Crank but no start after 4g63 swap - DSM Forums: Mitsubishi Eclipse, Plymouth Laser, and Eagle Talon Forum: DSMtalk.com
Wheel & Tire Center
Notices
Old 08-10-2009, 07:14 PM   #1
goose_14
goose_14's Avatar
1993 Eagle Talon
goose_14's Gallery
I got everything I know done and when I try to start it only cranks. It also sounds kind of weak its a 93 talon. Where should I look for a solution at?
goose_14 is offline   Reply With Quote
Old 08-10-2009, 07:16 PM   #2
goose_14
goose_14's Avatar
1993 Eagle Talon
goose_14's Gallery
Re: Crank but no start after 4g63 swap
Also I put gas in and changed the plugs and wires and flushed the radiator and changed the oil. I was thinking that it could have something to do with the ECU since its from a different car then the engine and the wiring harness.
Old 08-11-2009, 08:20 AM   #3
Lazer382
DSMtalker
Lazer382's Avatar
92 Talon TSi AWD
Lazer382's Gallery
Feedback Score: 3 reviews
Unless you have a tuning device you need an ECU that matches the injectors your motor has. What did you swap from? Was it a 1.8? And is the 4g63 na or turbo?
Although there is a good chance you have the wrong ecu, the car should at least turn over and then (worst case) idle bad and stall.
Do you get spark? Fuel? Compression? Those are the only reasons it might not kick over. Maybe CAS? Also you said different harness... did the old one plug right in or is there stuff not attached?
Lazer382 is offline   Reply With Quote
Old 08-11-2009, 09:28 AM   #4
hubz91talontsi
Eclipse/GST/90
hubz91talontsi's Gallery
Year really doesn't matter if you have a 91-94 ecu. Im pretty sure a 90 won't just fix when you swap it. Could have bad caps, but first check the basics. Spark,fuel,compression.
hubz91talontsi is offline   Reply With Quote
Old 08-13-2009, 04:27 PM   #5
goose_14
goose_14's Avatar
1993 Eagle Talon
goose_14's Gallery
got it to start but idle rev from 600-900 rpm. also my headers change color when hot and only two are getting hot. any suggestions?
Old 08-13-2009, 04:58 PM   #6
Ken81590
Super DSMtalker
Ken81590's Avatar
Eagle/Talon TSI/1995
Ken81590's Gallery
Feedback Score: 7 reviews
That's a fine rpm for idle. And about the only two runners getting hot, you would know if only two cylinders were firing.
Ken81590 is offline   Reply With Quote
Old 08-13-2009, 08:28 PM   #7
goose_14
goose_14's Avatar
1993 Eagle Talon
goose_14's Gallery
when it started it runs real rough and vibrates. it doesn't seem to have much power. there are a couple vacuum hoses i don't know where to hook up coming out the thermostat housing and one other hosed on the intake manifold that has no hose attached. any suggestions?
Old 08-13-2009, 09:14 PM   #8
Sean485
Senior Moderator
Sean485's Avatar
99 Spyder "GSX"
Sean485's Gallery
Rule 7... What hose on the intake manni? Sounds like you left the PCV valve line off and have a massive vac. leak.
99 Spyder "GSX"
Sean Clancy
Sean485 is offline   Reply With Quote
Old 08-13-2009, 09:27 PM   #9
laith
DSMtalker
laith's Avatar
98 eclipse gst spyder
laith's Gallery
Feedback Score: 2 reviews
What? Vacuum hoses coming out of the thermostat housing? That's not making any sense.
laith is offline   Reply With Quote
Old 08-13-2009, 10:01 PM   #10
need2fix
Hardcore DSMtalker
need2fix's Avatar
92 Talon TSI AWD
need2fix's Gallery
The 'vacuum' hose coming out of your thermostat housing should go to your resevoir.
The Thrill is gone... The thrill is gone away....
95 AWD Shell, the Second Generation.
need2fix is offline   Reply With Quote
Old 08-13-2009, 10:21 PM   #11
gdmbat85
Ultra DSMtalker
gdmbat85's Avatar
99 Eclipse Spyder AWD
gdmbat85's Gallery
Feedback Score: 12 reviews
How did you manage to get the engine in yourself? Honestly, no offense, but from saying something like that, I'd suggest you have a local DSM'er come take a look at your car and fix up all the issues. He/she can show you what everything does and where it goes.
George
AWD conversion | Dogbox Racing trans | ACT flywheel | Southbend SS TZFE clutch | 94mm Eagle crank | Manley pistons + H-beam rods | L19's | HKS HG | Kelford 272's | Kiggly beehive springs | Ferrea SS valves | AMS race shaft | Fidanza cam gears | Gates timing belt | FP race manifold | FP 18g | Injen intake | Greddy FMIC kit | Greddy RS BOV | Greddy profec S EBC | JMF street SMIM | 1g TB | Walbro 255hp | FIC 1050's | Aeromotive AFPR | DSMLink v3 | Inovate wideband
gdmbat85 is offline   Reply With Quote
Old 08-14-2009, 07:56 AM   #12
Lazer382
DSMtalker
Lazer382's Avatar
92 Talon TSi AWD
Lazer382's Gallery
I realize just about everyone has blocked their egr and don't have the vac lines going to the thermostat housing (for that temp sensor) but it's funny to see people not even remember they used to be there.
Although the OP is clearly confused it isn't helping him to tell him he doesn't know what he's doing.
Here are some vac diagrams that should help you see what is what:
http://www.dsmtuners.com/forums/arti...val-1g-2g.html
If a vac hose isn't connected you are just creating boost leaks.
Things to double check:
Make sure the FPR vac hose connects to the intake manifold where it should be.
Make sure the BOV is connected where it should be.
Make sure the wastegate is tapped directly off the jpipe (right after the turbo compressor side)
Just about all the other vac lines can be capped off. If you still have an EGR those vac lines from the thermostat housing need to be connected as shown in the diagram.
There's tons of other things to check also such as that your firing order is correct and that you are using a 1g ecu, and correct size injectors (should be 450 for stock).
Old 08-16-2009, 02:10 PM   #13
goose_14
goose_14's Avatar
1993 Eagle Talon
goose_14's Gallery
He is right I don't know much more than the basics but I got the engine in and ran a new wiring harness also. That being said I don't know what FPR vac is, BOV is, or CAS and it's a non turbo 6 bolt engine. I checked the fuel and the spark. How do I check the compression. I haven't timed it yet but it feels like it's completely missing cylinder maybe even two.
Old 08-16-2009, 02:54 PM   #14
Himari
Super DSMtalker
Himari's Avatar
1993 Eagle Talon DL
Himari's Gallery
Feedback Score: 1 reviews
FPR = Fuel Pressure Regulator
BOV = Blow Off Valve (You don't have with a non turbo)
CAS = Camshaft Angle Sensor
Which cylinders aren't firing? And do you have a Check Engine light on?
94 Eagle Talon DL - (Dead and Gone)
91 Mitsubishi Eclipse GS-T - Current Project.
1G GSX/TSI AWD - Dream and future goal!
Himari is offline   Reply With Quote
Old 08-16-2009, 03:36 PM   #15
goose_14
goose_14's Avatar
1993 Eagle Talon
goose_14's Gallery
I can't be positive but 1 and maybe 2. Where is the CAS?
