Really Rough Idle after Rebuild - DSM Forums: Mitsubishi Eclipse, Plymouth Laser, and Eagle Talon Forum: DSMtalk.com
Wheel & Tire Center
Notices
Old 06-29-2010, 10:51 AM   #1
kingclem123
Eagle talon 95
kingclem123's Gallery
Ok rebuilt the engine recently, herea are the Mods on the car.
Car is a 2G
1G bottom end
2G head (rebuilt by DSM graveyard)
big 16G turbo
750cc ing
walbro 255cc fuel rail
Apexi EBC
Punishment FMIC
DSM link
The car started up fine on the first try, there was a little bit of white smoke out the exhaust but that went away i ran the car for a few minutes.the car had high idle, but everything sounded good. the car heated up to normal temperture and would bogged down. i thought this was normal because i figured it just needed to be tuned. when i came home from work and went to start her, she was hesitant and the idle was real sloppy. plus i saw what looked like a small amount of vapor/smoke coming from behind the intake. i imeadiately did a compression check , there were between 165-175 across the board, so that was good, i then did a boost leak test and found that i have a crack in my VC, im replacing that tonight after i get home. one other thing, i noticed the grey vapor by the intake when i cranked the engine but couldnt tell where its was comming from.
any ideas why the idle is so erradic and wont stay started?
kingclem123 is offline   Reply With Quote
Old 07-02-2010, 12:59 AM   #2
luthoro
luthoro's Avatar
1990 Eclipse GSX
luthoro's Gallery
Re: Really Rough Idle after Rebuild
Is it still rough under throttle or just when idling? I ask because my 90 GSX is running pretty much like shit at idle but does fine under throttle. I have been looking back a few pages and couldn't find anything with the same symptoms as me. Maybe we both have the same issue.
luthoro is offline   Reply With Quote
Old 07-02-2010, 08:59 AM   #3
goalie40
Hardcore DSMtalker
goalie40's Avatar
1997 GST Spyder
goalie40's Gallery
Two things. First double check timing you could be off a tooth. It could just be the no tune. My old GST ran like crap, with just 550's and no tune.
goalie40 is offline   Reply With Quote
Old 07-02-2010, 11:56 AM   #4
luthoro
luthoro's Avatar
1990 Eclipse GSX
luthoro's Gallery
I forgot to mention, mine is a fresh rebuild, too. About 5k on it. All I know about this car is that they used Crower forged rods and JE forged pistons for the rebuild, it also has a 16g turbo upgrade and a Megan Racing turbo-back 3" exhaust. Boosting at 16-20psi. I don't know what size the injectors are, but I pulled the plugs the day I got it, and from their condition, its running rich. I assumed it still had stock 450cc injectors, but maybe not?
Old 07-02-2010, 12:15 PM   #5
kingclem123
Eagle talon 95
Well i found the problem and shes purring like a kitten now. I didnt install my timing belt on tight enough and skipped a tooth. Now everything looks good as far as breakin in goes. Got lucky as far as that i didnt bend a valve. still 165-180s across all cylinders. Thanks for the help though.
