No Start!! Bad Ground? Bad Battery? Bad Starter? Magic? - DSM Forums: Mitsubishi Eclipse, Plymouth Laser, and Eagle Talon Forum: DSMtalk.com
» Wheel & Tire Center
Old 07-28-2009, 08:21 AM   #1
TurboJuice
Hardcore DSMtalker
TurboJuice's Avatar
'97 Eclipse GS-T
TurboJuice's Gallery
Feedback Score: 10 reviews
Ok, I am in need of some direction. There are a lot of variables here, but please give me your best guess as to what's wrong and what to try next.
3yr old optima red top battery - mounted in the trunk
Brand new autozone / duralast starter
Brand new autozone / duralast 90A alternator
Just regrounded and added additional ground to negative battery terminal
Now the issue is sometimes the car starts and sometimes it doesnt.
Here is what happened last night. I fire the car up after work for a cruise and it starts no problem. Cruise for an hour and i stall it at an intersection. I try to start it and it just clicks. Just one solid click and nothing at all.
I fiddle for 10 minutes before someone offers to push me over. She we push it over and and i figure what thge hell lets try and jump it. Hook up and the jumpers and vroom!
So limp it home and actually stalled it again! This time for some reason it decided to fire up.
I get in the garage, shut it off, then try to start again and nothing. Just a click. I crank it a bunch of time and it just clicks once everytime. Then all of a sudden it fires over. I shut it off again and then it wont start.
I let the car sit in the garage for 2 hours and when i came back out it fired up 4 times in a row with no hesitation.
When i got in the garage i took some voltages.
Battery voltage with the car on is 13.8
Alt voltage with the car on is 14.0
My turbo time on the dash reads 13.0
With the car off voltage at the battery is 12.2
Turbo timer reads 11.8
I am stumped. I thought because i jumped the car, the battery was tired. But i cranked the hell out of the battery in my garage(trying to drain it). But then i let the car sit and it fired up.
I have no idea, Do those voltages look OK? Maybe a bad starter?
Thanks for reading this far.
TurboJuice is offline   Reply With Quote
Old 07-28-2009, 08:48 AM   #2
Lazer382
Lazer382's Avatar
92 Eclipse GST
Lazer382's Gallery
Feedback Score: 3 reviews
Re: No Start!! Bad Ground? Bad Battery? Bad Starter? Magic?
From those voltages I doubt the battery is a problem. Since the car is running fine too I think we can rule out a lack of fuel/spark.
Sounds like the problem is the starter. That one solid click you hear is the relay trying to power the starter but the starter doing nothing. If it had cranked then the issue would be something else.
Good luck.
Lazer382 is offline   Reply With Quote
Old 07-28-2009, 08:58 AM   #3
bmxcolorado
Hardcore DSMtalker
bmxcolorado's Avatar
Check the signature
bmxcolorado's Gallery
Feedback Score: -1 reviews
Starter solenoid or starter. All I can think of.
1994 Mitsubishi Eclipse GS- Totaled 10/26/09
Originally Posted by CrackedDSM View Post
DSM's are a turbocharged sports car meant from the factory to be fast. Honda's are slow shit aluminum blocked gas sipper's meant for daily driving.
bmxcolorado is offline   Reply With Quote
Old 07-28-2009, 09:25 AM   #4
TurboJuice
Hardcore DSMtalker
TurboJuice's Avatar
'97 Eclipse GS-T
My mechanic is telling me that my battery in the trunk could be an issue. He says I am losing AMPs / gaining resistance because the battery is in the trunk. true / False
Old 07-28-2009, 09:46 AM   #5
Lazer382
Lazer382's Avatar
92 Eclipse GST
Lazer382's Gallery
Although partially true, I really doubt this is the problem. Still think starter / starter solenoid.
Old 07-28-2009, 09:56 AM   #6
talonryder95
DSMtalker
talonryder95's Avatar
1995 talon tsi
talonryder95's Gallery
Feedback Score: 12 reviews
Okay , my battery is in the trunk and never, ever had an slow crank or problem. What i do wonder tho is what size wiring do you have to run from the battery to the fuse box. Also what size cable and how many cables and where do they go for the grounds in the trunk and under the hood?
