? Or an aftermarket ones?
The aftermarket ones usually have a small knob to determine the sensitivity of the alarm, you could try messing with that to see if it solves your problem. If your alarm goes off after its already been disarmed though, there's probably something wrong with the control module. Alarms are pretty cheap and easy to install, pick one up and replace your oem one.
-Aria-
A2SportCompacts
SionGrey66 is offline   Reply With Quote
Old 06-17-2009, 03:46 PM   #3
EclipseGST_97
Thanks for the input but I solved the problem.
Old 06-17-2009, 07:42 PM   #4
nad
Hardcore DSMtalker
nad's Avatar
'95 Eagle Talon TSi AWD
nad's Gallery
Feedback Score: 7 reviews
Well?? What was the problem? I'm having the same issue with my factory alarm....
1995 TSi AWD 95K
1987 Chrysler Conquest TSi 88K, all original
2006 CCSB 4x4 Duramax
nad is offline   Reply With Quote
Old 06-17-2009, 07:46 PM   #5
EclipseGST_97
Ahhh so embarrassing.... The alarm was always on and I was never disabling it. So the way to disable it, is to just use your key to open your driver door...
EDIT: Mine was the factory alarm as well.
Old 06-18-2009, 04:29 AM   #6
nad
Hardcore DSMtalker
nad's Avatar
nad's Gallery
Hm, that's odd, cuz that's the only way I can get mine to turn off when it starts going off like crazy out of nowhere. Then the next time I park it, it does it again. It's probably a wiring issue or something. Who knows.
1995 TSi AWD 95K
Old 06-18-2009, 11:11 AM   #7
EclipseGST_97
Do you use your keypad to lock your doors or the key itself? I'm in a pretty safe area so I really don't need the alarm so I just use the key in the door technique.
Old 06-18-2009, 11:29 AM   #8
Liquid2ice
Liquid2ice's Avatar
'96 Eclipse GSX
Liquid2ice's Gallery
Using the key in either of the doors is the only way to disable the alarm after it's been set off, this will also deactivate an armed alarm so you can enter the vehicle. Also, your car will automatically arm itself after you've left it alone for around 30 seconds, unless the keys are in the ignition.
You know what? I'm going to make a flow chart about our stock alarms since they seem to confuse people pretty often.
Liquid2ice is offline   Reply With Quote
Old 06-18-2009, 11:33 AM   #9
EclipseGST_97
Wish I would've known that before I was sitting in the parking lot for 20 minutes with my alarm going off and everybody starring at me
Old 07-05-2009, 07:22 AM   #10
Dsm Rocket
Hardcore DSMtalker
Dsm Rocket's Avatar
Eagle Talon 97
Dsm Rocket's Gallery
Feedback Score: 25 reviews
My factory alarm has been going off on me alot lately. Iv'e tried locking the doors with the button inside and about a minute to 5 minutes later the alarm goes off. Iv'e tried locking it with the key and same thing happens.
So when I go out to shut it off I put the key In the drivers side door and turn it to lock, not unlock. And it shuts off and won't go off anymore.
Till next time I drive the car and lock it again that is. lol
Dsm Rocket is offline   Reply With Quote
Old 07-05-2009, 08:25 AM   #11
Esky
Ultra DSMtalker
Esky's Avatar
2001 Saturn SL1
Esky's Gallery
Feedback Score: 26 reviews
My factory alarm was going off randomly on me too. I would get called out of work because my alarm was going off. It also went off on me a few times in the garage.
My solution: Checked all the alarm triggers (switches). They are little rubber boot covered push switches under the hood, doors, hatch, etc that trigger the alarm when it is engaged.
My issue was with the hood switch. It's on a little bracket and is basically the only "dynamic" switch, in the sense that it is able to travel a bit with age, abuse, adjustment, whatever. From the hood pushing down on it, to the rubber hood height adjusters (4), this switch can be in a place where it does not trigger, or barely triggers and the slightest wisp of wind causes it to switch.
I simply adjusted my rubber height knobs to get the hood where I wanted it, then bent the bracket up a little bit so it would come to meet the hood solidly.
Problem solved.
-Adam
97 GST: Urethaned 6 Bolt, ARPs, BSEK, 5031e, TiAL F38, PR o2, SBR Exhaust Manifold, Dejon 4" Intake, ETS Pro Race FMIC, GReddy Type S, Hallman MBC, MR 3" TBE, CFDF, ACT Flywheel. DSMLink v2.5, GM/MAFT. Remote Oil Filter, B&M Oil Cooler. 17" Motegi RT5s, Brembo Drilled/Slotted, Hawk HPS, Eibach Prokits. Autometer Boost, WB, EGT, Oil Press, and Oil Temp. - SOLD
90 GSX: MR 3" TBE. Autometer Boost Gauge. CRUSHED
Esky is offline   Reply With Quote
Old 07-05-2009, 04:22 PM   #12
Dsm Rocket
Hardcore DSMtalker
Dsm Rocket's Avatar
Eagle Talon 97
You know what, I bet thats my problem too, because I was screwing around with that. I didnt think it was for the alarm. haha
Im going to go try what you said. Thanks man
Old 07-06-2009, 08:58 AM   #13
Esky
Ultra DSMtalker
Esky's Avatar
2001 Saturn SL1
Esky's Gallery
No problem, hope it helps.
-Adam
Old 07-06-2009, 09:05 AM   #14
HOT97ECLIPSEGSX
Site Administrator
HOT97ECLIPSEGSX's Avatar
1997 Mitsu Eclipse GSX
HOT97ECLIPSEGSX's Gallery
Feedback Score: 27 reviews
I agree with the members who said it is the alarm triggers. This could mean your door triggers malfunctioning, etc.
My factory alarm went off in the middle of the night all the time if it was armed during the day. I believed it to be the passenger door trigger. I'm going to have to order a new one so I can get my new Viper 5701 (with remote start!) to work the way it is supposed to.
- Dustin
DSMtalk Rules and FAQ!!
1997 Mitsubishi Eclipse GSX - 12.281 @ 115.85 MPH (KCIR) - Weekend Terrorizor
2012 Subaru Impreza Limited AWD - The Daily
HOT97ECLIPSEGSX is offline   Reply With Quote
Old 07-06-2009, 07:13 PM   #15
Dsm Rocket
Hardcore DSMtalker
Dsm Rocket's Avatar
Eagle Talon 97
I think it was my hood switch. I set the alarm tonight for the first time since my last post and I bent the bracket up some. It was infact bent down a little bit. And its been an hour so far and it hasnt gone off. Before it would go off within maybe 5 mins everytime. But mostly within the first 30 secs.
