wont go into gear when the car is running - DSM Forums: Mitsubishi Eclipse, Plymouth Laser, and Eagle Talon Forum: DSMtalk.com
Wheel & Tire Center
Notices
Old 07-10-2010, 01:29 AM   #1
STREETSTYLEAUTO
Eclipse GSX 1996
STREETSTYLEAUTO's Gallery
i just got the following installed by turbotrix
-jdm trnasmission and t-case
-act 2600
-act flywheel
-oem clutch fork and ball
-all the belts
-oem water pump
i drove it home (5 miles) no problems
left it in my driveway for about a week
then i wanted to take it for a spin
but it wouldnt let me put it in gear
if i pushed the shifter hard enough it started to grind
so i shut off the engine and tried to go thru the gears (1-5)
and it lets me but when i turn on the car it wont
what could it be???
there are no leaks anywhere
also when i drove it home and changed gears
sometimes the rpms will drop to 0 and the car would shut off
i was thinking is because of the flywheel but idk
STREETSTYLEAUTO is offline   Reply With Quote
Old 07-10-2010, 11:14 AM   #2
twicks69
Super DSMtalker
twicks69's Avatar
1999 Eclipse GSX
twicks69's Gallery
Re: wont go into gear when the car is running
Clutch hydraulics - either a leak, an air bubble, or you need to adjust your master cylinder rod to increase pedal throw (adjusting the rod towards the firewall).
Tim Zimmer
1999 Mitsubishi Eclipse GSX
*7-Bolt 2.3L Custom Groden Aluminum Rod/CP Piston Combo w/ Borg Warner S400SX 74mm turbo.
*1020AWHP/730TQ @ 48psi
*9.49 @ 148 on 30psi at 740AWHP.
TMZ Performance - www.tmzperformance.com
twicks69 is offline   Reply With Quote
Old 07-10-2010, 02:18 PM   #3
9.0Buck60
Hardcore DSMtalker
9.0Buck60's Avatar
1992 Eagle Talon TSi
9.0Buck60's Gallery
-act 2600
-act flywheel
-all the belts
-oem water pump
what could it be???
ACT uses chrome moly for their flywheels. Not quite as light as the aluminum ones. Your having an issue with clutch engagement. There could be a number of things causing this to occur,however twicks just gave you one possibility.
9.0Buck60 is offline   Reply With Quote
Old 07-10-2010, 04:53 PM   #4
9.0Buck60
Hardcore DSMtalker
9.0Buck60's Avatar
9.0Buck60's Gallery
That could be anything. IAC,TPS,ZTS. I would go through the basics first. Check fuel,spark,and all sensors and devices that controll the engine.
Also,try checking the coils. Do you have a Fluke/volt meter?
Old 07-10-2010, 05:22 PM   #5
HOT97ECLIPSEGSX
Site Administrator
HOT97ECLIPSEGSX's Avatar
1997 Mitsu Eclipse GSX
HOT97ECLIPSEGSX's Gallery
Feedback Score: 27 reviews
I'm having the same problem with my car. Jack's "Premium", with Competition 6-puck. Most likely a dead disk. We'll see.
- Dustin
DSMtalk Rules and FAQ!!
1997 Mitsubishi Eclipse GSX - 12.281 @ 115.85 MPH (KCIR) - Weekend Terrorizor
2012 Subaru Impreza Limited AWD - The Daily
HOT97ECLIPSEGSX is offline   Reply With Quote
Old 07-23-2010, 10:02 PM   #6
Lemons6245
DSMtalker
Lemons6245's Avatar
1995 Eclipse Gst
Lemons6245's Gallery
i have somewhat of that problem, sometimes i have to force it into gear and other times its smooth
Lemons6245 is offline   Reply With Quote
Old 07-23-2010, 10:36 PM   #7
HOT97ECLIPSEGSX
Site Administrator
Please remember rule #7 when you post.
- Dustin