Sounds like it should be an starter/solenoid problem but could be an small factor with your wiring and fuse/connections.
I have dual 0 gauge grounds in trunk and under hood.Have dual 0 gauge power going to an splitter box and then got a 4 ga going to the fuse box.
talonryder95 is offline   Reply With Quote
Old 07-28-2009, 10:03 AM   #7
TurboJuice
Hardcore DSMtalker
TurboJuice's Avatar
'97 Eclipse GS-T
I have one 0 gauge + wire from the battery to the stock cluster under the hood.
I have one 0 gauge - from the battery to a paintless tab in the trunk
One 6 gauge - from the battery to a rear seat belt bolt hole, sanded down
one 6 gauge from the trans to the firewall
Old 07-28-2009, 10:22 AM   #8
talonryder95
DSMtalker
1995 talon tsi
sounds like your battery in the trunk is fine. 0 gauge is plenty to run the power up there. By means of under the hood, as long as your original grounds are still there and the one that use to run to the battery you grounded to the firewall, i dont see that an problem.
Im sure most people here are going to point you toward your starter/solenoid combo. Your battery seems to be at an good voltage and so does your alternator. I read that when you did have the car able to start, the battery had plenty of power to keep cranking on its own so it still has its cranking amps....
I think the last thing you could try to do is when the car doesnt want to start, try to use an set of jumper cables to connect to both strut towers and connect to the engine and trans. See if its for some reason an bad grounding issue first then look at the starter. The jumper cables will just be both used for grounding- no/not positve.
Old 07-28-2009, 11:44 AM   #9
Gamble
Ridiculous DSMtalker
Gamble's Avatar
02 Hyundai
Gamble's Gallery
Feedback Score: 39 reviews
While this is true it's not enough to hardly make a difference, unless you were using like a 10g wire.
And your mechanic is who?!?
Gamble is offline   Reply With Quote
Old 07-28-2009, 11:50 AM   #10
TurboJuice
Hardcore DSMtalker
TurboJuice's Avatar
'97 Eclipse GS-T
Devin really hates my battery being in the trunk for some reason.
Old 07-28-2009, 11:56 AM   #11
Gamble
Gamble's Avatar
02 Hyundai
Gamble's Gallery
Take the resistance of the short stock wire and the wire you have in there now, there won't be that much of a difference.
Old 07-28-2009, 12:04 PM   #12
TurboJuice
Hardcore DSMtalker
TurboJuice's Avatar
'97 Eclipse GS-T
yea, I am really leaning towards the starter being junk.
The only thing holding me back, is why would the starter not turn the car over on its own, but then with the added boost of jumper cables, be able to start?
The throw in the starts when cold but no start(unless jumped) when hot.
Is there somthing internally in the starter that would explain this?
Too many variables to this damn equation.
Old 07-28-2009, 12:09 PM   #13
GotARed
Ultra DSMtalker
GotARed's Avatar
98 GSX 2.0 E85
GotARed's Gallery
Matt, We had that exact same problem with the teal 1g that we bought from Devin last winter.
The battery is in the stock location.
It ended up being the starter, we changed in and it never happened again!
Project "GF's Talon"-in the works AGAIN!
long rod 2.0 l BW s475 l link l1600's l5in exhaust l125shot
Originally Posted by Asmodeus
Would you prefer babe, honey or sweet ass? How about the infamous "hey bitch" All of which are better than- hey you dumb fucking cunt come over here. Right?
GotARed is offline   Reply With Quote
Old 07-28-2009, 12:10 PM   #14
GotARed
Ultra DSMtalker
GotARed's Avatar
98 GSX 2.0 E85
GotARed's Gallery
You just got lucky and it happened to want to work the same time that you hooked the cables up.
Old 07-28-2009, 12:35 PM   #15
Gamble
Gamble's Avatar
02 Hyundai
Gamble's Gallery
I had the same issue with my honda. It ended up being the key ignition.
