Changing Valve Stem Seals? - DSM Forums: Mitsubishi Eclipse, Plymouth Laser, and Eagle Talon Forum: DSMtalk.com
Wheel & Tire Center
Notices
Old 06-18-2009, 06:36 AM   #1
91Bluebird
Ultra DSMtalker
91Bluebird's Avatar
93 Talon TSI (m/t)
91Bluebird's Gallery
Feedback Score: 6 reviews
How hard is this job and how much money to change them myself?
BTW my car smokes after idling awhile exhibiting stem seal problems and compression #'s are good so I'm ASUMING it's bad seals. Is there any other sure way to know if that is indeed the problem so I don't change them and then find out car is still smoking and that wasn't the prblem.
91Bluebird is offline   Reply With Quote
Old 06-18-2009, 06:45 AM   #2
lilredeclipse
lilredeclipse's Avatar
The Purple Monster
lilredeclipse's Gallery
Feedback Score: 16 reviews
Re: Changing Valve Stem Seals?
They are not hard to change at all. But getting to them is all the work. If you do not want to take the head off there is a tool for compressing the springs and taking them off. If you pull it, which is what I normaly just do, it makes it earier to work with, In my opinion.
If you have access to the tools for doing the job with it on the car I would do it that way. It will be cheaper.
If you pull the head it will take longer, replace the head gasket, and probably the timing belt since your in there.
Boosted INC, Purple Monster:
2010, 730awhp- 10.2@154, 10.19@150, 10.15@140
2011, 801AWHP- 9.7@149, 9.8@151, 9.9@151
2013, 823awhp- 9.9@150
lilredeclipse is offline   Reply With Quote
Old 06-18-2009, 01:02 PM   #3
91Bluebird
Ultra DSMtalker
91Bluebird's Avatar
93 Talon TSI (m/t)
Definately wouldn't be pulling the head off so where would I get the tool from and how much for new stem seals?
Old 06-18-2009, 01:24 PM   #4
kennyjr904
Super DSMtalker
kennyjr904's Avatar
'91 S10 & '85 Chevy C10
kennyjr904's Gallery
Feedback Score: 1 reviews
This is the one that I have and it works great. http://www.sjdiscounttools.com/sp91400a.html
Valve stem seals:
http://www.autozone.com/autozone/catalog/parts/partsShelf.jsp?displayName=Valve+Stem+Seal&itemId=prod61172&isSearchByPartNumber=&sortType=null&tota lPages=[I@dee5eb&currentPage=1&vehicleNValue=&navValue=15300013&parentId=cat30063&fromString=&fromWhere=null &filterByKeyWord=&categoryNValue=15399999&categoryDisplayName=&_requestid=77965
Originally Posted by bmxcolorado View Post
lets see you take the corner I did at 90MOH while racing. didnt think so.
._________________________
|.....Overnight.....................| ||
|........Japan Parts................||'|";,___.
|_..._...____________======||_|_|...,]
kennyjr904 is offline   Reply With Quote
Old 06-18-2009, 01:30 PM   #5
napoleon198905
91 Eclipse 1.8L
napoleon198905's Gallery
You will need to have a valve spring compressor. You can get them at almost any parts store. Make sure you tell them you want the one where you can pull the valve springs with the head in the car. I got mine for under $20. You will also need something to put into the spark plug holes to keep the valves from dropping down into the cylinder once you take off the spring. If you have an air compressor great. Go get a leak down tester and use that. Or if you don't have an air compressor you can use a long piece of rope and thread it in through the spark plug hole. Make sure you leave enough hanging out the hole so you can pull it out haha. If you have any questions let me know.
napoleon198905 is offline   Reply With Quote
Old 06-18-2009, 01:33 PM   #6
napoleon198905
91 Eclipse 1.8L
This is the one I use and it does the job and isn't hard on your wallet.
http://www.napaonline.com/MasterPage...ing+Compressor
Old 06-19-2009, 07:45 AM   #7
91Bluebird
Ultra DSMtalker
91Bluebird's Avatar
93 Talon TSI (m/t)
Ok thanks I'll have to think about whether it's worth doing or not since the smoking out the tail pipe is noticeable especially at idle but not THAT bad and oil consumption is still manageable
Old 06-19-2009, 08:04 AM   #8
lilredeclipse
The Purple Monster
How much oil does it eat? Are we talking a quart a day or a quart a month?
