Can a heater core cause the car to overheat ?? - DSM Forums: Mitsubishi Eclipse, Plymouth Laser, and Eagle Talon Forum: DSMtalk.com
Wheel & Tire Center
Notices
Old 09-11-2009, 07:58 PM   #1
UPSJoKeR
Eagle Talon TSi AWD
UPSJoKeR's Gallery
Feedback Score: 7 reviews
Hey I just have a quick question, can the heater core in a 2g awd turbo cause the car to slightly overheat if it is clogged ??
ALSO another thing I noticed is that if I'm in a carwash with the heat on I would see some coolant dripping on the passenger side floor, could that cause however the car does not over heat like that its only when I start the car for the first time, I just want to know if a heater core can cause the car to over heat. THATS ALL.
Please no HG suggestions, I know its either the heater core or the radiator, I just want to see if its possible for the heater core to over heat.
UPSJoKeR is offline   Reply With Quote
Old 09-11-2009, 08:00 PM   #2
shinotheweevil
DSMtalker
shinotheweevil's Avatar
Mitsubishi/eclipse/1990
shinotheweevil's Gallery
Feedback Score: 1 reviews
Re: Can a heater core cause the car to overheat ??
Yes happened to me! And yes coolant on the passenger floor means blown heater core.
shinotheweevil is offline   Reply With Quote
Old 09-11-2009, 08:09 PM   #3
UPSJoKeR
Eagle Talon TSi AWD
UPSJoKeR's Gallery
Hmmm, so when you replaced that did your car stop over heating, as for the coolant on the floor that ONLY happens when im in a car wash with the heat on NOT ANY OTHER TIME, so could it still be that.
Old 09-11-2009, 08:18 PM   #4
UPSJoKeR
Eagle Talon TSi AWD
UPSJoKeR's Gallery
Anyone else???
Old 09-11-2009, 08:20 PM   #5
Sean485
Senior Moderator
Sean485's Avatar
99 Spyder "GSX"
Sean485's Gallery
No it will not cause it to overheat unless it is leaking.
99 Spyder "GSX"
Sean Clancy
Sean485 is offline   Reply With Quote
Old 09-11-2009, 08:24 PM   #6
UPSJoKeR
Eagle Talon TSi AWD
UPSJoKeR's Gallery
Ok just to clarify it will cause the car to overheat due to loss of coolant not pressure in the system (causing tstat not to open) right ?
Old 09-11-2009, 08:42 PM   #7
UPSJoKeR
Eagle Talon TSi AWD
UPSJoKeR's Gallery
bump
Old 09-11-2009, 09:17 PM   #8
Sean485
Senior Moderator
Sean485's Avatar
99 Spyder "GSX"
Sean485's Gallery
Do Not Bump Up Posts, Especially, After Only 18 Minutes!
99 Spyder "GSX"
Sean Clancy
Old 09-11-2009, 09:23 PM   #9
UPSJoKeR
Eagle Talon TSi AWD
UPSJoKeR's Gallery
Well Im trying to get a quick question, I mean im not trying to be an ass but I'm sort of in a hurry.
Old 09-11-2009, 09:33 PM   #10
shinotheweevil
DSMtalker
Did you bypass the heater core? If you bypass it and your car works great then you know its the heater core.
Old 09-11-2009, 09:53 PM   #11
UPSJoKeR
Eagle Talon TSi AWD
UPSJoKeR's Gallery
I want to try that, If I want to do that all I have to do is bend the line comming out of the water pipe upwards to connect it to the tstat housing yea ?
Old 09-11-2009, 10:11 PM   #12
shinotheweevil
DSMtalker
I don't know what you just said, but if you said, "take the two radiator hoses that go to the firewall and connect them together." Then I would say yes.
Old 09-11-2009, 11:28 PM   #13
UPSJoKeR
Eagle Talon TSi AWD
UPSJoKeR's Gallery
Yea, thats what I said in other words though, Kk thanks for info.