Old 06-19-2009, 08:35 AM   #9
gdmbat85
Ultra DSMtalker
gdmbat85's Avatar
99 Eclipse Spyder AWD
gdmbat85's Gallery
Feedback Score: 12 reviews
You're going to need the valve spring compressor that Kennyjr provided a link to to remove the valve springs. I tried several of the ones napolean mentioned but was never able to get close to enough clearance to remove all the springs.
Then, you're going to need this: http://www.sears.com/shc/s/p_10153_1...criptionAnchor
Which will compress the cylinder and keep the valves from dropping into the engine.
George
AWD conversion | Dogbox Racing trans | ACT flywheel | Southbend SS TZFE clutch | 94mm Eagle crank | Manley pistons + H-beam rods | L19's | HKS HG | Kelford 272's | Kiggly beehive springs | Ferrea SS valves | AMS race shaft | Fidanza cam gears | Gates timing belt | FP race manifold | FP 18g | Injen intake | Greddy FMIC kit | Greddy RS BOV | Greddy profec S EBC | JMF street SMIM | 1g TB | Walbro 255hp | FIC 1050's | Aeromotive AFPR | DSMLink v3 | Inovate wideband
gdmbat85 is offline   Reply With Quote
Old 06-19-2009, 08:49 AM   #10
91Bluebird
Ultra DSMtalker
91Bluebird's Avatar
93 Talon TSI (m/t)
1 or 1-1/2 qts a month which isn't a problem money wise and the smoking tailpipe isn't good but it's not obscene either using syntheic oil. When I used regular oil then it was really bad so that's why I switched to synthetic.
Old 06-19-2009, 09:19 AM   #11
1timehondalover
Hardcore DSMtalker
1timehondalover's Avatar
93 Eagle TSi AWD
1timehondalover's Gallery
Feedback Score: 11 reviews
I'm surprised no one mentioned special valve seal pliers in all of this tool talk. They will help you not gouge the guides and make old seal removal much easier.
Make sure you check that there is no old seal left over on the guide or it can cause the new seal to sit too high.
1993 Talon AWD : Mahle-Manley 6 bolt 2.0 / MLS hg / HX35 12cm T3 / JMF Race SMIM / Crower 272's / FIC 1050's / DSMLink / 2g MAS / Supra TT pump / Punishment Racing FMIC and radiator / ShepTrans Stg. 3 / RPS Max PP and ACT solid disc / 3" turbo back exhaust / interior stripped and 6 pointed :
1997 Eclipse GSX : DD Status :
1timehondalover is offline   Reply With Quote
Old 06-19-2009, 11:13 AM   #12
mrt05zx6r
99 Spyder GST (Sold)
mrt05zx6r's Gallery
Feedback Score: 2 reviews
I always figured you had to take out the valves to change the seals. Can this method be done on any type of engine (not just DSM's), so long as you have access to the top of the heads?
mrt05zx6r is offline   Reply With Quote
Old 06-19-2009, 11:25 AM   #13
lilredeclipse
The Purple Monster
You have to pressurize the cylinder with air to keep the valves held up in place.
Someone else might have another crack head way but that is the best.
Old 06-19-2009, 12:29 PM   #14
kennyjr904
Super DSMtalker
kennyjr904's Avatar
You mean the rope trick I assume.
Old 06-19-2009, 12:48 PM   #15
willbur9788
willbur9788's Avatar
97 eclipse gsx
willbur9788's Gallery
I used the rope trick, It worked pretty well. They have the whole process on vfaq.
http://www.vfaq.com/index-main.html
The valve compressor he used on vfaq is a little different, but the valve spring compressor kennyjr904 recommended is the same concept and half the price. I used the same one he recommended and it worked well. I purchased mine through snap on though and it was 60 bucks more for the same thing.
willbur9788 is offline   Reply With Quote
